#1651 |
![]() Join Date: Aug 2013
Re: Post your 60-66 craigslist finds
https://slo.craigslist.org/cto/d/arr...583955575.html 1966 Chevy C10 - $1 (Arroyo Grande) 1966 Chevy C10 pickup, short bed, fleetside, big back window, 540 c.i. bbc with twin turbos, conservative 10 lbs boost, Dart 345 aluminum heads, Holley Super Sniper Stealth EFI, blow through throttle body, Holley Sniper tunnel ram, Comp Cams hyd roller cam and rockers, MSD 6AL box, MSD Magnetic pickup distributor, built turbo 400 trans, 2600 stall converter, Gear Vendors Overdrive, 9" PEM Ford rear w/3.70 POSI, front 6-piston Wilwood disc brakes, GM rear disc brakes w/e brake, CPP rear coilovers with tubular trailing arms, Riddler 605 20" wheels with Nitto rubber, electric parking/emergency brake, all polished 3" stainless exhaust, with electric cutouts thru front fenders and full exhaust with bullet mufflers exiting thru the bed, rear bed mounted radiator with dual electric fans, electric water pump runs 180-190 degrees, front mounted 3" air to air intercooler for the turbos, custom butcherblock rear bed floor made of Hickory and Black Walnut inserts mounted to an electrically controlled frame, rear mounted Tanks aluminum fuel tank with Aeromotive 1000 intank fuel pump, bed mounted Optima yellow top battery underneath easily removable bed floor panels, interior seats/console/door panels by TMI Products, One Piece Products door glass(no windwings) with power window conversion, Custom Autosound Bluetooth stereo, Dakota Digital VDX gauges with GPS speedometer, Ron Francis wiring harness, bed sides, tailgate, headboard and front fenders all new steel, fiberglass lift off hood, satin paint, and much more I've probably forgotten about. Runs perfect, shifts hard, lots of eyeball and sounds threatening. Less than 1100 miles at this point. Have clean CA title in hand. $85k . Reply to craigslist with contact information. Driving / walk-around / cold start video on youtube.https://youtu.be/ds9yFK99g04, https://youtu.be/p_VpySeNi6I . 1966 twin turbo c10
"Envy is a declaration of inferiority". Napoleon Bonaparte. |
#1652 |
https://sfbay.craigslist.org/nby/cto...584352878.html 1965 C10 Stepside - $16,500 (Petaluma) Freshly painted 1965 Chevy C10, new oak bed, we 22” transports with new rubber. Fresh drum brakes all the way around, runs and drives great. New aluminum radiator, carburetor, gas tank relocated under bed.
#1653 |
https://sfbay.craigslist.org/eby/cto...585793952.html 1963 short bed c10 - $12,000 (concord / pleasant hill / martinez) 350
700r4 Short bed New brakes New tires Vintage slot mags Manual steering Manual brakes Old paint Lights work Runs drives stops $12,000.
#1654 |
This is quite a deal for someone that has some room. Three panel trucks for $7000
https://losangeles.craigslist.org/an...589239338.html |
#1655 | |
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 1990 Chevy Bus 8.2l fuel pincher 8800 miles 1993 Ford F350 crewcab 7.3idi nonturbo ZF5 Transmission Running on WMO |
#1656 |
![]() Join Date: Oct 2009
66 GMC 1/2 ton Custom Cab bbw - don't see these every day.. Rough condition but only $3K. Would be a gem restored.
#1657 |
I know that big back window short bed fleet sides are popular right now but prices are becoming a little ridiculous. Especially for a truck that doesn’t run and looks to have rusted rockers.
https://losangeles.craigslist.org/sg...629679624.html |
#1658 | |
![]() Join Date: Sep 2022
Or not, since I'm trying to stay somewhat sane about that... |
#1659 | |
straight body minimal rust factory short bed factory big window factory a/c factory v8 factory interior unmolested knee knocker cab w/o pig nose hood I suspect it could be fairly haggled to $15k and doesn't last long
I started out with nothing - and I still have most of it |
#1660 | |
#1661 |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
I don't think that that is "factory" AC. Also the heater box and receiver dryer are missing. Cute little truck, though.
#1662 |
I think it's dealer installed AC but a universal "factory approved" unit as if I recall it was an available accessory in pre-'64 trucks. In '64 we got the C10 specific design, still dealer installed, then '65+ onward it was factory installed.
#1663 |
All I can say is that is one time I would not mind sitting in the middle.
#1664 |
although it's not really my type, that truck checks a lot of boxes as far as the market goes
my apologies if I misspoke on the a/c, I wasn't sure when they started in dash but still, even if it's oem installed at the dealer it's a pro not a con and I'm right there with you Forest!
#1665 |
![]() Join Date: Nov 2022
FBMP find
Check out the rims on both trucks selling for 7K! https://www.facebook.com/marketplace...3-344ac642db70 |
#1666 | |
#1667 |
I know its not a craigslist find but a fakebook one
https://www.facebook.com/marketplace...1942090228679/
dont want to hear excuses, i want to hear solution(s) |
#1668 |
![]() Join Date: Nov 2007
Greensboro, NC my hometown!! Nice find.
1963 Chevrolet C-10 "Ginger" ![]() 1970 C-30 Dump Truck "Scarlet" 2019 Chevy Silverado 2500 Z71 LTZ 1947 Indian Chief Roadmaster with Sidecar. 2012 Indian Chief Serial #002 of 110 built in '12 2016 Indian Chief Roadmaster |
#1669 |
Good running 292 4 spd transmission and transfer case for sale WA $500!!
https://www.facebook.com/marketplace...9982427035071/ Last edited by CKfan; 06-16-2023 at 11:31 PM. Reason: spell |
#1670 | |
https://losangeles.craigslist.org/sg...634720048.html |
#1671 |
#1672 |
Fotos(s) from the link above
Thats an interesting setup on that rear bumper w the trailer hitch Could use that air cleaner if its for one for a four barrel . . .
#1673 |
65 K10 stepper ebay $20K starting bid
#1674 |
Moderator
![]() ![]() Join Date: Aug 2011
1960 Chevy Apache Fan Shroud and Radiator.
https://www.facebook.com/commerce/li...are_attachment
| Bookmarks |
