06-10-2019, 12:00 PM | #151 |
Re: 6 luggers
https://i0.wp.com/knsacc.com/wp-cont...0%2C1200&ssl=1 6 lug spider caps have been out for a couple of years now. These fit pretty much any steel and transit wheels. Just do a google search and they pop right up. Would like to see more trucks with these on. Cheers! |
06-10-2019, 04:16 PM | #152 | |
Re: 6 luggers
06-10-2019, 04:21 PM | #153 |
Re: 6 luggers
I wonder if you can use these with a different type of lug and not use the plastic lug covers.
06-10-2019, 10:36 PM | #154 |
Re: 6 luggers
im running these :
behind my smoothies : Wheel close up by Keith, on Flickr they are just a little bit bigger then the bore of the wheel, but the flange is pulled tight between the wheel and the brake drum as the lugs are tightened down |
06-11-2019, 12:34 PM | #155 | |
Re: 6 luggers
For those that do not wish to use the lug covers, use the Bullet lug nuts and they'll work and look just fine. |
06-11-2019, 12:35 PM | #156 |
Re: 6 luggers
06-11-2019, 01:20 PM | #157 |
Re: 6 luggers
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
06-12-2019, 01:22 PM | #158 |
Re: 6 luggers
06-13-2019, 04:49 PM | #159 |
Re: 6 luggers
22" GM Transports
60 with 2-1/2" front spindles (torsions adjusted) and 4" drop springs in rear.
06-13-2019, 04:51 PM | #160 |
Re: 6 luggers
But they are rather large. the stock 7/16" lugs are too small.
06-13-2019, 08:14 PM | #161 |
Re: 6 luggers
wheel vintiques series 12,1952 center caps
06-14-2019, 11:14 PM | #162 | |
But Found Her 25yrs Later!
Re: 6 luggers
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
06-15-2019, 01:33 AM | #163 |
Re: 6 luggers
10-28-2019, 01:00 PM | #164 |
Re: 6 luggers
these were on the truck when I got it
old school prime gold 5 stars
1961 c10 longbed - gone 1964 c10 swb |
10-28-2019, 04:50 PM | #165 |
Re: 6 luggers
I’m running stockers up front. Out back running wheel vintiques series 12 15x8 smoothies with 4” backspace. I modified some VW hubcap clips and drilled/tapped the wheel to fit these to run a hubcap.
