Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 03-19-2008, 04:45 AM   #151
Rust Buster
Rust Buster's Avatar
Re: 72 K20 build thread, need good name
Well finally some decent progress.
I rebuilt the side cowl vents and drains. I built them to take 300 years to ever rust through again...
Completed the cab undercarriage metal work and laid down two coats of Southern Polyurethanes epoxy primer with my TP Tools turbine system. The stuff goes on great and that HVLP turbine system is an awesome alternative to compressed air and you don't have to worry at all about moisture.
Next is two coats of Durabak and then I can finish up the rest of the cab.
I picked up the 67 front clip that gtomechanic had for sale and an extra hood with a GMC core support. Jim and Jeff are great guys and they have an absolute treasure chest of parts, I'm extremely jealous.
Maj USAF
71 K5 Blazer CST
72 K20 HT383 NV4500 Mass-Flo EFI
71 K10 LWB
52 Dodge Power Wagon
67 Dodge WM300 Power Wagon
48 Dodge WDX Power Wagon
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=239487
Rust Buster is offline   Reply With Quote
Old 03-19-2008, 06:20 AM   #152
arkracing
Weekend Warrior
Don't know how I missed this build. Looks very cool! I just read through all of it.
Where did you get the stock replacement springs? I see LMC carries them, but they are super expensive.
Why did you run weld the cab supports to the floor solid like that? instead of doing a factory type spot weld. If you have the truck long enough for them ever to be replaced again, I would imagine that it will be quite a job to cut them back off
How do you like the Southern Poly Epoxy Primer? Does anybody else you know use it or have experience with it? I was contemplating buying some, but it isn't too popular like "DP90"
Looks like it will be an awesome 4x4 when done.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 03-19-2008, 06:26 AM   #153
Rust Buster
Thanks for the compliments. The epoxy primer is awesome, and when it is cured it actually sands really well. I did a lot of research before I bought it, and haven't ran across anyone who says anything bad about it.
Welding the bracing on the undercarriage was for two reasons... 1. to seal up any crevices so there were minimal areas for rust to collect, and two just because I could and I was having a rare moment of welding zen where I was laying done some really nice beads. I don't plan on ever replacing them, this truck is a lifer and I'm going to stay on top of the rust if it ever comes back.
The springs I got from a local spring shop. I think they are expensive no matter where you get them.
-Tim
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 03-19-2008, 06:36 AM   #154
arkracing
Weekend Warrior
-Tim
What did they cost you if you don't mind?
-'66 C10 Suburban
Old 03-19-2008, 06:48 AM   #155
Rust Buster
I think they were about $150 a piece, but it's been a while, so I'm not 100% sure.
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 03-19-2008, 07:44 AM   #156
msgross
msgross's Avatar
just looked up the specs on your tp paint system. Is that the 90? cost about 600 or so? Looks nice, if you decide to sell it when your build is done let me know, I might be getting around to primer by then! Also, what size welder are you running?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-19-2008, 03:16 PM   #157
Rust Buster
I'm running a Millermatic 180, a great welder for my needs
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 03-21-2008, 05:12 AM   #158
Rust Buster
I let the Epoxy cure for a day and then brushed on the first coat of Durabak to make sure I got it in all the nooks and crannies. This is good stuff!! Just make sure you have a good respirator, it's definitely not good for the lungs. Then the next day I sprayed a good coat of Durabak to get a nice texture. I got some great coverage and I think with one more coat I will be happy and the undercarriage will be done.
This stuff is really thick, has the ground-up tires pieces in it and it sticks like nothing I've seen. If this truck ever rusts again under there, it won't be in my lifetime (knock on wood). Not the best pictures, but it's all I could get. I got the dark gray just to provide some contrast and it might allow me to spot any rust that starts quicker.
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 03-21-2008, 06:01 AM   #159
watahyahknow
watahyahknow's Avatar
hmmm that durabak stuff seems like a good alternative to do my truck with , i can aply it myself wish is nice cause we dont have a lot of people here who do spray in bedliner here in the netherlands europe , it seems cheap too and i can order it on the net ........ you used a spraygun , wat kind ? i can immagine you need a big nozzle on it to spray this stuff , they only discribe rolling the material on there website
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-21-2008, 06:04 AM   #160
Rust Buster
I used the economy undercoating gun from TPtools.com
It was about $30 and worked pretty well. It did clog a couple of times, but all it took was me clearing it by putting my finger over the nozzle and squeezing the trigger to flush it out, then it worked fine.
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 04-02-2008, 12:40 AM   #161
Yukon Jack
Yukon Jack's Avatar
Been way too long since I visited this post - you've come a long way. Very nice craftsmanship!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-09-2008, 07:08 AM   #162
72blazer_mud_bogger
72blazer_mud_bogger's Avatar
where are you in va
72blazer_mud_bogger is offline   Reply With Quote
Old 04-09-2008, 03:18 PM   #163
Rust Buster
I'm in Chantilly
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 04-21-2008, 06:41 AM   #164
RICHARD MORGAN
Wow! What a great build. I'm actually right down the road from you in Ashburn. I'm also Active duty Military (Navy) and currently starting my own project, a 1972 Chevy 4x4.
Richard
RICHARD MORGAN is offline   Reply With Quote
Old 04-21-2008, 04:55 PM   #165
Rust Buster
Hey Neighbor! This could be fun...
Do you work in the blue building as well?
I want to see some pictures of your truck!!
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 04-23-2008, 02:24 AM   #166
Rust Buster
With the undercoating done, I was able to put two coats of epoxy primer on the entire cab, inside and out. The SPI primers are great, and the epoxy sands really well.
With that done, I started putting down some Rage Gold filler. Great product but a little tough to sand. While that was drying, I bought and installed a GM Performance Parts wire loom with some MSD 8.5 mm plug wires. It's the first engine I've ever had with where the spark plug wires are organized! I am very happy that it worked well with the Doug Thorley headers.
While all that was happening the friendly UPS man brought some cool goodies including an Ididit tilt steering column, a used front swaybar and mounts from a 76 4x4, and a complete A/C system from Old Air Products.
The goal has been to get the interior primed and all set with filler so that I can paint it a dark grey. Now I know how many of you feel about cutting these dashes, so some of the photos may not be for the faint of heart. I'm putting an Alpine IVA-w505 head unit in the dash and it is a double din size. I respect the opinion about keeping these trucks as original as possible, but this truck is hardly original anymore, and I plan on keeping this forever and this is what I want. I do have something in mind that will pay homage to the original look that I haven't seen anywhere yet, so stay tuned.
So with that, the dash was cut...
I am still working the filler, and used Rage Extreme this time. Wow that stuff is great. Flows awesome and no pinholes! Also made the ignition module hole smaller because I am using a push-button ignition.
More pics as I go...
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 04-23-2008, 02:25 AM   #167
Rust Buster
Some more
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 04-23-2008, 03:43 AM   #168
RICHARD MORGAN
Great work neighbor! We need to get together this week and check out each others projects. Give me a call 571-277-0973
Richard
Old 04-23-2008, 04:08 AM   #169
RICHARD MORGAN
Here’s some pics of my project in various stages:
http://s281.photobucket.com/albums/k...LUE/?start=all
It looks allot different now. I've installed Dakota digital gauges, a new front clip, cowl hood, etc...right now I’m in the process of installing a Painless wiring harness.
Richard
Old 04-23-2008, 06:08 AM   #170
84 400
Sb 400 club
84 400's Avatar
Great job! that truck is loads cleaner then any back here!!!
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 04-23-2008, 06:13 AM   #171
Rust Buster
84 400,
It was there for almost a year. I grew up in Princeton, MA, but got stationed down here with the Air Force. I definitely miss New England and hope to get back there soon. Just watched the Bruins lose game 7, and I'm now in a bad mood...
Thanks for the compliment though!!
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 04-23-2008, 06:21 AM   #172
abebummy26
abebummy26's Avatar
where's the pics of your 71 k10?
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 04-23-2008, 06:40 AM   #173
trx450duner
trx450duner's Avatar
I really like your accesories brackets on the motor what are those off of or where did you get them from? The chassis looks really good your doing a nice job.
trx450duner is offline   Reply With Quote
Old 04-23-2008, 02:22 PM   #174
Rust Buster
Thanks trx450duner! It's off a camaro, and I bought it on ebay, then pieced together the accessories for it. It was a good deal at $125
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 04-24-2008, 02:43 AM   #175
RICHARD MORGAN
Tim,
What are you using to cut your sheetmetal?
Richard
