#151 |
I'm just glad to be here!
Re: 84 with a Dropmember
Updates??
Also, could the rear kit be used to convert a Long Wheel Base frame to short wheelbase? I know that most take about 12" out of the straight section in the frame just past the cab, but why not use this bolt in kit to do the same thing, just use a different set of holes to locate it with? Just an idea that popped in my head... ![]()
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#152 |
to convert it to a shortbed you need to shorten part in the front and part in the back of the axle , but i think it can be done too .
i'm just not sure if the bed will line up to the holes in the frame
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#153 |
Here are a few more pics of the truck.
Those planning on running the Dropmember Rear kit and the fuel cell from Performance Online... You will need to raise the tank, I would recommend 2" if you plan on laying frame. There is maybe 1/2" of ground clearance when aired out... too close for comfort.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#154 |
![]() Join Date: Dec 2006
hey nate how much taller is that notch then mine chris
bagged 87 |
#155 |
This one is 2" deeper than yours... you'll be fine with the Performance Online tank in it's normal mounting position.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! Last edited by PBFAB.COM; 09-24-2008 at 10:34 PM. |
#156 |
thanks , what kind of cv joint are you refering to in the in.ts
bagged 87 |
#157 |
It's called a "Cardon Joint" or "CV Joint". It goes on the front side of the driveshaft and prevents the driveshaft from binding at full dump, it also cancels out the driveshaft vibrations. I will see if I can dig up a pic for reference.
#158 |
can i get it at oreillys or autozone
bagged 87 |
#159 |
I don't think so... but you can ask. I have had a couple other customers in the mid-west who have had difficulty finding a company to make their driveshaft with the CV. I even called the local driveshaft shop in OK for a customer trying to explain what I was needed. It was an interesting conversation! I was told it was impossible to do what I was suggesting... not a safety issue, just IMPOSSIBLE! I told him about the shop here that makes them all day long... he told me to have them build it and then hung up on me!
I have a place here in town that I call... they pick it up and bring it back same day. I can source the joint for you, or even a driveshaft no problem, but need to know what trans you are running, and a measurement from the seal face on the trans output shaft to the center-line of the differential yolk where the u-joint cap fits in place.
#160 |
Go to post #74 here: http://67-72chevytrucks.com/vboard/s...=211503&page=3
There's a good pic of the joint.
#161 | |
#162 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Nate, I am thinking you are talking about a double cardan joint. Looks like this. Lots of 4x4 owners use it.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#163 | |
I knew they were common in the 4x4 world.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! Last edited by PBFAB.COM; 09-24-2008 at 11:34 PM. |
#164 |
Happy to be here
![]() Join Date: Mar 2000
Tell em you want a wiggler joint then they will understand...;0)
#165 |
the joint they where probably thinking about was one thats commonly used on a frontwheeldrive car the ones with the balls in them , and yes those are impossible to use as they can't take the power , they would be nice joints though if they made them big enough
#166 |
I have worked on several 98-newer s-10 extended cabs that have those jounts factory.Yes, that joint is just like the front shaft on a 4 wheel drive.
#167 |
It'd be alot cooler if you did
So I'm assuming this "wiggler" is something all of us guys who are bagged should invest in?
#168 |
If you have a SEVERE drop, it would eliminate u-joint binding at extreme angles. So yeah.
#169 |
Can I get a price for an 84'???? Oh yeah, will I be able to utilize this on a Crew Cab?
#170 |
PM sent.
#171 |
This truck was stolen last week in Mesa, Arizona. If anybody has any information PLEASE contact me.
#172 |
chevy truck fan
nathan,
does it still look pretty close to the the pics above?? i live in chandler & will keep an eye out for you!! good luck!! |
#173 |
I am in Chandler as well. I saw it a couple months back driving in Gilbert at the Power Ranch park. Ill be sure to keep an eye out.
#174 |
Nathan, You do top notch work and I've been watching all your builds. I want one of your dropmembers when I get the funds to do it. Seeing that this truck is stolen is awful! With these boardmembers and the internet, i would think that this truck would stand out, or the parts from this truck. Do you put a serial number on your parts? If you don't, it might be good if you can to log a serial number and who it was sold to. I'll keep an eye out up here in N.C. There's car shows coming up, and with that truck, its bound to show up somewhere. Thats one bad truck and nobody's going to part it out and not show the truck, or its parts. I'll keep watching my local craigslist and car shows for any info on this. Best of luck getting this back.
#175 |
truck addict
hey just dont confuse it with my 87 longbed...lol... in the next few months mine will have them parts on it.. but im a few states up so doubt it will be up this way
trucks |
