#1701 |
HOW long until spring??
![]() Join Date: Mar 2009
Re: Daverods project 66
I drilled and welded a 1/2 I.D. pipe through my crossmember before installing it to use as a E-brake anchor point and fabbed up the rest of the E-brake parts
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
#1702 |
SSN 706
That looks just like my cross member. Have you put a level on your carb to see if it's level? With 2 shims my carbs close to level and my trans is at 5.5*. I'm going to get a couple more shims today.
Went to the junk yard no shims. ![]() ![]() ![]() ![]() -2 on the 64's rear end. I'm thinking thats as low as you can go with static stuff.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 05-21-2010 at 01:16 PM. |
#1703 |
My magnetic angle finder (like yours) is on my service truck at work, I will bring it home Monday and check angles.
Just a rough once-over tonight with a torpedo level shows that my engine is lower in the rear.It is hard to say how much at this time. I had to measure off the valve cover of the inline 6 cylinder as the carb is 1 barrel monojet right now and too small to balance the level. My driveway has a negative fall , the bed of the truck is removed and new rear springs and tires have it tail high right now. taking all that in-- it still looks lower to the rear of the motor.
#1704 | |
SSN 706
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 05-21-2010 at 10:17 PM. |
#1705 |
How does the carb stay level when you are playing with the the bags and doing wheel hops or one side down and one side up????
seriously i think the driveline yolk angle is all you need to watch.. the drive line needs to be offset or angled . Anything but spinning true and straight yoke to yoke. the U-joints will not last long. There are several threads on here about driveline angles
#1706 | |
SSN 706
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 05-21-2010 at 11:25 PM. |
#1707 |
there some special yokes available for off road aplications that can still operate under extreme angles maibe thats an idea
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#1708 |
Member of the longbed union.
Looking good Dave.
For the angle of the dangles he's the ? you need to ask. Are you running a 1 or 2 peice driveshaft? If a 1 peice. The trans needs to sit at 3* Down and the Pinion on the diff needs to be at 3* up. With that being said you man run into problems running your exhaust with your crossmember if you move it up. If you just shim it up you'll be fine. You may have to cut the trans tunnel up a little more not sure since the trans is going to be sitting higher up now. I cant really tell you about a 2 peice drive shaft. If you dont want to shim it up then you can run a CV joint off the trans that will give the drive shaft more flex and take out the vibration of not having the correct angles. All this info is coming from Jason and Nate, so you can ask more queistions about it. Also take a look at my thread or Creeps and you'll find that info on there from Nate.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#1709 |
SSN 706
I'm doing a two piece.
#1710 |
If I'm not wrong either Bazooka or Creep is doing a 2 peice so I would check with them. or even PM Nate he's always willing to help.
#1711 |
SSN 706
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 05-23-2010 at 10:35 AM. |
#1712 |
One day...
#1713 |
SSN 706
Sometimes I really wish I had air tools. Someday.
#1714 | |
SSN 706
#1715 | |
One day...
#1716 |
Geez Dave If we split the cost of the tools it would not be too bad .. the killer part would be the 300 miles of air line we would need to share stuff .
I hope you did not Jinx my compressor.......... it started making strange noises today and seemed to take a long time to reach pressure..kinda sounded like the valves might be going bad . It has every right to quit... it is an old Montgomery -Wards working on it's second tank. The first tank finally rusted out ![]()
#1717 |
SSN 706
Put a new filter and seal on my transmission. Bought a new flex plate.
#1718 |
SSN 706
#1719 |
One day...
Holy crap what did you pull out of there its guts??
#1720 |
SSN 706
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 05-23-2010 at 11:54 PM. |
#1721 |
One day...
![]() ![]() Was it the bushing in the pump? |
#1722 |
SSN 706
Easy fix or not so easy.
#1723 |
One day...
if its the bushing you just need to find something to drive it in there without kinking it but if it something more then im not sure.. ill look at one of my trannys at the shop and see what you pulled out
#1724 |
looks like you just pulled the guts of the seal out. Go get another one and put it in.
#1725 |
check the converter too maibe it has a groove in it causing the new seal to get ripped too ....... there sleeves available to repair that
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 05-24-2010 at 07:27 PM. |
