Old 04-23-2009, 11:42 AM   #151
kizer
Its Deja Vu time again
kizer's Avatar
Re: Kizer and his 65 here
Originally Posted by Alan's Classic View Post
The hard part is over.
You wish. The hard part is prying the cash from my wifes dead grip. Well shes not dead, but she would have to be dead to pry it out.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 04-23-2009, 12:54 PM   #152
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Helluva teardown man....keep it coming !
The ol' wife 'deathgrip on the cash', huh ??
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 04-23-2009, 03:06 PM   #153
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Alan's Classic is offline   Reply With Quote
Old 04-23-2009, 03:23 PM   #154
kizer
kizer's Avatar
I was actually staring at the thing yesterday trying to figure out if I should pull the motor first or pull the cab first. The wife pulls in and lays on the horn. "Lets Go, Its not like you are going to actually work on that thing" Man made me a bit mad and determined. Something will come off this thing this weekend.
Looking at the steering the shaft that comes through the firewall is that connected inside or is it held on by the two bolts under that C shaped band? I pulled the two bolts, but I couldn't pull the shaft. I figured I'd leave everything inside intact until I'm ready to tackle the cab, but wanted to start pulling things off the firewall that would get damaged when I live the cab off to tackle the rest of the frame.
Old 04-23-2009, 04:02 PM   #155
MacAttack
283 Drama Queen
MacAttack's Avatar
Ouch!
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 04-23-2009, 04:53 PM   #156
joe231
joe231's Avatar
steering shaft??
are you referring to the column? if so it is one piece(solid shaft) from the steering wheel to the gear box....
CHEVY ONLY
Old 04-23-2009, 06:13 PM   #157
kizer
kizer's Avatar
Thanks Joe. Yeah I was looking at the end that connects to the steering box trying to figure out how to get it off or do I need a steering wheel puller to get the wheel off and pull it down.
I'm sure I'll figure it out eventually. I do have a book laying around some where.
Old 04-23-2009, 09:21 PM   #158
beefshreadder116
beefshreadder116's Avatar
this hood came off of a 66 LWB chevy
Projects:
66 gmc, SWB ,BBW,76 disc brakes/PS and rearend, pancaked crossmember 2 1/2" drop spindles 1 cut coil, 6" drop coils 2 " blocks c-notch with a 350.
beefshreadder116 is offline   Reply With Quote
Old 04-24-2009, 12:49 AM   #159
kizer
kizer's Avatar
Thanks and you have more PMs.
Old 04-24-2009, 08:41 AM   #160
joe231
joe231's Avatar
you will either need to take the 2 bolts out that hold the rag joint on the flange at the box or take your column loose under the dash then remove the bolt at the gear box that is perpendicular to the shaft and slide/pry the coupler up and off of the gear box shaft...make sense??
the easier way would probably be to take apart the rag joint if it has bolts and isn't riveted together ...
CHEVY ONLY
Old 04-24-2009, 11:57 AM   #161
kizer
kizer's Avatar
Thanks Joe. I could be wrong, but I think they are riveted. It just didn't look easy to pull the rag joint apart. Either way I'll just give it a go this weekend so I can start getting this thing apart.
As well I'd like to start taking some measurements so I can build a stand to hold the cab once I take it off. I don't plan on building a fancy flip over type of thing as of yet, but I'd like to be able to take the cab off and sit it on something other than the ground to avoid bending sheet metal.
Old 04-24-2009, 12:43 PM   #162
joe231
joe231's Avatar
right on!
CHEVY ONLY
Old 04-24-2009, 10:35 PM   #163
Captainfab
60-66 Nut
The column is also attached at the firewall on the engine side. Just a little FYI.....
Get after it this weekend and you'll show her.....
Old 04-25-2009, 04:11 PM   #164
joe231
joe231's Avatar
yeah that too
CHEVY ONLY
Old 05-02-2009, 12:50 AM   #165
TimE
Hey Y'all!!
TimE's Avatar
Sorry it took me so long but here's some pics of what I mentioned about the chain to pull the motor. Hope it helps!
Overview
Installed a long Grade 8 bolt in the front to attach the chain to.
Looped the chain around the rear of the intake.
Just find the sweet spot on the chain and it will pull out level. Good luck!!
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 05-04-2009, 01:14 PM   #166
kizer
kizer's Avatar
Oh, now I see how you did it I thought you went around the motor which I coudln't picture. You went around at an angle.
Thanks for the pictures. Makes a lot more sense now.
Old 05-04-2009, 02:27 PM   #167
MacAttack
283 Drama Queen
MacAttack's Avatar
That sucker must have really good brakes - with the drive shaft ending up in the engine compartment and all.
Old 05-04-2009, 02:43 PM   #168
4dranch
Shloooooong bed member #2
4dranch's Avatar
I was thinking the same thing. Or Tim must have front wheel drive..
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 05-04-2009, 03:23 PM   #169
joe231
joe231's Avatar
the peanut gallery is alive and well
CHEVY ONLY
Old 05-04-2009, 04:47 PM   #170
kizer
kizer's Avatar
Hahah, I didn't even notice the drive shaft in the pictures. Thats funny as heck.
Wooooo hooooo
I'm guessing thats his driveshaft driven fan.
Old 05-06-2009, 11:33 PM   #171
TimE
Hey Y'all!!
TimE's Avatar
You guys are a bunch of Fruit Loops!!
That motor is sitting on the slab with clutter on/around/under it. It's an abandoned relic at the moment...
Glad the pics helped out though.
Old 05-07-2009, 07:47 AM   #172
scotts62
One day...
scotts62's Avatar
Wooooo hooooo
Na it works like an air boat, has a fan up front to pull him around
Scott
93 crew cab build
Project 62
Old 05-07-2009, 09:56 AM   #173
MacAttack
283 Drama Queen
MacAttack's Avatar
Hey, I just call'em as I see'em.
Old 05-07-2009, 10:08 AM   #174
4dranch
4dranch's Avatar
David,
Daughters 66 truck:
Old 05-07-2009, 10:22 AM   #175
protrash64
Resistance is Futile
protrash64's Avatar
Thanx for clarifying; I thought it was a shaft-driven heater fan.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
