#151 |
Re: got a new truck!!!!
Yeah, you just have to cap off the original heater/air duct that went there. It works out well for a/c because driver and passenger get more air and heat.
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness! my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal: I'M SO SO CAL! ![]() |
#152 |
I made a little progress today. I finished up the fuel system, oil system, and the cooling system. I just need to tackle the electrical and the exhaust and my honey will be happy and on the road again. Here are a few pics
#153 |
Looking good.
Videos!!
Mine- '91 GMC RCSB 2wd, 350tbi, 5 speed, 3.42 G80 -Dad/Me Projects/Toys 75 SWB Silverado Factory 454, Th400 87 SWB Silverado 305tbi, 700r4, 2.73's...17.4 @74mph a couple dodge cummins trucks. PLEASE DO NOT MESSAGE ME ABOUT FACTORY TACH DASHES, I AM NOT MY FATHER AND I KNOW VERY LITTLE ABOUT THEM. Thanks ![]() |
#154 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Looks great. Did you use the donor trucks lower radiator hose too or the
c10s hose?
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#155 |
Nice progress. Looks almost factory with the original fan shroud in place.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
#156 |
I'm not sure which hose i used because I have a tote full of lower hoses that I pulled it from. I had to cut about an inch to make it fit. I think it's from the donor truck though just not 100% sure.
#157 |
i got my suburban cluster today!
#158 |
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
#159 |
dude build looks great!
#160 |
OK I've been hunting and gathering parts, but can't find any fittings to adapt the trans lines to the radiator. I saw that Bob used AN fittings. Is there a less expensive way?
#161 |
hey Ram, i tried looking for another route also but ended up back at 2 choices... an fittings or use hard line with a flare. you could also try just using a barbed fitting and clamps with high psi rubber hose but with the high pressure i'd just do it right for piece of mind. Bob was saying that the 4l80e trans spikes up over 350psi when in reverse so i ended up back at the -an fittings. i'm not sure what the 60e spikes up to. good luck bro!
#162 |
Dennis, my original intention was to flare them with a 3/8 tube nut but there are no 5/16 male to 3/8 female inverted adapters.
#163 |
tackled the harness today. i have to add relays and fuse box and I'm done with the harness. I wish i wasn't so frugal because i would definitely just send this type of work out. here are a few pics of the carnage. Pics are in chronological order from start to almost finished.
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness! my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal: I'M SO SO CAL! ![]() Last edited by 69face; 06-23-2010 at 01:08 AM. |
#164 |
wow dude props for doing the harness yourself i messed with mine but i dont have the attention span for that! lol
#165 |
i bought some parts and figured out a way to frugally make the transmission lines work. i bought a box to hide the aldl, relay, and wiring. here are a few pics.
#166 |
#167 |
Ready to see this burning tires off. Good job so far.
#168 |
Just waiting on computer to come back, find a pedal location, exhaust tubing, and new O2 sensors
here are a few pics
#169 | |
#170 |
No i dont work at stevies. Thats my family! My interior man is flakey so i dont send him business anymore. sorry i cant help!
#171 |
I did little things today. I cut the fan shroud and installed the filter, finished up the gauge cluster, and sanded and painted some surface rust on the frame.
#172 |
looking good bro!
#173 |
Coming along nicely man!
#174 | |
your build is lookin real good man!! Last edited by tattoojoey; 07-06-2010 at 02:54 PM. |
#175 |
Thank you all for the compliments! I started it today, but i didn't have the O2 sensors in so i didnt run it long. I really enjoy these swaps! I made the O2 sensors using the connectors from the O2 sensors that i took out of the harness and universal Bosch sensors.
