Old 12-14-2009, 11:25 AM   #151
78-5.3
78-5.3's Avatar
Re: My camaro tach cluster-done!
Originally Posted by Jonboy View Post
Another dumb question. Using the electric speedo, it wires from teh VSS output to the original DRAC input (position #18 in the plug), right? I wired mine up, and the speedo went to 65 MPH when I turned on the key. The odometer seems to be working, but the needle doesn't move. Any ideas?
i intalled the speedo wire to ecm directed coz i used a 78 cluster!!!!
78-5.3 is offline   Reply With Quote
Old 01-07-2010, 12:45 PM   #152
68 TT
Still plays with trucks
68 TT's Avatar
Originally Posted by Jim85IROC View Post
Has anybody tried using the camaro speedo as well? Seems like it would make a better visual match, plus if you have a 110 or 140mph speedo, well, that would be sweet.
I pulled a third gen Camaro speedo out at the wrecking yard to take a look at it.
They are bolted in from the back side and do not have mounting tabs for screwing them in place on a truck cluster. I'm sure you could figure out a way to install one but it wouldn't be as simple as the tach install.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 08-25-2010, 12:36 AM   #153
SCOTI
SCOTI's Avatar
Had to search for this again.... good info so TTT.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-25-2010, 07:16 AM   #154
motornut
78K & 79C Jimmys
motornut's Avatar
wasn't sure if it was here i posted it but i did the tac thing to my 81 lemans cluster,using it out of a gran prix.they seem close if some else wants to try it. i will at a later date the top set it the way it was,bottom is after i poked at it.....idiots light go on other side of speedo from a truck
this was done in 1992
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 08-25-2010, 08:11 AM   #155
BigBlocksRule
All the photobucket links show to have been deleted - could you repost, please - I'm likin' it!!!
BigBlocksRule is offline   Reply With Quote
Old 10-16-2010, 09:58 AM   #156
68 TT
68 TT's Avatar
I found a copy of the original images that were linked to in case they are gone.
Old 10-16-2010, 09:59 AM   #157
68 TT
68 TT's Avatar
Here are the rest.
Old 02-11-2013, 05:07 PM   #158
egaray281
egaray281's Avatar
i really like this alot i think ima try it!
egaray281 is offline   Reply With Quote
Old 12-30-2014, 05:23 AM   #159
lilspike
I just got done adding the camaro speedo as well. I mounted the tach and at first it was ??okaaayy??, but I just didn't think it looked at home. So I started looking at the speedo too.
the camaro mounts through the back via two screws. Which makes it imo a bit simpler. They have the same basic shape of base. So it worked out well. I had to cut out the 4x4/choke housing first. Then I used the piece of insulating foam the camaro used (I guess for anti rattles?) for a template for the mount holes. One falls on the edge of the factory hole. So I only had to drill one and half moon the other hole. Then I had to put a "c" notch in the metal speedo cable clip to clear the mount screw. Flatten the 6 o'clock position of the gauge face slightly to clear the bottom edge of the cluster housing. I used the blue indicator from the camaro and the foam gasket from the truck. So the highbeam indicator worked out perfect. Then I drilled a hole in the lens for the trip odometer reset.
All in all, the speedo part was much easier than the tach/fuel gauge swap. Pros: much easier to read, 110mph gauge, matching combo. Cons: losing the seat belt, 4x4, choke, and brake light warning lights. However it wouldn't be hard to make a custom solution for those.
lilspike is offline   Reply With Quote
Old 12-30-2014, 07:38 PM   #160
mattcrp1
mattcrp1's Avatar
Lilspike, do you have a pic?
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 12-30-2014, 08:06 PM   #161
lilspike
My painting of the needles ain't that great, but it's not a show vehicle.
Old 12-30-2014, 08:16 PM   #162
lilspike
Sorry for the crappy cell pics...
Old 12-30-2014, 09:57 PM   #163
mattcrp1
mattcrp1's Avatar
Looks good.
IG mattcrp1
