02-16-2009, 07:25 PM | #151 |
Hey Y'all!!
Re: The 283 Rebuild Begins
Sounds like 2 excellent reasons to me!! Looking forward to seeing it all installed.
Just hopin' I live long enough to finish something!!! |
02-23-2009, 11:55 AM | #152 |
283 Drama Queen
Weather co-operated Saturday, so we got a chance to put the 65’ about three feet up in the air and drill the new hole pattern for TH350’s cross member’s new location - about 1.2" forward. Center drilled punched spots first - then ½ inch bit drilled clearance holes for the new 3/8-16 (grade-8) bolts, washers and nuts - with red ‘loctite’, just for good measure. (Yes - I’ll have the pics by this weekend, so cork it!) So all the heavy lifting is done and now comes the plumbing & small wires. Can’t wait to annoy the neighbors with some new engine noise. Mac.
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
02-23-2009, 12:32 PM | #153 |
Shloooooong bed member #2
[quote=MacAttack;3161404]
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q |
02-23-2009, 12:55 PM | #154 |
283 Drama Queen
Thought I’d beat you’all to the punch.
02-23-2009, 01:19 PM | #155 |
Registerd User
Are you implying that we would hound you for pics?
02-23-2009, 01:31 PM | #156 |
283 Drama Queen
"Hound" as in rabid dogs running me (and anyone else) down for photos?
You bet. Mac.
02-23-2009, 01:49 PM | #157 |
but guess what.....
CHEVY ONLY |
02-23-2009, 01:51 PM | #158 |
283 Drama Queen
* Gee - who didn’t see that coming?
02-23-2009, 01:55 PM | #159 |
Registerd User
02-23-2009, 01:59 PM | #160 |
just keeping it exciting and on the top for ya
CHEVY ONLY |
02-23-2009, 02:48 PM | #161 |
Hey Y'all!!
02-23-2009, 06:35 PM | #162 |
283 Drama Queen
What do you guys think about the 50/50 (already mixed) coolant?
And should I fill the block up (with the bottom hose on - of course) at the thermostat housing first - then put the thermostat in and drop the swivel type housing (with an "O" ring inside its base) with the upper hose on, prior to filling the rest of the radiator? And finally - is it important that I should have my heater hoses connected upon initial light-up?
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. Last edited by MacAttack; 02-23-2009 at 06:36 PM. |
02-23-2009, 06:41 PM | #163 |
Resistance is Futile
I usually just run water at first. If there is an issue you wont watch your $$$$ running out on the ground. Glad to hear about the progress.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
02-23-2009, 08:34 PM | #164 |
Registerd User
Why pay extra for water? But I would sure stay with the mean green.
02-23-2009, 09:27 PM | #165 |
Since you put the TH350 in- What flexplate and starter are you using?
02-23-2009, 10:42 PM | #166 | |
Someone already stated about the 50/50 coolant mix, why pay extra for water? If you are running any aluminum cooling components, you might use de ionized water to mix with the coolant. We do that with dirtbikes, which are all aluminum motors. Slows down the corrosion factor. You def. want your heater hoses connected, or plugged, as the there is always water circulating through them, I beleive. |
02-23-2009, 11:01 PM | #167 | |
I agree with YZ250, I use Hyperlube (Hypercool?)......looks like Mountain Dew.... for its corrosion fighting chemicals. There are a bunch of different types but they all fight chemicals eating aluminum. Ive usually gotten 2 gallon containers of distilled water from the grocery store to avoid corrosion.
02-24-2009, 03:19 PM | #168 | |
283 Drama Queen
Mac.
02-24-2009, 06:57 PM | #169 |
283 Drama Queen
10-4 on the hoses. BTW, I had one of these in my tool box and have never used it - just thought I'd give it a rip during the break-in on the driveway (just hope I've got enough vertical clearance:
02-24-2009, 06:59 PM | #170 |
The pink will look good with your grey engine.
02-24-2009, 07:14 PM | #171 |
283 Drama Queen
Fuel filter location question:
Before plumbing it to the motor I’d like to get some input on my options. I’m using the hard canister type (polished, of course - cause that makes the truck go faster) but I don’t like putting it down on the frame rail, where the hard line dumps out - just behind the motor mount on the passenger side. After seeing various engine fire photographs on our site - I’m not digging the idea of having it up on top of the engine - even if it’s easy access. I mean - how often do you need to change the thing in the first place? My tank (stock - behind the seat, for convenient detonation) has been rehabbed and is as clean as when it came from the factory - so there’s no junk to worry about. I’d like to put the filter in that short rubber line that runs directly from the tank to the hard line on the frame. Is there any reason that the fuel pump would have a problem pulling from there and sending it up to the 2-barrel?
02-24-2009, 07:34 PM | #172 |
the under cab location you described was exactly where our filter was before the tear down.....it ran great, no starvation issue
CHEVY ONLY Last edited by joe231; 02-24-2009 at 07:34 PM. |
02-24-2009, 07:44 PM | #173 |
283 Drama Queen
Actually, that is Magenta. And I’m not gay - so save that noise.
Mac.
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. Last edited by MacAttack; 02-24-2009 at 07:45 PM. |
02-24-2009, 10:57 PM | #174 |
that is what all the guys wearing pink say
CHEVY ONLY |
02-24-2009, 11:05 PM | #175 |
There's so many things to say....I 'm just going to pass.
