07-03-2023, 08:02 AM | #1701 |
Post Whore
Re: My Dusty 71 GMCe Electruck
07-03-2023, 08:26 AM | #1702 |
Post Whore
can you guess which grommet I needed ?
07-03-2023, 08:28 AM | #1703 |
Post Whore
so my local Harbor Freight claimed to have a box in stock
you can't make this stuff up folks ! |
07-03-2023, 08:29 AM | #1704 |
Post Whore
five stores later...
07-03-2023, 08:30 AM | #1705 |
Post Whore
anybody wanna 179 piece grommet set, never been raced !
07-03-2023, 06:36 PM | #1706 |
Could you please give info on the 3 hole device on page 1656? What are its functions and dimensions, etc? Thanks
07-03-2023, 06:49 PM | #1707 |
Post Whore
aha yes the Dual QC3.0 Cigarette Lighter Socket Splitter, USB Car Charger Socket Panel Switch 250W Waterproof 12V Dual USB Charger Power Adapter Outlet with Aluminum Shell for Car Boat Marine, or as I like to call it: The Hole Filler
07-03-2023, 11:19 PM | #1708 | |
cool project, keep after it Last edited by coldrider; 07-03-2023 at 11:25 PM. |
07-04-2023, 12:54 AM | #1709 |
Thanks, Ski
07-04-2023, 09:04 AM | #1710 |
Post Whore
tell me you luv wiring without telling me you love wiring
07-04-2023, 09:10 AM | #1711 |
Looks like you could use that broken Craftsman for a turn signal stalk.
07-04-2023, 10:38 AM | #1712 | |
Post Whore
says WW Super 270 Win on it |
07-04-2023, 10:35 PM | #1713 | |
Post Whore
but if you are in the mood for knowing a bit more about the batteries that will power this beast, I just uploaded this new video and it is pretty down to earth BMW 530e HV Battery Safety Box Control think of each battery like a 9 gallon fuel tank, and I have two of them, the MPG for EVs is guestimated using 3.5 mpg so about 30 mile range per pack, and my original plan was to run three packs for a range close to 100 miles however I have recently heard it's more like 4.5 mpg so closer to 40 miles per pack, we can only build, test, and see for ourselves |
07-04-2023, 10:51 PM | #1714 |
Post Whore
I don't know how you all do your wiring, but I don't do anything without my trusty hack saw
on a bit more serious note, repurposing the stock TOYOTA / Lexus OEM relay sockets is a bit of a PIA as there are 4 pin relays, 5 pin relays and umpteenth pin relays, plus some relays served multiple purposes, think rear window wiper and radiator fan type of deal so as much as I wanted to have them consolidated and nicely mounted together, I only want to use 4 pin relays that are all the same style (not rating) for the oil pump, water pump, steering motor, and eventually iBooster Why not use aftermarket sockets? Well I ordered some ( R95-160A ) but I am pretty sure they won't come with these really nice heavy duty 8 AWG wires like the stock ones do and the super wide 10mm blades |
07-05-2023, 08:15 AM | #1715 |
Nice work!
For those heavy duty relays you should get the bare terminals and the crimper to match, then you can make the connections with whatever gauge wire you want. Something like this: https://www.summitracing.com/parts/p...iABEgK03vD_BwE Here's a relay with pins https://vetco.net/products/4-pin-aut...t-high-current I can't find just the pins, but we have them at work so I know they're available.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
07-05-2023, 10:41 AM | #1716 | |
Post Whore
thanks, sound advice, 100% on the bare terminals, and having done a few LS Swaps my collection of crimper thingies grows... and this doesn't even include the 50 Cal that lives in the garage, ha ha my only concern is the gauge ie thickness of wire the aftermarket relay sockets and terminals support, it seems like the OEM wire is as large as 8 AWG and that is the thickness of your girl friends pinky (back when she was in high school, lol) here is a properly prepped OEM four pin / four wire relay (as god intended) this one I would say only runs 10 AWG wires (hence the yellow manual calculator for reference) Last edited by Gregski; 07-05-2023 at 10:49 AM. |
07-05-2023, 10:54 AM | #1717 |
Post Whore
it's always a good sign when you get to the Ignition Switch install on your build, am I right fellas?
looks like, she's seen better days has sum of that patriotic Statue of Liberty tint to her |
07-05-2023, 11:57 AM | #1718 |
Post Whore
meanwhile on this episode of You Can't Make This Stuff Up ! YCMTSU
OUR throttle bracket is making it's way from California to California via Texas, and you wonder why this build is taking so long, well actually it drove by my house on it's way to Texas... I'm looking at you Robert !!! did you have anything to do with this? |
07-05-2023, 02:36 PM | #1719 |
I wanted to tweak it so it would fit.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
07-05-2023, 11:36 PM | #1720 |
Post Whore
07-05-2023, 11:40 PM | #1721 |
Post Whore
so while our BMW throttle pedal bracket is on tour opening up for Guns N Roses we decided to keep busy, so let's put this stock OEM wire harness back in, how hard could it be?
07-05-2023, 11:50 PM | #1722 |
Post Whore
honestly there aint that much to it, i've deleted the, radio, and factory AC and heater connections, so all we have left is
dang it I put it all away when I heard the ol' lady pull up in the driveway and forgot to take some final pics with all the gizmos laid out (heater controls, wiper motor, dome light, etc.) |
07-07-2023, 12:32 AM | #1723 |
Post Whore
sometimes you just have to hunker down and do some adult stuff
07-07-2023, 01:05 AM | #1724 |
Post Whore
I was super productive today, installed this parking brake cable grommet all by myself, is it a parking brake or an emergency brake, what do you all call it?
07-07-2023, 07:52 AM | #1725 |
Hubcap looks nice (straighten that bowtie). Kinda chuckled seeing the firing order on the 2x4. Years down the road that will be seen as some sort of "EV hieroglyphics".
