07-03-2014, 02:09 AM | #151 |
Re: 73-91 8-lug 19.5 22.5 24.5 Pics
Have you guys heard of http://nashvillewheelcompany.com/ they will custom cut a dually rim any size and bolt pattern.
07-03-2014, 05:57 AM | #152 |
07-03-2014, 08:05 AM | #153 |
they all are untill you mill them
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
07-10-2014, 07:07 PM | #154 |
my new wheels
07-16-2014, 07:49 PM | #155 |
Change decided to go matte black looks much better
08-08-2014, 07:13 PM | #156 |
70 SS 454 Monte 69 355 C-10 Shortbed 90 454 Crew dually 4x 76 454 Dually 2x 75 454 K5 77 468 Kona |
08-20-2014, 07:40 PM | #157 |
put the fronts on today.
08-20-2014, 08:33 PM | #158 |
hubcaps look nice havent seen those before only the ones inside the wheelnuts
08-21-2014, 02:04 PM | #159 |
08-21-2014, 04:49 PM | #160 |
08-21-2014, 07:59 PM | #161 |
personally i think the 24's are a little to big for a squarebody the sidewall on the tires you need to fit under the square tires just dont look right , they do look good on the newer trucks though with a bit more sidewall
still have a set of 22's i need to put on mine
08-21-2014, 08:23 PM | #162 | |
Long live SLIM ------------------ At least try to buy American |
08-21-2014, 09:00 PM | #163 |
08-22-2014, 03:09 AM | #164 |
It doesn't have the 454 in it anymore. It's 2wd also...
06-12-2016, 05:45 PM | #165 |
Got 3 wheels on of course last wheel has two froze lug nuts
06-12-2016, 05:47 PM | #166 |
Another shot
10-24-2017, 07:33 PM | #167 |
Mounted my P30 19.5's last week.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
05-20-2018, 08:07 PM | #168 | |
05-20-2018, 08:39 PM | #169 |
06-02-2020, 01:14 PM | #170 |
Just put a set of P30 wheels on the shop truck.
06-05-2020, 08:03 AM | #171 |
Great looking truck eye catching. That mirror must be all most out of mirror side clamp, or you extended your mounting rod
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
06-05-2020, 08:48 AM | #172 |
06-08-2022, 11:34 AM | #173 |
Where you guys finding the p30 steel 19.5s????
Todd |
04-20-2023, 02:08 AM | #174 |
05-10-2023, 04:11 PM | #175 |
22.5" cut to 22"
