Old 02-02-2011, 01:29 PM   #151
cable666guy
cable666guy's Avatar
Re: BP68 Official Build Thread
That came out beautifully!!
cable666guy is offline   Reply With Quote
Old 04-19-2011, 04:45 PM   #152
BP68
BP68's Avatar
Been a while since I posted. Mostly been busy and saving up for parts. Snagged a set of 454 SS truck wheels last weekend, ordering front and rear bumpers this week. Savin up for tires now (plan to run 275/60r15 all around).
Will try to post up some pic soon, once I get her cleaned up.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 04-19-2011, 05:38 PM   #153
70_BBC
I love your truck. I can't wait to get home so I can get back to work on mine. One Day I hope to have it look as good as your's, very impressive truck.
70_BBC is offline   Reply With Quote
Old 06-04-2011, 10:40 PM   #154
BP68
BP68's Avatar
Test fit of my new wheels till I can save up for 20's
Also test fit of 275/60R15 Tire
03 Grand Prix GTP
Old 06-04-2011, 11:05 PM   #155
BP68
BP68's Avatar
Need opinions on tire size. I was planning 275/60r15 in a BFG Radial TA. The test tire in the pic is a Cooper Cobra. It almost seems a little taller that I was expecting compared to the same size bfg on my uncles truck.
Should I maybe be looking at a 255/60r15
The 275 bfgs on my uncles truck look/appear to have a shorter side wall and look perfect. The Coopers on my truck appear taller???????
03 Grand Prix GTP
Old 06-04-2011, 11:26 PM   #156
BP68
BP68's Avatar
I am thinking it may just be the sidewall design on the BFGs that make the diff. Here are same 454 ss wheels with the bfg 275/60r15 on a 98 with 4/6 drop (my 68 has a 4/6 drop also) and the have the look I want. The cooper test tire I have looks taller for some reason?
Thoughts/opinions anyone ?
03 Grand Prix GTP
Old 06-04-2011, 11:32 PM   #157
spike38
spike38's Avatar
I've had cooper cobras on a camaro. The traction was good,
But the wear rate was bad. I had to slam the brakes one day,
For a lady on a cell phone, And one of the tires separated down to the cords
So be careful
Spike
spike38 is offline   Reply With Quote
Old 06-05-2011, 11:25 AM   #158
BP68
BP68's Avatar
So be careful
Spike
Thanks for the heads up. But I wasn't going to run the Coopers. I am for sure getting BFGs, just need to decide size. The Cooper is worn out and for test fit only.
03 Grand Prix GTP
Old 06-05-2011, 02:16 PM   #159
BossHogg69
motor exploder
BossHogg69's Avatar
I thought the 275's all the way around looked good on your '68 - filled the wheelwell up nicely. The 255 BFG's might be a little short on all four corners with that drop, but might look good if you have 255's in front and the 275's in back. I guess it depends on the look you're after and how much being able to rotate your tires means to you. I had a '92 chevy xcab like the one pictured above, but with a 5/7 drop and I ran 235/60/15's in front and 295/50/15's in back and it sat perfect (to me, anyway). To me, with a 4/6 drop (or 5/7) on a GM half ton a 1/2" to 1" taller rear tire compared the the front gives a nice 'rubber rake' to the stance - not too much in the air, but just a tad more than level for a nice hot rod look. This is all just my humble opinion of course...
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 06-05-2011, 09:15 PM   #160
BP68
BP68's Avatar
Thanks for the input. I really prefer to run the same size front and rear, or at least same diameter with no rake. I am thinking the 275 BFGs will have the look I want. Something about the cooper just makes it look taller I think.
03 Grand Prix GTP
Old 06-06-2011, 04:01 PM   #161
68 TT
Still plays with trucks
68 TT's Avatar
I had a 90 454SS with the same tires. The 275/60-15 is 28" tall and has quite a bit of sidewall. Not the best for handling but they do OK. Not a high performance tire for sure though. The sidewall will flex over an inch to the side under heavy lateral load and rub if you don't have the clearance.
I would try for a little larger diameter wheel to knock that sidewall height down a bit if your wheel choice can be had in a bigger diameter. Even one or two inches larger rim diameter would make a big difference.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 06-06-2011, 07:54 PM   #162
gringoloco
A guy with a truck
gringoloco's Avatar
I think the wheels are temporary until bigger ones are in the budget...
A 275/60-15 works well out back, paired with a 255/60, 235/70, or 215/75 up front. All depends on wheel width and personal preference for the fronts. Truck looks good!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-08-2011, 02:11 PM   #163
BP68
BP68's Avatar
Thanks for the input all.
Yes these wheels are temporary. I eventually want to save up for 20x8.5 front and
20x10 rears. I just thought the chrome steel wheels looked a little better than the aluminum ones.
03 Grand Prix GTP
Old 06-08-2011, 09:00 PM   #164
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
What upper radiator hose did you use?
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 06-08-2011, 11:10 PM   #165
BP68
BP68's Avatar
I think I got the rad hoses from brotherstrucks.com or LMC
03 Grand Prix GTP
Old 09-01-2011, 09:52 PM   #166
BP68
BP68's Avatar
Hey all, been a while since I updated. I have had the truck at work doning a bunch of odds and ends. Leaking axle seal, two bad fuel pumps. Carb and timming setup/tuning. Little wiring.
If all goes well, I will drive her home tomorrow after work. Once I get her cleaned up I will post some current pics with the new wheels and BFG tires. Also working on some door panels and saving up for carpet and grille moldings.
Little by little getting closer.
03 Grand Prix GTP
Old 09-02-2011, 12:36 AM   #167
hgs_notes
GEARHEAD
hgs_notes's Avatar
There were a couple reasons why the test tire looked like it had a taller sidewall compared to the newer truck. First, you had a blackwall compared to a white letter showing, which changes the perspective. The green truck was also much higher with larger wheel openings, making the tires seem smaller and shorter sidewall. I used 235-70-15 up front and 275-60-15 in back on mine so the sidewall would be a close match. I just have a 3.5" static drop all around. I like the rake.
Good luck with the tuning, etc. Other than windows, grill, front lights and door assembly, that's pretty much where I'm at now also.
hgs_notes is offline   Reply With Quote
Old 09-02-2011, 09:23 PM   #168
BP68
BP68's Avatar
Attachment 795192
Attachment 795204
Attachment 795205
Attachment 795206
Attachment 795207Finally some progress pics!!!!
She made it home on her maiden voyage (not couting coming short distance home from bodymans house and some very short trips around town.
Got the leaking rear axle seal fixed, clean out axle tubes and installed new outer bearings. Wired up fuel pump realy and cooling fan relays are just about done. Got B&M lockup control hooked up for 700r4, carb dialed in nice and timing pretty close, may come down just a hair.
She ran good, never got hot, and did fine. Did a quick clean up at home tonight. Should be ordering carpet soon, working on door panesl now (pics to come)
Also, front bumper outer brackets did not quite fit and it sticks out too far on pass side. Gonna get my body guy to help me out with that this soon.
Enjoy
03 Grand Prix GTP
Old 09-02-2011, 09:36 PM   #169
VA72C10
VA72C10
VA72C10's Avatar
Looks really good! Maybe the wrong brackets for the bumper? Or they could be tweaked slightly....I've run across both issues in the past.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-02-2011, 10:59 PM   #170
BP68
BP68's Avatar
Yeah, not sure. Brackets are old and came with truck, but no bumper installed. They also did not come off this frame. They look right going by LMC catalog pic but bumper is repop and bracket is close. I would say when bolted to frame both brackets are out of line with the outer holes in bumper by abour 3/8 of an inch.
I think we maybe able to shorten them and get everything to work ok.
03 Grand Prix GTP
Old 09-02-2011, 11:22 PM   #171
67cheby
67cheby
67cheby's Avatar
Looks super clean and slick !!
67cheby is offline   Reply With Quote
Old 09-02-2011, 11:27 PM   #172
VA72C10
VA72C10
VA72C10's Avatar
do you have a picture of the brackets? I am thinking maybe they are 71-72 specific brackets....slightly different than the ones made for 67-70.
Old 09-03-2011, 11:44 AM   #173
68 TT
68 TT's Avatar
Truck looks great.
Glad she made it home safely.
Old 09-03-2011, 06:26 PM   #174
BP68
BP68's Avatar
Thanks for the kind words everybody. I will try to post a few more when I get some more cleaning done, especially under the hood.
03 Grand Prix GTP
Old 09-06-2011, 04:10 PM   #175
yawdie1
yawdie1's Avatar
the truck looks great! But what happened to the Boss wheels?
Here is a pic of my blazer. (Hope this works)
1950 chevy PU work in progress.
yawdie1 is offline   Reply With Quote
