Closed Thread
Old 02-21-2011, 01:34 AM   #1701
ItsRandy
ItsRandy's Avatar
Re: What did you do to your truck today!
I finished my front suspension on Saturday and put my motor and trans in on Sunday.
ItsRandy is offline
Old 02-21-2011, 03:37 AM   #1702
Cambons
pulled then last part of the rad out and flushed it hope to get the feul lines cleaned up if weather permits
Cambons is offline
Old 02-21-2011, 07:26 PM   #1703
(joey)
(joey)'s Avatar
Originally Posted by jakeblues652 View Post
(joey), do you have any idea what you are going to hide that in the dash with? and good luck with the wires. looks like you'll need it!!
not a problem.after spending a great amount of time laying on my back staring up under the 67 dash theres all kinds of hiding room.just have to build a bunch of brackets and get some good wire clamps.
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain)
http://67-72chevytrucks.com/vboard/s...d.php?t=434253
(joey) is offline
Old 02-21-2011, 07:30 PM   #1704
BearFlagRepublic
Added a new Antenna and ran wire for speakers today. Nothing too crazy but a major pain to take out the glovebox liner without ruining it.
69 Custom Camper C/20 - 2nd Owner truck with records from the very beginning. 350/350
BearFlagRepublic is offline
Old 02-21-2011, 07:33 PM   #1705
(joey)
(joey)'s Avatar
Originally Posted by AirSpeed View Post
You must be glad you won't be using all those wires! That would suck! Are you going to use steel to shape the area around the gauges or part of the Sierra dash?
its not so bad.wiring doesnt scare me haha.i am going to use steel and some fiberglass mat around the sierra dash pieces.i started to make a higher rise cap tonight to clear the harness plug that comes out of the top of the gauge.for below the gauges i have to mock up my newer steering column and shape around it.hers a couple pics from tonight.i will have more as i go in my build thread
(joey) is offline
Old 02-21-2011, 07:34 PM   #1706
NORMSCOLORADO
NORMSCOLORADO's Avatar
yesterday i got the 6.5 lined up and sitting in and now its time to go fab up some bracketry for the hyd clutch!
04 Chevy Colorado Z71 4X4
76 Chevy C-10 Custom Deluxe (sold)
67 Chevy C-30 1 Ton 9' stepper 6.5 Turbo Diesel
NORMSCOLORADO is offline
Old 02-21-2011, 09:00 PM   #1707
glider_6969
Got my hands on power brake booster, it cost me $0.00 just owe a favour to a friend. Tore it down and painted all the parts, here is the before pic, haven't taken the after pics yet.
68 Long stepper
My other ride ,,, 07 Streetglide..
glider_6969 is offline
Old 02-21-2011, 09:13 PM   #1708
67Slider
67Slider's Avatar
Used my 67 to jump start my 4 wheelers today. Then me and the boys tore up the back yard!
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 02-21-2011, 10:07 PM   #1709
Hubscrub
Cruzin
Hubscrub's Avatar
sanded and painted steering column parts
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline
Old 02-21-2011, 10:24 PM   #1710
kcsa75
kcsa75's Avatar
I installed my tach that I've had sitting on the shelf for three months!
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline
Old 02-21-2011, 10:26 PM   #1711
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
sounds like fun 67slider!
I attempted to install my junkyard hitch, realized im going to have to drill some holes, I'll mess with it this weekend.
John
1999 Toyota Tacoma 4x4
oldblue1968chevy is offline
Old 02-21-2011, 11:40 PM   #1712
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Son and I gave up on trying to use the angle grinder with wire brush to get rust off...too many places are hard to get to. So, we decided to get it sandblasted. Then, we started pulling the front end off, so we can get as much of it blasted as possible. Still gotta pull the lower control arms/shafts, then the crossmember. Next week, we're gonna finish that part, then pull the rear end/trailing arm ass'y.
Member Nr. 2770
ChevLoRay is offline
Old 02-22-2011, 11:26 AM   #1713
Keller
Keller's Avatar
did a rear brake overhaul this weekend and finally ended the sqeaking! coming up this week is a new radiator, installing an overflow tank, transmission fluid/filter change and a distributor overhaul. i love having a box of parts just waiting to be put on.
Keller is offline
Old 02-22-2011, 01:56 PM   #1714
1quik70
Drove it to work and back, then changed the oil and a header gasket. First time in awhile I could even get a vehicle in my shop!
Don't make fun of my dirty little truck, it is my Daily Driver!!!
1quik70 is offline
Old 02-23-2011, 06:07 PM   #1715
stich626
Here is the factory set up
Cut the holes in the lower four and center upper to fit the Autometer 2 1/16th" gauges
Added a little paint
The speedo and tach backing clamps ,where a tad to short for the sheet metal backing panel so,, I added a little RTV and waa la
The autometer 2 1/16th" gauges fit the lower four spots in the factory panel like they are born there
The factory panel had the highbeam light in a gauge so, had to add one,
sadly the hole is a little off center..
The speedo and tach fit the factory holes "almost" the factory rolled the metal edges, so to close up the hole a little, I unrolled the flange a little , and Waaa la..
The highbeam and turn signal lights are l.e.d.
and the finished panel , only thing missing is the upper three gauges glass,
that is being buffed, then I'll install and have a better pic of the finished product..
stich626 is offline
Old 02-23-2011, 06:13 PM   #1716
bigdogboxers
bigdogboxers's Avatar
snow snow and more snow.... bought a tranny filter and gasket kit but 31 degrees is just a little to cold for a concrete floor with no heater.
bigdogboxers is offline
Old 02-23-2011, 06:25 PM   #1717
shawno72
C/10 junkie
shawno72's Avatar
I installed a new chrome rear bumper.
Before
After
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline
Old 02-23-2011, 07:01 PM   #1718
barry h.
barry h.'s Avatar
Great job using the parts you already had.i have done the same thing on a elcamino cluster
barry h. is offline
Old 02-23-2011, 09:36 PM   #1719
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Originally Posted by 67Slider View Post
I hear ya. Finished my fronts this morning too. PITA!!! Rears will be next month when the funds are a little better.
Ugg! Finished the driver's side rear last week. Haven't been back for the passenger's rear. Gotta do it....Maybe tomorrow. Thank the Heavens for the disks up front.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 02-23-2011, 09:56 PM   #1720
pryorstemmed
4wd Enthusiast
pryorstemmed's Avatar
Warmed it up, adjusted the idle and hauled some firewood again!
*1972 Cheyenne Super SWB K10 Original Paint 350/350 AC (Added) Tach/Tilt
*1972 Cheyenne Super SWB K10-Buckets/Tach/Tilt/Wood Bed/Manual Throttle/Marker Lamps
*1972 Cheyenne Super Custom Camper K20 AC/Tilt/Aux Tank/Aux Battery/Wood Bed
*1970 Olds 442 W-30 M-21 4-speed
*1978 Ford F250 4x4 Ranger-Explorer-Camper Special Marti Report: 1 of 1
*1986 K30 Silverado Crew Cab 502/TH400
*2002 Silverado LT 2500 Duramax Long bed Crew Cab 4x4 107K original miles
*2022 RAM Bighorn 1500 Waldoch edition ...Daily Driver
pryorstemmed is offline
Old 02-23-2011, 10:29 PM   #1721
darkolive71
Installed 1 ton brake booster, cleaned and painted the brackets and booster, replaced a wheel cylinder, and bled brakes. It stops alot better now!
darkolive71 is offline
Old 02-23-2011, 10:55 PM   #1722
bollybib
bollybib's Avatar
I reassembled and installed the passenger side rear wheel hub/drum and axle. I removed the differential cover, drained the oil (yuck), and cleaned the cover, attaching hardware, and gasket surfaces. I counted 41 teeth on the ring gear and I didn't see any obvious damage.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline
Old 02-24-2011, 12:29 AM   #1723
Jeffs70
Jeffs70's Avatar
Finished up fiberglassing my center console. Tomorrow I will be putting a layer of fiberglass bondo on it to smooth it out to the shape I am looking for.
Also did some work on my Radiator/Support Cover. The Primer is still a bit wet. but this gives you an idea of what it will look like.
Jeffs70 is offline
Old 02-24-2011, 02:07 AM   #1724
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
I finally got an opportunity to drive it in the snow.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline
Old 02-24-2011, 03:56 AM   #1725
wwotr
wwotr's Avatar
Went and saw it at the shop, and after 6 weeks, the Interior Renovation is almost complete!!!!!!!!!!!!!!!!!!!!
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline
Closed Thread
