Old 01-28-2010, 11:23 PM   #151
highperf4x4
Re: 69 cst-10
Shift + Prnt Scrn (print screen is on the top right of your keyboard) then open paint, click on edit, click on paste then cut and resize before you save it as a .jpeg
highperf4x4 is offline   Reply With Quote
Old 01-28-2010, 11:30 PM   #152
ripdog28
ripdog28's Avatar
Re: 69 cst-10
Im not sure what gasket i have but this is the closest KB i found. dont remember the part #
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 01-28-2010, 11:34 PM   #153
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: 69 cst-10
that didnt work travis
but with those pistons it says its 10.561
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 01-28-2010, 11:49 PM   #154
ripdog28
ripdog28's Avatar
Re: 69 cst-10
I wrote my signature when the engine was built and it says 10.5:1 so i may have been wrong. It probly is 10.5 Im running 91 and havent heard anything bad. I do plan on using some Octane boost or maby mix in some 100 with every tank just to have more fun. Im sure the 91 will be fine by itself though.
69 c-10 BBC
Old 01-28-2010, 11:51 PM   #155
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: 69 cst-10
my dads car is running 91 on 11 to 1 it only claters under hard acceleration
Gage
Old 01-28-2010, 11:57 PM   #156
highperf4x4
Re: 69 cst-10
Actually heat is the primary concern when the compression gets that high. Gage if your dad was to do much hot rodding with 11:1 on 91 he would probably burn a valve or piston.
Old 01-29-2010, 12:26 AM   #157
highperf4x4
Re: 69 cst-10
Originally Posted by ripdog28 View Post
I wrote my signature when the engine was built and it sayd 10.5:1 so i may have been wrong. It probly is 10.5 Im running 91 and havent heard anything bad. I do plan on using some Octane boost or maby mix in some 100 with every tank just to have more fun. Im sure the 91 will be fine by itself though.
10.25, 10.5, who cares right? it's a beast of an engine!
Old 01-29-2010, 09:27 AM   #158
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: 69 cst-10
well it is a Ferd so itll handle it
Gage
Old 01-31-2010, 09:04 PM   #159
ripdog28
ripdog28's Avatar
Re: 69 cst-10
Today i fired it up for 1 minute and it cut out. I do not have spark. Looked into my Mallory 6AL and it has power out but not to the coil. It was really freaking hot also. Need to look into it more.
69 c-10 BBC
Old 01-31-2010, 10:15 PM   #160
highperf4x4
Re: 69 cst-10
I don't know alot about that setup. However, the heat issue would lead me to believe there is a ground problem somewhere. It is supposed to have a full 12v to it right?
Old 01-31-2010, 10:53 PM   #161
ripdog28
ripdog28's Avatar
Unhappy Re: 69 cst-10
Yea its connected directly to the batt cabel. I redid the ground but still no luck. (Update) Called Mallory they believe its an internal problem and will be acknowledging the 1 year warranty. I called Jegs and they are sending me a replacement.
69 c-10 BBC
Old 02-04-2010, 03:09 PM   #162
ripdog28
ripdog28's Avatar
Re: 69 cst-10
Just ordered an Alum 4in driveshaft from Inland Empire Driveline. About $660 with the universal joints and yolk/shipping. not to bad. hope its in on Monday so ill get her thrown in.
69 c-10 BBC
Old 02-04-2010, 10:06 PM   #163
highperf4x4
Re: 69 cst-10
Holy crap. Gonna need pics of that bad boy.
Any info on the ignition problem?
Old 02-04-2010, 11:31 PM   #164
ripdog28
ripdog28's Avatar
Re: 69 cst-10
I am not sure but it was getting power in. Some output wires had full power. THe coil wires were really weak. May have been from a bad ground but im not claiming anything on my part. It has a warranty and i am exchanging it When i felt the box it was crazy hot. I opened the little door and a bad smell came out.
69 c-10 BBC
Old 02-05-2010, 12:37 AM   #165
highperf4x4
Re: 69 cst-10
I hate the bad smells.....................
Old 02-05-2010, 12:50 AM   #166
nuke1
nuke1's Avatar
Re: 69 cst-10
I hate ignition problems, that is my fear! hope all turns out well.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-05-2010, 12:57 AM   #167
highperf4x4
Re: 69 cst-10
Brother I hate ANYTHING to do with wires!!!
When I have wiring problems....... I call Joe!
Old 02-06-2010, 04:25 PM   #168
ripdog28
ripdog28's Avatar
Re: 69 cst-10
I had a small leak from my fuel press reg so i just got in a new return style one i will be throwing on. I ordered my Power brake booster 8"duel diafram. Ill be finishing my brake lines. Also have all new rubbers (Caugh) coming in for the doors/window. Ill be ordering new front and back windows in about 2 weeks along with a new 40/20/40 lowback seat. Almost there Im getting so damn anxious.
69 c-10 BBC
Old 02-09-2010, 04:13 PM   #169
ripdog28
ripdog28's Avatar
Re: 69 cst-10
Was hoping the driveshaft would show up by now but i did get something that will keep me busy for a few more days, I guess i would need something to hold the motor back. Its an 8in duel diaphram. Also added a return style regulator.
69 c-10 BBC
Old 02-09-2010, 07:24 PM   #170
70stroker
70stroker's Avatar
Re: 69 cst-10
Looks good man, were ya get the booster from?
70stroker is offline   Reply With Quote
Old 02-09-2010, 10:31 PM   #171
highperf4x4
Re: 69 cst-10
Whoa! How much clearance do you have on that booster?
Old 02-09-2010, 10:44 PM   #172
ripdog28
ripdog28's Avatar
Re: 69 cst-10
It is a POL booster. I had to go with the 8in because the 11in would not have fit. I have about 2 inches between the valve cover and it. Almost done with the brake lines just need a few 3/8in fittings.
69 c-10 BBC
Old 02-09-2010, 10:45 PM   #173
highperf4x4
Re: 69 cst-10
Cool, from the pic it didn't look like you had that much room. I figure you're going to be twisting the frame now and then with the throttle.
Old 02-09-2010, 11:15 PM   #174
ripdog28
ripdog28's Avatar
Re: 69 cst-10
HAHA, I dont know if itll twist the frame with drag radials but once i throw a set of slicks on and the NOS, 750+hp, it may pull the tires a little.
69 c-10 BBC
Old 02-09-2010, 11:40 PM   #175
mcbassin
Still Learning
mcbassin's Avatar
Re: 69 cst-10
Booster is looking good! What kinda cash for that setup?
mcbassin is offline   Reply With Quote
