Old 12-26-2009, 06:06 PM   #151
shortbed70
shortbed70's Avatar
Re: Protrash Re-hash
Well the weather must be nicer where you are. Nice to see your still working on it. Wish I could say the same its just TOO cold
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 12-26-2009, 06:11 PM   #152
lakeroadster
Originally Posted by protrash64 View Post
I've got this head lite thing figured out and just need to assemble it and do some welding.
smoke:
Subscribed.... looking forward to the headlight install!
lakeroadster is offline   Reply With Quote
Old 12-27-2009, 01:11 AM   #153
protrash64
Resistance is Futile
protrash64's Avatar
It's pretty good......chilly, but good. It chased me inside last nite when I was head scratching and not actually doing anything.
Me too.....I've never been able to drive at nite. Also looking forward to your dash install.
OK.......cut and welded and got my grill support together. Fairly self explanatory but it coulda gone a couple different ways. The first pic shows the original grill support lip clamped on the new grill support. A few welds and then hung the thing on the front of the truck just to get it out of the way. Still needs a bunch of grinding and a little body work but I think its good. I will try to get the headlites mounted tomorrow.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 12-27-2009, 09:00 AM   #154
lakeroadster
I have contemplated sinking the headlights back into the grille support panel too. (I never have liked the "profile" look of the headlights sticking out of the front of the truck) Problem with doing this is I would also need to cut the inner fenders and then make some type of bucket.
Will you be cutting the inner fender panels during you modifications?
I am thinking of using bigger than stock headlights and making a custom grille to replicate a 67 plane Jane Camaro. Basically a big flat grille that from the side doesn't protrude out past the grille support panel. Or go a similar route like you have, with a Ralley Sport look.
Thanks, any input is appreciated.
Old 12-27-2009, 01:16 PM   #155
protrash64
protrash64's Avatar
This exactly how I came up with my original idea. I noticed GM styling thruout the years had basically a rough shape and then a pie-cut for the grill. Its noticeable on anything with a phantom grill and the hideaways.
I thought I would be into the inner fenders and decided to hack out whatever I needed to get the cosmetic and function I wanted. Turns out that I will not cut the inners. If you look, they bolt on to the core with a lip folded down which actually gives you about 2'' vertically. Some of the lip may have to go, but I dont believe the engine bay side will be touched(looking down from the front with the hood open). Also the grill mounts very low and to the outside. The only casualty so far has been the core support diaginal. I thought I would rplace this metal with square stock around my future headlite bucket, but it is so solid I may forego the work. There are only about 50 bolts holding this stuff together!!!
What I have considered so far are the following: any of this may stimulate a better idea than mine. My metal skills are just this side of caveman, so I'm sure there are cleaner possibilities
88-89 truck headlites (4 little peanut lites)
90's F-body thin, flat lites
70's-80's square lites....on just about everything(4x6'')
5'' round headlites (4 headlite 70's Impala's for eg)
stock 7'' rounds....cut out the original headlite bucket and flip it around backwards and it almost fits.
The problem with the smaller headlites (4 lite set-ups) is a separate high beam lite adding mounting space and complexity. I went with the 5x7's cuz they fit the 'rounded square' look of the truck and had hi/lo beams in one unit.
I also learned that the mount feet of the original grill will give you the offset of the grill support bends to allow you to measure a level behind the grill to aim the lite. If you look at it it will make sense.
good luck and enjoy my hacking away...all your parts are getting more valuable by the day!!!!
Old 01-03-2010, 08:21 PM   #156
ravens65
ravens65's Avatar
How about rs/ss camero hideaway headlights , had thoughts of doing that to mine w/rs/ss taillights in a roll pan and a cowl induction hood scoop - noone has done it.....yet! the grill is shorter so you would need to graft 2 together with a plastic welder it would look wicked than add rally strips and rs/ss emblems and the front spoiler
If it has tits or wheels its gonna give you problems!!!
ravens65 is offline   Reply With Quote
Old 01-03-2010, 08:25 PM   #157
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
they make a metal rs grill i think
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 01-03-2010, 08:34 PM   #158
ravens65
ravens65's Avatar
I had looked @ plastic ones -the doors are metal of couse this isn't the easiest but.... it would be awesome to flip open the headlights grilles are bout 90.00 can't remember the doors and trim think it was all about 300-350.00 for new repo parts (not inc hood scoop and tail lights or emblems)junk yard parts would greatly reduce the cost!!
Old 01-10-2010, 09:36 PM   #159
protrash64
protrash64's Avatar
I continued my headlite deal that I thought I would finish in one afternoon. Here it is 3 weeks later.....at least the pieces are in place and I can continue sanding as I'm trying to get on a new coat of primer. Some drive time would be nice too.
I welded tabs on to the headlite buckets and made a heavy duty version of the factory mounting. Only took 3 trips to the hardware store and about 15 bucks worth of stuff. Imagine that!! I also included a pic of the core support with the clearance cut out............still one inch away from the inner fender panels. It all fits in nicely. I pulled it back apart to rattle can the various pieces on the back.
Old 01-10-2010, 11:35 PM   #160
Dinos63
chevy only
Dinos63's Avatar
nice work jeff!!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 01-11-2010, 08:12 AM   #161
tiggamonsta
tiggamonsta's Avatar
How do you plan to adjust the headlights aim? Do you have any pictures of this?
tiggamonsta is offline   Reply With Quote
Old 01-11-2010, 09:19 AM   #162
jason65
Registerd User
jason65's Avatar
Lookin good Jeff.
jason65 is offline   Reply With Quote
Old 01-11-2010, 09:34 AM   #163
lakeroadster
Looks like it was meant to be.
Do you think you will have to reinforce the inner fenders due to the clearance cuts for the lights?
Old 01-11-2010, 11:01 PM   #164
protrash64
protrash64's Avatar
The tabs I welded on the lite buckets will fit on 3 different lengths of bolts extending behind the grill support. I will use nuts to capture the bucket and make adjustments. There are some weird bends to deal with......
The inner fenders are not cut. I am still 1'' away in the uppermost corner. The core support is still solid, too.
Old 01-12-2010, 09:40 AM   #165
lakeroadster
So in this picture the notch that is shown (where you can see the front tire) is stock and uncut?
Thanks,
Old 01-12-2010, 10:07 AM   #166
protrash64
protrash64's Avatar
Thanks,
That is cut and its the core support.......the inner fenders are untouched with the exception of a small portion of the flange. It does not need reinforcement and is totally solid. Once I put the 40+ bolts back in it will not move at all. I was planning on welding square stock around the cut-out to reinforce but I can barely flex the metal by hand. I will then build a box to fit behind the lites and attach to the inner fenders and core support.
Old 01-12-2010, 11:20 AM   #167
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
It better be strong.....once you start juice'n that front end, you wouldn't want to leave the headlights behind....
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 01-12-2010, 11:23 AM   #168
lakeroadster
Now I see... thanks for the clarification.
Old 01-12-2010, 12:12 PM   #169
protrash64
protrash64's Avatar
.....let alone just all the weight!!!! Mite need a supercharger, too.
Old 01-12-2010, 03:45 PM   #170
MacAttack
283 Drama Queen
MacAttack's Avatar
Great looking work, Jeff! Nice pics.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 06-16-2010, 12:20 AM   #171
bama63
bama63's Avatar
great work protrash
bama63 is offline   Reply With Quote
Old 06-16-2010, 10:35 PM   #172
protrash64
protrash64's Avatar
Originally Posted by bama63 View Post
great work protrash
Thanx, this has been collecting dust after being distracted by my BBC install and now working 12 hours a day and weekends........someday it'll get there.
Old 06-21-2010, 07:32 PM   #173
shortbed70
shortbed70's Avatar
Dang glad to see your still tooling around with your truck. So your building a BBC for it? Give us info...
Troy
Big Red Dog build
Old 06-22-2010, 10:03 PM   #174
protrash64
protrash64's Avatar
Thanx Troy.......the BBC went in the 'burb. I havent touched the p/up in nearly a year. Hard to believe it's been that long.
Old 06-28-2010, 08:02 PM   #175
shortbed70
shortbed70's Avatar
I know what you mean I just went back through my build and though I would be done by now and actually said that in one post..Keep on truckin...
Troy
Big Red Dog build
