Closed Thread
Old 08-21-2010, 11:18 AM   #1701
GMC91
Always trouble
GMC91's Avatar
Re: Finally "Silvers" build thread!! ('78 swb 2wd silverado)
Dennis, I envy the patience you have. Your truck is bad@ss...
91 Silverado Regular cab, 2wd, swb-project truck
97 Silverado Extended cab, 2wd, swb-driver
GMC91 is offline
Old 08-21-2010, 11:21 AM   #1702
nlped
nlped's Avatar
Cool, I couldn't really tell from the picture. I'm really jealous of how great this thing is coming together!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Old 08-21-2010, 11:45 AM   #1703
joe231
joe231's Avatar
BEAUTIFUL!!!
when are you guys coming out here?
CHEVY ONLY
joe231 is offline
Old 08-21-2010, 01:12 PM   #1704
breeze85cten
What made you go with the RAAMat stuff instead of Dynamat? Im sure there isnt much difference in quality but just wondering. Also what did you use to roll it out so nicely on your floor. It looks great. I am going to be buying some soon as well for my c10. How much did it take?
breeze85cten is offline
Old 08-21-2010, 09:12 PM   #1705
menace121978
menace121978's Avatar
thanks guys!! i used a roll of bxt and a case of bxtII. looks like its going to be perfect amount. We used ALOT! doubling up through all the seams. We used a wall paper roller to get it smoothed out and believe it or not some water proof tape for pipes on all the seams. you can get it at wally world. be sure to get at least 2 rolls. the tape is made out of the same stuff the ram mat is made out of. as for going with ram mat... just google it! tons of info and high praise on the stuff
i got a lot done today! column in with all new hardware. all the parts blasted and painted. cowl cover blasted and painted. locker shift linkage (PAIN IN THE ASS) installed and goes into ALL gears also started on the wiring harness and finished installing the sending units for the ultra lite's!!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline
Old 08-21-2010, 09:13 PM   #1706
menace121978
more
"Dennis the Menace"
Old 08-21-2010, 09:15 PM   #1707
menace121978
more...
"Dennis the Menace"
Old 08-21-2010, 09:16 PM   #1708
menace121978
few more...
"Dennis the Menace"
Old 08-21-2010, 09:17 PM   #1709
menace121978
last ones
"Dennis the Menace"
Old 08-21-2010, 09:59 PM   #1710
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looks sick. Absolutely sick.
--Josh
STOCKISH is offline
Old 08-22-2010, 03:39 AM   #1711
54Caddy
GM Addicted
54Caddy's Avatar
the sound mat looks good.. Plan on doing mine soon with dynomat. Keep it up getting closer
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline
Old 08-22-2010, 12:11 PM   #1712
mcbassin
Still Learning
mcbassin's Avatar
Awesome progress! you are cooking now man!
mcbassin is offline
Old 08-23-2010, 09:51 AM   #1713
JohnC
JohnC's Avatar
Wow you got a lot done! Looks awesome man!
JohnC is offline
Old 08-23-2010, 11:40 AM   #1714
silvereagle07
silvereagle07's Avatar
Looks great man! Are you going to get a steering wheel to match the 225's (or at leat get close to it)?
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline
Old 08-23-2010, 03:33 PM   #1715
draggin86
draggin86's Avatar
maybe like this?
or
draggin86 is offline
Old 08-23-2010, 03:37 PM   #1716
68 TT
Still plays with trucks
68 TT's Avatar
Originally Posted by menace121978 View Post
tomorrow i'll get the column bolted in, steering shaft cut and in, mount the a/c vacuum canister somewhere in the cowl out of sight, and a few other odds and ends. then it will be on to the painless wiring harness and installing the gauges
btw, the raam mat bxt is a great product. adheres like no other!!! kind of a mess and sticks like heck but other wise very nice.
Looks great, nice progress.
Are you going to put down the Ensolite IUO material as well?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline
Old 08-23-2010, 03:50 PM   #1717
Puglia10
wow, awesome work....cant wait till mines at that point and now just a bare frame! mind me asking why the lokar linkage was such a PITA? any tips?
1979 c30 3+3 dually
1946 GMC
Puglia10 is offline
Old 08-23-2010, 04:15 PM   #1718
menace121978
thanks guys!!!! i'm happy about it
yes i'm pretty much being forced to by vvvv Mr. Baldwin there! i was going to go back to the original wheel that i had put away a few years back but....
Originally Posted by draggin86 View Post
maybe like this?
or
im really liking the bottom one!!! nice and clean
no, i've read that it holds moisture and i had just planned on going with factory insulation over custom open loop carpet. we will see though.
the rod for the linkage barely hit the brake booster brace on the firewall. then once i cleared that it was hitting on the o2 sensor that screws into the header collector. once i finally figured i couldn't get around the sensor i removed it then had to go back and forth with the adjustments (like 5+ different adjustment points) until finally it was dialed in and went from P R N OD D 2 1. just kicked my butt is all
"Dennis the Menace"
Old 08-24-2010, 08:19 AM   #1719
JohnC
JohnC's Avatar
Yeah that bottom steering wheel gets my vote too. It will look awesome in the truck.
JohnC is offline
Old 08-24-2010, 11:03 AM   #1720
silvereagle07
I like this wheel. Billet Specialties Chicayne.
Jeramy
'85 Chevy 4X4 SOLD
Old 08-27-2010, 04:49 PM   #1721
menace121978
thanks for that Jeramy! i like it just need to see if it comes wrapped in grey.
i got a little done today. modded the column shaft a little and got the new steering shaft all painted up and installed. also went to the driveline services shop and ordered a custom built 3 1/2" driveshaft! here's a few pics of the steering...
"Dennis the Menace"
Old 08-27-2010, 04:53 PM   #1722
menace121978
just need to get the driveshaft painted and installed, buy brake booster and master cylinder and m/c brake lines, bleed, run wiring harness', and test drive!! probably forgetting a few things though!
Btw, anyone have the brake booster vacuum adaptor for the intake part number?? i cant find it anywhere in my bookmarks.
"Dennis the Menace"
Old 08-27-2010, 05:33 PM   #1723
breeze85cten
I just made a list for my truck as well and its a page long and even after that I keep on thinking of about a million things i need to do after the list! its never ending.
Old 08-27-2010, 06:15 PM   #1724
LiveAnimals
LiveAnimals's Avatar
Want to take a brake and come swap out my column
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline
Old 08-27-2010, 09:34 PM   #1725
mcbassin
Still Learning
mcbassin's Avatar
Steering column looks great and functional!
Sorry I don't know the part number for the booster adapter (Bob where you at?).
What are you doing with the interior? all new too? Where are you getting the door panels, dash, etc.? Just curious how deep you are going with this monster? It's going to be too nice to drive man.....
thanks
mcbassin is offline
Closed Thread
