Old 03-04-2012, 11:47 AM   #151
waybad
waybad's Avatar
Re: New 1957 Project
cool,, what size did you go with?
waybad is offline   Reply With Quote
Old 03-04-2012, 12:13 PM   #152
renegade6
I went with 255/85 16 tires. I originally went with zero offset rims but, found out the hard way that they won't clear the tie rod ends.
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 05-15-2012, 09:39 AM   #153
renegade6
Unhappy Re: New 1957 Project
It is now sold
Brandon
Old 05-15-2012, 10:49 AM   #154
Russell Ashley
Russell Ashley's Avatar
Originally Posted by renegade6 View Post
It is now sold
Thanks for your service, hope to see you back soon with a new project.
It's sad that you had to sell it without getting to enjoy it for very long but I hope you got a lot for it. It should be a high dollar truck IMO.
How did you sell it? EBay, HAMB, this forum, CL? just curious.
Russell Ashley is offline   Reply With Quote
Old 05-15-2012, 03:07 PM   #155
renegade6
Thanks. I enjoy doing what I do.
I sold it for $24.5 and I could have gotten a bit more but, didn't want to get greedy.
I had it listed in multiple sites but, old-ride was the one that I got the most hits off of.
I already have my next project a 63 Biscayne.
Brandon
Old 09-05-2013, 08:59 AM   #156
gmjim4x4
Re: Steering pictures
Here are the pictures of the steering gearbox and linkage.
You had crossover steering to make this setup work is that right?
gmjim4x4 is offline   Reply With Quote
Old 03-10-2018, 02:05 AM   #157
Rebecca55
how do I fix my driver door hinge as the top hole for pin is worn and big. 99 chevy silverado replaced pins but top hole is worn bigger. i was told that the hinge needs replaced but no one wants to do it. Help ple
ase��
Rebecca55 is offline   Reply With Quote
Old 03-10-2018, 07:06 PM   #158
dsraven
I had the same problem with mine. I welded the hole and drilled to correct size. replaced the pins and bushings. just gotta bear in mind where the correct hole center should be.
otherwise replace with a new hinge, not usually gonna break the bank.
