Old 07-27-2009, 01:56 AM   #151
Jvsapp
Jvsapp's Avatar
Re: Lucy - My 1968 SWB
sounds good. i'm sure it'll look sweet.
Jvsapp is offline   Reply With Quote
Old 07-29-2009, 11:11 PM   #152
tdave00
Restoring a 68 SWB
tdave00's Avatar
This is what I am gonna do for the upper plates.
tdave00 is offline   Reply With Quote
Old 07-29-2009, 11:20 PM   #153
Jvsapp
Jvsapp's Avatar
welding on or bolting on? i know there is a kit that uses plates that bolt onto the front crossmember. that's the route i would go....
Old 07-29-2009, 11:33 PM   #154
tdave00
Restoring a 68 SWB
tdave00's Avatar
I can't wait for them to get here. Thought I had some bought local but they wouldn't work for me. It's 1/4" plate - same as the kit. Just doesn't cover as much area.
Old 07-30-2009, 10:55 PM   #155
tdave00
Restoring a 68 SWB
tdave00's Avatar
I had a few hours tonight after work to work on the truck. I had been thinking about this all day, so to heck with it. I did it. Call me lazy and cheap, but I am tired of drilling holes.
Old 07-30-2009, 11:11 PM   #156
Jvsapp
Jvsapp's Avatar
are you going to be able to get in there and attach the nuts/bolts for the bags?
Old 07-30-2009, 11:21 PM   #157
tdave00
Restoring a 68 SWB
tdave00's Avatar
Yeah, I checked that before I did it.
Old 07-30-2009, 11:39 PM   #158
Jvsapp
Jvsapp's Avatar
cool then i don't see a problem with it... cleaner too, hidden plate.
Old 07-31-2009, 12:14 AM   #159
tdave00
Restoring a 68 SWB
tdave00's Avatar
Yeah, and it probably get's me another 3/4 of an inch. I welded the *^# out of it. Almost hated to grind those beads, but I thought it needed to be smooth in case the bags touched any of it by chance.
Old 07-31-2009, 12:17 AM   #160
Jvsapp
Jvsapp's Avatar
hehehe i hear you. if the beads were nice i would have maybe cleaned them up with a roloc disc. i've used those gasket cleaning discs to clean up welds so there's no sharp edges but keep the bead for strength
Old 07-31-2009, 01:08 AM   #161
tdave00
Restoring a 68 SWB
tdave00's Avatar
I left the majority of the bead. Just tried to make a smooth transition from the plate to the crossmember. Didn't take very much of the weld off.
Old 07-31-2009, 02:04 PM   #162
LooseCannon
Your build is looking good!
LooseCannon is offline   Reply With Quote
Old 07-31-2009, 07:27 PM   #163
tdave00
Restoring a 68 SWB
tdave00's Avatar
Thanks. Should be rolling again by the end of the weekend.
Old 08-02-2009, 02:37 AM   #164
tdave00
Restoring a 68 SWB
tdave00's Avatar
Took me all day off and on to get the holes drilled and bags mounted to the crossmember. Cross member is ready to be bolted in.
Old 08-02-2009, 10:09 PM   #165
tdave00
Restoring a 68 SWB
tdave00's Avatar
Made my cups today.
Old 08-03-2009, 11:20 PM   #166
tdave00
Restoring a 68 SWB
tdave00's Avatar
Got my crossmember on tonight and got the upper control arm balljoints in. The airlines I bought at Ace stretched on me...didn't realize they were that cheap. So, I have to take the bags back off and get more line. Didn't wanna take the bags off with the lower control arms on so I just decided to wait til I get the line tomorrow. Depending on how much time I have tomorrow I should be able to get the front end back together, or at least close.
Old 08-07-2009, 01:28 AM   #167
tdave00
Restoring a 68 SWB
tdave00's Avatar
Had some help for a few minutes tonight. I was gonna take the cab off and clean up the frame and get it ready to paint under the cab, but I had a few things to do to get that ready and my help couldn't stay long. Instead I took the rearend off of the jackstands and put a jack under the front and rolled it closer to the front of the garage. That will give me some room to set my cab in front of the truck.
I mocked up one side of the front suspension tonight.
Old 08-10-2009, 02:44 AM   #168
tdave00
Restoring a 68 SWB
tdave00's Avatar
Had 3 of my cousins friends in the garage the other day, plus a guy that works for me, so we unbolted the cab and set it off the frame. I rolled it out of the garage that night and pressure washed it to get the grime off. I still have a bit of hand cleaning to do, but plan to get the rest of the frame painted in the next few days, get the cab bushings and set the cab back on it. I have been granted a little reprieve in my time schedule, but still need to get this thing put back together in the next week or two.
Old 08-10-2009, 11:41 PM   #169
71'tahoe
71'tahoe's Avatar
Looking good Trai!!
71'tahoe is offline   Reply With Quote
Old 08-11-2009, 12:01 AM   #170
Jvsapp
Jvsapp's Avatar
progress looks good. i love the shop shots
Old 08-11-2009, 12:45 AM   #171
tdave00
Restoring a 68 SWB
tdave00's Avatar
Thanks guys. Hopefully really soon I can get most of it back together and get you a stance shot outside of the garage.
Old 08-25-2009, 02:51 AM   #172
tdave00
Restoring a 68 SWB
tdave00's Avatar
Old 08-26-2009, 04:54 AM   #173
Jvsapp
Jvsapp's Avatar
looking good. now sit it on the ground
Old 08-26-2009, 11:57 PM   #174
tdave00
Restoring a 68 SWB
tdave00's Avatar
I just decided to make this piece. I bought 3 washers and just bent one of them in to give it a similar shape as the spacer. Then I welded them all together.
Got my rotor on the other side now. I need to stick the brakes on and I can put the front wheels on.
Old 08-26-2009, 11:57 PM   #175
tdave00
Restoring a 68 SWB
tdave00's Avatar
I have four 8" rally wheels. I know there is a problem with the front when trying to use 8's on the front because they stick out too far.
Check the tire size that I came up with below and tell me if you think it will work.
http://www.1010tires.com/tiresizecalculator.asp
The tire size on the left is the tire size that's on the rear. I tried to play with this calculator and find a tire that was alot narrower but kept the same sidewall height. What do you guys think?
The 225/70R15 is 2 inches narrower than the rear tires, so just wondering if that will work and look right, or if I am gonna have to go with a 6 or 7 inch rim.
