11-23-2009, 09:20 PM | #151 |
Re: The MONEY PIT
I think she`ll kill you, try a bbq with a tin foil pan under it.....!
11-23-2009, 11:12 PM | #152 | |
Re: The MONEY PIT
Here is a picturer of the upper a-arms, one done and one not. A buddy of mine took these and the other parts to media blast them for me.. All it needs now is paint.
My Build "63 Stepside" Major Components 71 350 stock 86' 700R4 My Front Disc Conversion Last edited by drogers; 11-23-2009 at 11:13 PM. |
11-24-2009, 01:33 AM | #153 | |
60-66 Nut
Re: The MONEY PIT
No I wouldn't do that in an oven you're going to cook food in again. The BBQ would probably be OK since you can air it out good. It is a good idea to cure this paint too as directed. In my experience some high heat paints will have a tendency to allow rust to form if it hasn't been temperature cured.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 11-24-2009 at 01:34 AM. |
11-25-2009, 08:06 PM | #154 |
Re: The MONEY PIT
Thanks for the feedback.. I chickened out and took the paint back and got some Dupli Color Caliper paint that does not require baking. Also came across another issue with the lower a-arm shaft and have a question posted over in the suspension section.
Here are a few pictures,
My Build "63 Stepside" Major Components 71 350 stock 86' 700R4 My Front Disc Conversion Last edited by drogers; 11-25-2009 at 09:17 PM. |
11-25-2009, 08:12 PM | #155 |
1 thing at a time is progress.
Re: The MONEY PIT
Nice work!
Alan
Philippians 2:14-16 |
11-25-2009, 08:49 PM | #156 |
Re: The MONEY PIT
Thanks Alan..
I also picked up a '85 power booster for the brake conversion. I tried getting a prop valve but they want $50 bucks for it, went to 2 other salvage yards and they wanted the same. What happened to used parts price, I can get a brand new one for $56? Any suggestions? Thanks Below are the before and after, got to keep Joe Happy...
My Build "63 Stepside" Major Components 71 350 stock 86' 700R4 My Front Disc Conversion |
11-27-2009, 08:25 PM | #157 |
Re: The MONEY PIT
Well, I got most of the front end put back together and the new rotors and calipers installed..
11-27-2009, 09:27 PM | #158 |
One day...
Re: The MONEY PIT
Ah nice and clean. Looks good
11-27-2009, 09:57 PM | #159 |
Re: The MONEY PIT
Nice job !!!!!!
11-28-2009, 12:27 AM | #160 |
Member of the longbed union.
Re: The MONEY PIT
Looks really good. I cant wait to see it put together. Paint turned out good.
everyones trying to make money off there used parts, with the way the world is they have to make money some how.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
11-28-2009, 09:05 PM | #161 |
Re: The MONEY PIT
Thanks guys.
I did get a prop valve from a local U-Pull It for $6.95. After looking at the power booster, I might need to head back to the drawing board. I'll post some pictures tomorrow.
02-14-2010, 12:58 AM | #162 |
Re: The MONEY PIT
I've been stalking the other builds and will post some pictures of my drum to disc conversion tomorrow....
02-28-2010, 05:39 PM | #163 |
Re: The MONEY PIT
Well, after 4 months she's back on the street. I ended up going with a CPP booster, prop valve, and MC. I still need to get a front end alignment done and then I'll put together a list of all the parts I used.
02-28-2010, 09:09 PM | #164 |
Registerd User
Re: The MONEY PIT
Looking good drogers. I used the same booster and master cylender for a year now with no complaint. Good to see you back on the road.
03-03-2010, 08:05 PM | #165 |
Re: The MONEY PIT
Thanks Jason, it's been hard staying motivated this winter.
03-03-2010, 10:38 PM | #166 |
One day...
Re: The MONEY PIT
I hear ya there, this winter has sucked and been too cold to really get out and do a whole lot..
03-05-2010, 09:49 PM | #167 |
Re: The MONEY PIT
Yes, you guys in OKC have had it as bad as us, and I bet we get hit again before it's over.
My Build "63 Stepside" Major Components 71 350 stock 86' 700R4 My Front Disc Conversion Last edited by drogers; 03-05-2010 at 09:53 PM. |
03-05-2010, 09:52 PM | #168 |
Re: The MONEY PIT
We'll I'm back on the road. I did a write up on my disc conversion adventure, [http://67-72chevytrucks.com/vboard/s....php?t=390446] if you're interested.
My next project is putting new coils and shocks on the back and putting the sway bar kit on. Hopefully it doesn't take me 3 months. Below is a picture of the sway bar kit I got..
My Build "63 Stepside" Major Components 71 350 stock 86' 700R4 My Front Disc Conversion Last edited by drogers; 05-14-2010 at 08:44 PM. |
04-04-2010, 08:35 PM | #169 |
Re: The MONEY PIT
Hi Drogers from Claremore, looks like you are only about 10 miles from me or so. Great job on the truck so far. by the way you wouldnt happen to be one of those AA guys would you? Good Luck Bill
04-05-2010, 06:13 PM | #170 |
Re: The MONEY PIT
AA, American Airlines, no? BTW, your frame and fuel tank install looks sharp..
My Build "63 Stepside" Major Components 71 350 stock 86' 700R4 My Front Disc Conversion Last edited by drogers; 04-05-2010 at 06:14 PM. |
05-31-2010, 06:31 PM | #171 |
Re: The MONEY PIT
It's been awhile since I've posted or even done anything on the truck. Been enjoying it not being in pieces in the garage. I've also been busy doing yard work and some minor home improvements.
Getting ready to maybe take it to my first car show. Here are a few before and after pictures of the hood. Just did a wash, light sanding, and a coat of Hammerit.. I need to get busy on the body and the interior but can't get motivated to do it.
05-31-2010, 06:51 PM | #172 |
One day...
Re: The MONEY PIT
Hey man its looking good!!
05-31-2010, 09:00 PM | #173 |
Re: The MONEY PIT
05-31-2010, 09:11 PM | #174 |
Re: The MONEY PIT
with Scott...looks nice!!
CHEVY ONLY |
06-02-2010, 07:57 AM | #175 |
Re: The MONEY PIT
Thanks Joe.. Wish I was making better progress but time & money keep getting in the way!!
