Old 01-26-2009, 04:08 PM   #151
joe231
joe231's Avatar
Re: 63 stepside SWB project
nope not a bolt-on
the front mounts are different....
I believe they are wider on the '60-'62
CHEVY ONLY
Old 01-26-2009, 04:21 PM   #152
1963chevyshort
New Member
1963chevyshort's Avatar
Darn so how much of an adjustment is it to make it fit. Is it that bad off?
Anthony
63 chevy stepside SWB
57 chevy 2dr hrdtop belair
1963chevyshort is offline   Reply With Quote
Old 01-26-2009, 04:23 PM   #153
joe231
joe231's Avatar
let me see if i can find the answer....
CHEVY ONLY
Old 01-26-2009, 04:33 PM   #154
scotts62
One day...
scotts62's Avatar
Answer..
Well mine on my 62 measure 51 1/2 center to center.
Scott
93 crew cab build
Project 62
Old 01-26-2009, 04:35 PM   #155
1963chevyshort
New Member
How about on bolt pattern. Like from front mount to front mount. I heard that the mount will line up different. Thanks Scotts62
Anthony
Old 01-26-2009, 04:41 PM   #156
scotts62
One day...
scotts62's Avatar
No problem.
That was front to front, you want me to measure all for you?
Scott
93 crew cab build
Project 62
Old 01-26-2009, 04:42 PM   #157
502tripower
502tripower's Avatar
Here is mine. A 62' Cab on a 63' Frame. I cut the cab mounts out of the 63 Frame and mounted them into the 62 Cab. Here are some pics. You have both Cabs there so it should be pretty self explained. You can see in the pics that the outboard mounts are the ones that were used for the 62' and the inboard ones are the relocated 63's With the bolts in. Good luck with you project.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 01-26-2009, 04:49 PM   #158
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: 63 stepside SWB project
I can look at my book when I get to the house, and see the cab mount bolt patterns on the frames. I am going to scan all the frame demensions/Specs on 1960-1966 pickups, and post a new post for everyone to see for guidance. They have the cab demisions as well.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 01-26-2009, 04:53 PM   #159
joe231
joe231's Avatar
Originally Posted by scotts62 View Post
Answer..
thanks Scott!!!
between Scott and I, we got the '60-'66 short wheel base covered, fleet and step
'63-'66 is 40 5/8" front mounts center to center... just measured our '66 cab that was bolted to our '63 frame.
i believe the rear mounts are the same....
nice pic 502!!!
CHEVY ONLY
Old 01-26-2009, 05:01 PM   #160
1963chevyshort
New Member
502tripower this is not bad info. So this still a salvagable way to go. Yeah it is kinda hard to find a nice 63 body. Kinda rare. This body is in really good condition.
1Bad62Pro/Street if you have that info that would be great. i will probably have to do what 502Tripower did to make it work.
I am going to post some pics tonight of the new cap and also some measurements. Thanks guys. it is time to get this project going again.
Anthony
Old 01-26-2009, 05:02 PM   #161
1963chevyshort
New Member
Scott I will do that when i get home. I will see if this will work right.
Anthony
Old 01-26-2009, 05:08 PM   #162
502tripower
The 61' Cab will go right on. You have both cabs so it should be a breeze. The cab supports are the same the only difference is the outboard location on the 60-62. Its a no brainer.
98' FXD
2002 2500HD
Old 01-26-2009, 05:17 PM   #163
1963chevyshort
New Member
Got it. I should be able to just swap both correct?
Anthony
Old 01-26-2009, 05:26 PM   #164
502tripower
If thats what you want to do. My 63' cab was ten times better then yours but that was also 12 years ago. I took what I wanted a scraped the rest. What I did was drill out the spot welds on the round cab mount inside the cab. Once that was off then I noticed there was a rolled tube inside the mount that would support the tourque of the cab bolt. I just cut some round tubing to do the same thing welded it all in and called it a day. If you are going to sell the rusty 63' cab by the time you cut the stuff out that you need you may find that for 300.00 you could spend your time working on your project more rewarding. JM2 cents.
98' FXD
2002 2500HD
Old 01-26-2009, 05:38 PM   #165
1963chevyshort
New Member
No i was going to sell the 63 cab for cheap. maybe someone may find a need for it. I am keeping the 61 body as you will see the shape it is in.
Anthony
Old 01-26-2009, 05:44 PM   #166
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Nice floor board!
Joey~AP is offline   Reply With Quote
Old 01-26-2009, 05:51 PM   #167
502tripower
Thanks, is original, with no rust, except for the mounts.
98' FXD
2002 2500HD
Old 01-26-2009, 06:01 PM   #168
1Bad62Pro/Street
Love the seats! What are they out of. That's what I been wanting in my Chemmy.
Old 01-26-2009, 06:56 PM   #169
1Bad62Pro/Street
Just scanned them! Will post them tomorrow!
Old 01-26-2009, 11:11 PM   #170
1963chevyshort
New Member
Pics of the new cab.
Anthony
Last edited by 1963chevyshort; 11-20-2013 at 03:53 PM. Reason: Pic location changed
Old 01-26-2009, 11:13 PM   #171
1963chevyshort
New Member
Anthony
Old 01-26-2009, 11:14 PM   #172
1963chevyshort
New Member
Anthony
Last edited by 1963chevyshort; 11-20-2013 at 03:57 PM. Reason: Pic location changed
Old 01-26-2009, 11:16 PM   #173
1963chevyshort
New Member
Anthony
Old 01-26-2009, 11:17 PM   #174
1963chevyshort
New Member
Anthony
Last edited by 1963chevyshort; 11-20-2013 at 04:00 PM. Reason: Picture link update
Old 01-26-2009, 11:18 PM   #175
1963chevyshort
New Member
Here are some pics of the 61 cab. It is in pretty decent shape
Anthony
