#151 |
Questionable
Re: Calling all LS1 converted trucks.
looking at all of the S&P crap on there, yes, they probably have 10k in the drivetrain alone.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#152 |
Junior Member
Don't give up, the biggest part for me was just getting started. You just have to pick one task at a time and get it done and move on to the next.
Happy wrenching Bill ![]() ![]() ![]()
1972 K/5 4x4, Radixed LS1 6.0, 428HP/445TQ, Lingenfelter GT2-3 cam, WCCH 90mm J-Tube, LS2 90mm TB, Stainless Works Headers, NV4500, 4.56 gears, Detroit Lockers, 14 bolt FF, Dana 60, 4 wheel disk Hydro Brakes, dual electric fans, Autometer guages, 4" lift, Zero Rates, Weld Evo Velocity XT8 wheels, 35x12.5x17 Super Swamper SSR's..... http://s72.photobucket.com/albums/i1...tos/?start=all |
#153 |
Questionable
hey billyjo - what headers did you go with? did you need to notch the frame to use em? sorry if i've asked this before.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 08-30-2007 at 11:58 PM. |
#154 |
A guy with a truck
He's running the Stainless Works f-body headers, I believe. That Blazer is 4wd using plate style mounts IIRC, so fitment will be different than your truck...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#155 |
![]() Join Date: Nov 2001
So, how does the 8.1L fit into all this... what is it, a LS, LQ, 1, 2... What?
Do you think I should talk my boss outta the 8.1L sitting in our shop? We bought a 8.1L w/ allison out of a 2002 2wd 3/4T suburban. Our plan is to put it into his motorhome (replace the 366 gas motor, Junk) we got the wiring redone by a Jims Performance (very reasonable price) So it's very ready to go, but we haven't started the project yet... Maybe I could talk him into putting it in my '68 with a different trans behind it. So, DOES ANYBODY WANNA BUY A ALLISON??? oooohh, he would kill me, then fire me...
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
#156 | |
Junior Member
Gringoloco is right about me using the SW headers, the plate mounts and the 4WD being differen't. I also had to cut the collectors off and shorten them about 4" so that the connections weren't behind my crossmember and they are still about 3" lower than I would like. If I had to do it over I think I would've made my own headers or had someone make them for me. It's really the only part of my conversion that I'm unhappy with. If they were 3" shorter (height wise) I wouldn't have to offset my exhaust pipe over the top of my cv joint on the front of my transfer case. Bill
#157 | |
![]() Join Date: Apr 2005
I want me one of those! ![]()
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#158 | |
68 lwb to swb Cummins swap in the works. I promise it will be cool someday. |
#159 | |
Parts and more parts
It was priced at $10K (which is what I could have purchased it for--the wife out gunned me that day) and about a year later someone unknowingly offered the guy around $16 and won the truck. The motor and the tranny would cost a person right at $9K if you bought it all new at S&P. The guy that owned it, did polishing work at the S&P shop to pay off the goodies and the motor. I would not call all of the S&P stuff crap, but if you want just a running drivetrain, then they can sell expensive stuff, however, I personally like some of their "BLING". If I am oging to build a runner--it will shine, too. When I drove it, it had minimal brakes but the Kick A$$ part was well oiled and working fine. I calculated what I could do the same type of install for, by using a good used motor and tranny, I feel that I will get mine together for about half of the price for the install. I am looking at using a long tube header set, instead of the shorties that S&P sells. By the way the headers on that truck are the Prototypes for their shorty series that they now sell (the first set built for this style of trucks). The tranny in that truck is a new 4L60E with the adaptor to give it a manual speedo capability, along with the computer input connection. Last edited by piecesparts; 08-31-2007 at 04:42 PM. |
#160 |
Questionable
oh i didn't mean crap as in "sh*tty" i meant crap as in "stuff"
#161 | |
#162 |
What are you guys using for a throttle cable? I am using my 72 pedal but what cable do I need? Thanks
#163 |
A guy with a truck
Use the stock LS1 cable
#164 |
#165 |
Junior Member
Wish I could help but mine is DBW
#166 |
Questionable
I went with a lokar cable. a stock truck cable (99-05 silverado) would have worked using 71-72 pedal, maybe some shortening and a new cable stop, but ...
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 09-11-2007 at 05:16 PM. |
#167 |
I've now owned 4 cars with LS1s in them, just bought a 05 pickup with the 5.3L tonight so I've been "studying" the genIII engines for about 7 years.
I also just made a deal for a 5.3L for my 68 project truck. The goal is 400 RWHP, but it looks like for the 5.3L that is a bit of a stretch, so I'll probably do some bolt ons and a small shot of nitrous (~50HP) to get me there. I'll be running an auto tranny (not sure which one) along with 4.10 gears (just cause I have one with that gearing) The 5.3L I'm getting for the truck doesn't have an intake, wiring, TB, ECM, or MAF. I did however find 2 harnesses and an ECM tonight that I already bought (one harness is for a 4L80E, the other 4L60E). So now I just need a TB, intake, and MAF...oh and tranny. Shouldn't be hard finding this stuff though. Once I get all the pieces, I'll update my build thread. Time to go start reasearching wiring configurartions! |
#168 |
Edited by moderator
XIV. As of October 15th 2005 subscribing members will be the only ones permitted to post for sale and want to buy ads on any classified section of this site. All other rules of buying and selling still apply. 67-72chevytrucks.com, its administrators or staff are not responsible for any transactions on or off the forums. We will work hard to ensure you a smooth transaction, and help in the event you may need it, but all for sale and trade areas are buyer beware. Any persons who have misrepresented an item, lie about an item, fail to deliver, or are in violation of any of the rules will forfeit there subscription fees and be banned from 67-72chevytrucks.com
1972 Chevy C-10 Short Stepside 6Cyl, 3 spd, not opts (Current Project) Now a 2004 SSR 5.3L with 4L60E Now Ididit tilt- ps, pb 2002 Saturn L200 2006 Toyota Highlander HYBRID Last edited by centsless; 09-11-2007 at 05:42 PM. Reason: Rules violation |
#169 |
A guy with a truck
Not 100%- the truck cable will work.
#170 | |
#171 |
Please post all parts in the parts board.
Thanks Last edited by centsless; 09-11-2007 at 05:50 PM. Reason: for sale |
#172 | |
Oh, I'm using the stock tank for my TPI 350 in my 72 GMC, and when it gets low and I turn a corner the engine will hesitate....not the best setup, but it works. I'm using a fuel pump mounted to the frame for it.
Project Bruiser: 68 Pro-Touring C-10 5.3L / 4L60E Project Ironhide: 97 GMC Crew Cab 4x4 Cummins SOLD: '69 GMC 1/2T SWB TBI'd: Project No Buck Assembly Manual Index Sign up Thread!!! Factory Service Manual Index Last edited by centsless; 09-11-2007 at 05:52 PM. Reason: parts in quote |
#173 |
The ls style intakes look the best, I am running a ls1 for now but I will swap to a ls6 when I get the funds built back up.
#174 | |
68 lwb to swb Cummins swap in the works. I promise it will be cool someday. Last edited by centsless; 09-11-2007 at 05:53 PM. Reason: Parts in quote |
#175 |
maybe there should be a fuel injection or genIII subforum since there are so many of us going to this option, but have pretty specific questions about some of this stuff.
