Old 03-15-2010, 02:35 PM   #151
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: My 63 farm truck build thread
No powdercoated shaft for this truck fellas. I'm on day 8 of pneumonia. I'm not getting too much work done this week. Just getting the steering installed was all I was up to. Between going to work and resting, my shop time is down to just a couple of hours a day.
Old 03-15-2010, 02:59 PM   #152
DPowers
DPowers's Avatar
Hope you get to feeling better.
DPowers is offline   Reply With Quote
Old 03-15-2010, 04:18 PM   #153
SCOTI
SCOTI's Avatar
1613 & a poker face.... I won't tell .
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-15-2010, 04:28 PM   #154
Tx Firefighter
Funny thing is I know what you mean by 1613.
Old 03-15-2010, 11:07 PM   #155
Sam59
Flat Broke
Awesome truck man
Sam59 is offline   Reply With Quote
Old 03-16-2010, 10:36 AM   #156
MacAttack
283 Drama Queen
MacAttack's Avatar
Kevin, that's an outstanding bracket for the P/S pump! Never seen one before.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 03-16-2010, 12:53 PM   #157
SCOTI
SCOTI's Avatar
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-16-2010, 06:07 PM   #158
Charles Hettich
you got one of the nicest pickups on here. what camshaft is in that 327?
Charles Hettich is offline   Reply With Quote
Old 03-16-2010, 06:27 PM   #159
Tx Firefighter
It's a Comp 268 High Energy cam.
Old 03-16-2010, 07:42 PM   #160
LILRED66
LILRED66's Avatar
Nice work Kevin. The power steering conversion if a great upgrade and nicely done.
LILRED66 is offline   Reply With Quote
Old 03-16-2010, 07:53 PM   #161
Capt280
Capt280's Avatar
nice
Capt280 is offline   Reply With Quote
Old 03-16-2010, 07:57 PM   #162
Tx Firefighter
You just hang around in this area too much. That's just a stock 72 small block truck bracket set and pump I detailed and powdercoated.
Old 03-16-2010, 08:37 PM   #163
SCOTI
SCOTI's Avatar
And you do a fine job if I may say so.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-16-2010, 08:44 PM   #164
Tx Firefighter
Didn't I do a set of these for your truck awhile back ?
Old 03-16-2010, 08:54 PM   #165
SCOTI
SCOTI's Avatar
Yes sir. The set-up I have looks just as nice!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-17-2010, 10:48 AM   #166
MacAttack
283 Drama Queen
MacAttack's Avatar
I guess so! That's exactly what I need for my 65' Chevelle's P/S pump!
Old 03-19-2010, 03:22 PM   #167
Tx Firefighter
I'm sure everyone will hate the old man factor, but I needed a spare tire.
1/8 plate steel cut into a circle, bolt pattern template and two new wheel studs...
Mark and drill lug pattern holes, weld studs into two of them, build center hub out of 2 inch tubing with a stud welded in the center sticking out, then sandblast. For some reason, I was having an off day with the welder. Welders can be like women, wonderful most of the time, but pure hell 4-8 days out of the month...
I started to build something really trick here but finally decided to go old school with angle iron. I think this truck needs old school.
Powdercoated it real thick with two coats of clear powder on top. It's vein texture powder which explains to texture to it...
Welded a nut to the center of the 4 way lug wrench and powdercoated it with argent powder and two coats of clear powder...
Final product.
The reason the lug wrench is sticking out from the wheel like that is that I wanted to keep my options open so I have the ability to put an 8 inch rally wheel on the rack without the 4 way hitting the vale stem when I screw it into place. This wheel is a 6.5 inch van rally wheel.
I know it looks like an old man's truck with the tire mounted here, but I needed the spare secured and not laying in the bed all the time in my way.
Old 03-19-2010, 04:58 PM   #168
dean jendro
Old and crusty
dean jendro's Avatar
Kevin,
This has got to be one of the most interesting threads/blogs anywhere. You could probably write a book some day. When I get my 64 stepside on the road I think I'll drive it down to Texas and visit with you. With any luck I'll get done with it about the time I retire. Keep up the good work. I love the truck!
Dean
dean jendro is offline   Reply With Quote
Old 03-19-2010, 05:24 PM   #169
astrochimp
Nice.
Good to see someone put thought into what most think of as a simple part.
And good to see no bling, on that simple part.
David
astrochimp is offline   Reply With Quote
Old 03-19-2010, 07:10 PM   #170
joe231
joe231's Avatar
That is very cool Kevin!
I showed the wife and she digs it also.
Nice work!!
CHEVY ONLY
Old 03-19-2010, 07:12 PM   #171
JohnC
JohnC's Avatar
Normally I don't like spare tires in the bed, but with your truck, and the attention to detail it looks sweet!
JohnC is offline   Reply With Quote
Old 03-19-2010, 07:42 PM   #172
Thealien
Thealien's Avatar
excellant attention to detail!
Old 03-19-2010, 08:21 PM   #173
daxloves
daxloves's Avatar
Nice, I like it! Only one question tho. Why did ya drill all 5 stud holes and only use 2 studs?
daxloves is offline   Reply With Quote
Old 03-19-2010, 08:25 PM   #174
Tx Firefighter
No real reason. I was going to go down to O Reilly and buy some more studs but I didn't get around to it. Then I was running a big batch of parts through the oven so I wanted to go ahead and get my powder on my own parts while I had it running.
Old 03-19-2010, 08:38 PM   #175
Primered_69
Primered_69's Avatar
we ned a new side shot showing the spare tire
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
