Old 01-27-2014, 11:36 AM   #1701
shearjs
shearjs's Avatar
Re: Chucks SWB Fleetside
The fuel door looks great. I threw around the idea of doing something similar to this but just couldn't stomach cutting a big hole in the side of a new bedside. Keep up the good work. Look forward to meeting you sometime around Nashville, and checking out this truck.
shearjs is offline   Reply With Quote
Old 01-27-2014, 08:11 PM   #1702
thelonerife
thelonerife's Avatar
Originally Posted by Gus350 View Post
Chuck what did you use to cut the hole out of the bedside with
Thanks Kevin
Kevin, I started using my 3'' air cutting tool but the discs but they weren't doing it fast enough so I broke out my old jigsaw w/a metal blade. (less heat this way too) I cut about an inch off of the blade so as to not hit the inner structure/wall of the bedside. It worked great. I used a dewalt battery operated sawzall to cut the door out of the trailblazer at the junk yard.
thelonerife is offline   Reply With Quote
Old 01-27-2014, 08:17 PM   #1703
thelonerife
Believe me I know exactly what you mean. I think I had that paper template on the bedside longer than it took me to cut it out of the Trailblazer. Once you start it isn't so bad, Its just getting started that is nerve racking..
Looking forward to seeing your truck too.
Old 01-28-2014, 10:30 PM   #1704
thelonerife
I welded some tonight on the gas door. I had a couple flat spots show up. I got them out but I still have more welding to do. I think part of it is that the metal is thinner than the original metal. Argh!
Old 01-29-2014, 12:53 PM   #1705
cubber
Keep at it, brother!
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 01-30-2014, 04:46 PM   #1706
JRANGER
JRANGER's Avatar
man you are just rocking out over there! Keep it up Chuck!
JRANGER is offline   Reply With Quote
Old 01-30-2014, 09:00 PM   #1707
thelonerife
Thanks guys. I had to work late but tomorrow I'm off and I'm gonna knock a dent in this mutha
Old 01-31-2014, 11:18 PM   #1708
thelonerife
I did get a little done today. I got the fuel door all welded in an the inner panel cut. I installed the filler tube too. I also cut the opening in the floor. I need to trim a little more of a radius around the tube then make a tube to hide it.
I finished welding up the hood and cut some holes in it. Then welded a little on the rocker.
Old 01-31-2014, 11:20 PM   #1709
thelonerife
Inner floor.
Old 01-31-2014, 11:22 PM   #1710
thelonerife
Hood and cowl fill panel. I'm gonna see if Rus will cut this with his plasma cutter.
Old 01-31-2014, 11:27 PM   #1711
thelonerife
I put some bolts in where the original seat was bolted in. Then cut the heads off. They'll be seam sealed later.
I also welded a little on the rocker.
Old 02-01-2014, 07:28 AM   #1712
Rusbuilt
Rusbuilt's Avatar
dude you are getting close!! And when you come up for the swap meet bring that piece and we can cut it!
Rusbuilt is offline   Reply With Quote
Old 02-01-2014, 09:43 AM   #1713
JRANGER
JRANGER's Avatar
sweet!! GJ When is this swap meet? What ya talking bouts?
Old 02-01-2014, 11:00 AM   #1714
thelonerife
Cool. I will. I got my pieces in for my Lincoln too. I just have to work on the plug now and get the gas nipple for the back of it.
Its tomorrow Jeff, at the fairgrounds.
Old 02-01-2014, 11:20 PM   #1715
thelonerife
Didn't get a whole lot done today. Got some metal for the filler tube in the bed and welded some more on the rocker. I took the back glass out w/the help of my boy. The rubber was super hard. I guess it was baked in the AZ sun. We took the hood outside and washed it out. There were a lot metal shavings in all the hidden areas.
I also went and got my taxes done so ''a fun day''
Old 02-02-2014, 12:36 AM   #1716
swamp rat
swamp rat's Avatar
Keep up the good work!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-02-2014, 09:27 PM   #1717
thelonerife
Rus cut my metal for me and I bought a couple parts at the swap meet. Other than that no progress. Had fun though. Super Bowl!
Old 02-02-2014, 09:27 PM   #1718
Rusbuilt
Rusbuilt's Avatar
Good times!
Old 02-04-2014, 11:00 PM   #1719
thelonerife
I got my rebuilt vent windows today from Roger Koop. They look awesome!
Old 02-04-2014, 11:38 PM   #1720
Bennett68C10
Bennett68C10's Avatar
Nice Chuck, I ordered a set from Roger too. Those look awesome.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 02-05-2014, 12:03 AM   #1721
coggonobrien
what do they run from roger and do you need to get him a core?
coggonobrien is offline   Reply With Quote
Old 02-05-2014, 12:04 AM   #1722
Rusbuilt
Rusbuilt's Avatar
dang those are sick!
Old 02-05-2014, 12:15 AM   #1723
thelonerife
Thanks, You will be pleased, I am.
I got these for 530 ish shipped. I offered to send mine for cores and he had enough.
They are nicer than I expected. Very happy with them.
Old 02-05-2014, 01:13 AM   #1724
sduckworth13
sduckworth13's Avatar
Those vents look real nice Chuck. I'm going to have him do mine when it comes time.
Scott
sduckworth13 is offline   Reply With Quote
Old 02-05-2014, 01:00 PM   #1725
cubber
Nice glass!
=MATTHEW
