#151 |
Hollister, CA.
![]() Join Date: Sep 2006
Re: PROJECT "Z069" - LS7 powered '69 Stingray....
- ![]() - ![]() - Welded an 1/8" pipe bung for the barbed fitting...hose to cylinder head bleed... - ![]() - Bottom pipe was a lot easier: - ![]() - ![]() - ![]() - ![]() - I purchased a box of cheapy hose clamps to hold things together...but the nice ones were picked up later. - ![]() - After the pipes were done...my buddy hooked it up with the bead roller !! - ![]() - ![]()
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
#152 |
Hollister, CA.
Not sure why the pics turned out in different sizes..my camera phone has a mind of it's own sometimes...
#153 |
Hollister, CA.
Last two on the pipes...
- ![]() - Looks pretty good, I think...even better after it's coated the same Silver as the fuel tank !!! - ![]() - - After numerous years...we called Classic 5-speed and had them send up the driveline...built by Empire..and a nice piece !! - ![]() - ![]() - ![]() - Lift'n her ass up, so she can get the shaft... - ![]()
#154 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Looking good did you ever get the rear spring figured out?
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#155 |
Hollister, CA.
Not yet man....with the engine and tranny in....fuel in tank...there is no movement yet.
I still think there is something wrong with that spring. The dashboard, seats, and all the glass have to go in.....but I dont think that'll do it either. Planning on purchasing a new fiber spring for the rear. We will see...
#156 |
Hollister, CA.
I finished up the throttle pedal and mount yesterday too.
When I first installed the throttle pedal, Lokar cable, and the throttle body mount...I wasn't getting enough pull from the cable. After tons of adjustments, I realized the thin fiberglass firewall was flexing like crazy...and the stock small metal pedal mounting plate (riveted by two small rivets) was even working it way loose. Not to mention the stock plastic pivot point ended up breaking. I thought this will not cut it...especially being the most important pedal on the car !! ( next to the brake pedal ) So, the flexing was taking away from the leverage to open the throttle plate. The Lokar cable was new.. and not binding. And the return spring on the TV was not that over-powering, so the firewall was the problem. So this is what I did.....I built a reinforcement plate, using roller heims for the pivot..heavy duty, and stout !! - - Here the pedal, and stock now broken, mount: - ![]() - ![]() - and my idea: - ![]() - ![]() - After making a paper template, then a steel plate....I traced out the stock mounting location, for the bolt holes: - ![]() - ![]() - Took some 1/2" stock, drilled and tapped for the heims: - ![]() - .....and tacked to plate: - ![]() - ![]() - After cutting the heims down a bit...it placed the pivot point within spec....This gave me more adjustment as well. I backed them out, which gave me a little more pull on the cable: - ![]()
#157 |
Hollister, CA.
![]() - ![]() - ![]() - Cut them down a bit: - ![]() - Now I had to come up with a cool, way of mounting the plate to the firewall. I couldn't get in there with a rivot gun, or use hard rivets so.... I went to the hardware store, I purchased some screws with the same size head as the factory rivot...weld the philleps head, sanded smooth, painted black then installed. Man, it looks totally stock !! Hard to see in pic though... - ![]() - Here's it mounted on the inside: - ![]() - Firewall pad back over it: - ![]() - Also finished the cable mount on the engine side: - ![]() - ![]() - ![]() -
#158 |
nice work John!
very ingenious ![]()
#159 |
Hollister, CA.
I AM BACK !!!!!!!!!
We are on a mission to get this thing into PAINT JAIL ASAP !!!! ![]() Currently I have been working on get the interior and dash back together, and getting the Vette operational. From here it'll go to the alignment shop, and then to PAINT JAIL !! Picked up some supplys at Lowe paint and went to work on the column and dash pieces. Special attention is going into everything, including blasting and paint brackets and such that you would never see, but that's the way I roll ... came this far, why stop now !! - - I started back on it with the restore of the 'Astro-Ventilation' flappers from the rear of the car...blast, paint, re-seal, lube, re-assemble, and shelf it for now....
#160 |
Hollister, CA.
![]() - ![]() - ![]() - ![]() - ![]() - The main frame needed a little more persuasion in removing the OG adhesive: - ![]() - Two-tone detail....:rofl: - ![]() - ![]() - ![]() - ![]() - ![]() - -
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 03-01-2013 at 08:00 PM. |
#161 |
Hollister, CA.
Next, I moved on to refacing the heater controls.....Completely dissasembled, blasted, and lubed the mechanisms:
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 03-01-2013 at 08:01 PM. |
#162 |
Hollister, CA.
Steering Column freshly painted with 'Trim Black' and in position:
- ![]() - Moved on to guages: - ![]() - ![]() - ![]() - ![]() - ![]() - and repainted upper panel...then carefully sanded to bring back the shine.... - ![]() - ![]() - Even rebuilt the clock to a 'quartz' movement.... - ![]() - ![]() - ![]()
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 03-01-2013 at 08:02 PM. |
#163 |
Hollister, CA.
A few more from last week:
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 03-01-2013 at 08:03 PM. |
#164 |
Hollister, CA.
Last Friday, I mocked up the headlights to check for worn parts (everything, pretty much) ... and to start the vaccumm line routing:
- - ![]() - ![]() - Vette still sports 3 of the "V" lights.... - ![]() - ![]() - ![]() - ![]() -
#165 |
Hollister, CA.
Among other things...the horn relay got located today:
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 03-01-2013 at 08:05 PM. |
#166 |
Hollister, CA.
Few random pics of the steering column.....
- - ![]() - ![]() - And the custom pedal and TB mounts after PC !! (anyone still need one ??:toetap ![]() - - ![]()
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 03-01-2013 at 08:06 PM. |
#167 |
Hollister, CA.
It's been a while, so it's about time we UPDATE !!
- - The dash finally went back in ... here are some past progress shots: - - ![]() - ![]() - ![]() - ![]() - ![]() - ![]() -
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 03-01-2013 at 08:07 PM. |
#168 |
Hollister, CA.
Shots from the kick-panel vent door restore ... These were pretty nasty and shot:
- - ![]() - One small piece of foam seal barely hanging on: - ![]() - ![]() - ![]() - ![]() - ![]() - ![]()
#169 |
PROJECT 7DEUCE
Good to see ya still plugging away at this....
#170 |
very very cool love the gauges on these things! also that upper dash panel looks awesome excellent job cheif!
#171 |
![]() Join Date: Aug 2005
Looking great. Always high quality work from you. I bought some raptor liner for the Minx on your recommendation.
#172 |
Hollister, CA.
Over a year .... been that long ???
![]() WELL IM BACK, with a NEW shop and MORE detailed pics !! The vette has been FINALLY painted and delivered about a week ago.... - - Late delivery with a Tow truck .... - ![]() - ![]() - These were taken that night.... - ![]() - ![]() - ![]() - ![]() - ![]()
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 03-01-2013 at 08:13 PM. |
#173 |
![]() Join Date: Mar 2005
Wow Chief, that car is looking great!
I commend your patience on this build. Corvettes are hands-down the hardest Chevy to restore because they share essentially nothing with any of the other models. They are extremely difficult to restore. Lots of unique little clips and brackets, and the wire and hose routings aren't like anything you've ever seen. I helped a neighbor restore his '64 Corvette 327/365 horse (with A/C) roadster. There is no way you can put these cars back together without a build manual, and even that isn't enough sometimes. Can't wait to see more!!
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#174 |
PROJECT 7DEUCE
Vette looks great glad to see it in black..
#175 |
Great work. Glad to see you're still at it and updating us all.
81 GMC C15 RC SWB 5.3L 4L80E project ![]() |
