03-20-2010, 11:39 PM | #151 |
Re: 79 GMC Sierra LWB 6.0L swap
looking good there chief
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
03-24-2010, 08:55 PM | #152 |
6.0L power.........
Making a little progress. Got the fuel system installed went with a walbro 255 external fuel pump with steel lines to the engine bay and rubber FI hose up to the fuel rails, new heater hoses got the return line on the power steering cut and ran, did I read in Bobs thread that there is a fitting on the back of the old P/S pump that will fit the new P/S pump and use the old high pressure line from the old P/S pump, is this right? I took this fitting out but have not tried it on the new pump. Got the brake booster vacuum hose installed, wired temp and oil pressure to gauges. Cleaned up all the wiring with new split loom and removed the wires I am not going to need. Still waiting on the harness and ECM from W4M. Trying to decided where to put the ECM and TAC. Got the gas pedal cut and welded like Bob did. I am trying to decide on headers now(thanks to seeing Dennis latest pics). I am going to run a 2 1/4" Y pipe to a 3" high flow CAT to a 3' single inlet 2 1/2 dual outlet Magnaflow muffler. I like the Y pipe that Dennis used. I think that is about it. Sorry no pics I'll try to post a video of first start!
What ever the mind of man can conceive......... he can achieve! My built thread http://67-72chevytrucks.com/vboard/s...d.php?t=375914 1979 GMC Sierra 6.0 L 4L60E 1995 Mustang GT 347 |
03-24-2010, 09:25 PM | #153 |
Never Satisfied
man you are close.
1973 4x4 Blazer- Parting Out 1986 LWB Silverado Undergoing LQ4/4L80E Swap '86 Build Thread:http://67-72chevytrucks.com/vboard/showthread.php?t=390566 |
03-25-2010, 10:35 AM | #154 |
i was reading and thinking the same thing
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
03-25-2010, 10:44 AM | #155 |
Slots go on anything!
I would go ahead and put the ECM underhood. Mine was shoved (not placed) behind the cluster, and it was a mofo to get to. It now resides under the hood.
1974 Jimmy- 5.3/4L80e/NP241 |
03-25-2010, 06:43 PM | #156 |
6.0L power.........
Yea it will be under the hood I got the OEM bracket for the ECM just don't where will be the best place to put it. I guess just mount it to the D/S inner fender with the TAC unit under it.
03-25-2010, 11:48 PM | #157 |
Still Learning
Your install is going too smooth! the engine totally looks like it came in the truck! Nice
03-29-2010, 06:49 AM | #158 |
6.0L power.........
Small update, but a money savings! My drive shaft fit like a glove. So I wan't need to spend money on adding to or shorting it, now I can better justify those S & P headers (thanks to Dennis) Need to run the trans cooler lines, tweek the shifter linkage to get it to work, finnish the P/S pump high pressure line, install the gas pedal, install wiring harness, TAC, ECM, radiator, fan shroud and fill all the fluids. Did I leave anything out? Then I can hear this beast run
03-29-2010, 08:20 AM | #159 |
man your almost there!
03-29-2010, 09:04 AM | #160 |
Formerly- 1972SuperCheyenne
Awesome, cant wait to hear it. Is everyone going to finish their swap before me?
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
04-01-2010, 06:40 PM | #161 |
6.0L power.........
Update: Got the harness and ECM back from W4M yesterday. Everything looks OK they replaced a couple of the connectors for the injectors and said everything else checked out OK. I started installing it and everything is going smooth. There are 3 wires that I need to hook up to switched power and 1 to the battery. It is the other wires that I am not sure of. I am making a list of the labels they put on them and I may need some clarification on some of them. The one that really confuses me is the data port I have has 6 wires but there is only 1 on the harness labeled data port. Anyway at some point I am going to rely on you guys for help. Thanks in advance. Just 1 more step closer!
04-01-2010, 07:14 PM | #162 |
Next project: 1970 K10
Go here:
http://67-72chevytrucks.com/vboard/s...postcount=1256 and open the first .PDF there. On the top of page three is the Data Link Connector, and it shows what pins need wired. You will only have 4 when you are done.... data, power, and 2 grounds. Give me a shout with any questions on the other wires.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 04-01-2010 at 07:16 PM. |
04-01-2010, 08:28 PM | #163 | |
6.0L power.........
04-01-2010, 09:12 PM | #164 |
at least you graduated... i'm still in 2nd
1 step closer buddy!
04-01-2010, 09:20 PM | #165 |
Never Satisfied
crap that put me back in preschool
04-02-2010, 02:58 AM | #166 |
OK I'll try to explain also as I just went through the harness 3 times. The serial data wire labeled goes to wire 2 in the obd2 connector, 4 and 5 are grounds and a constant 12v+ goes to 16. If you still aren't clear. Let me know. Looks great! Awesome progress!
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness! my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal: I'M SO SO CAL! |
04-02-2010, 06:44 AM | #167 |
6.0L power.........
Thanks I am determined to start this thing this weekend!! That clears up the data-port, do the grounds need to go to the chassis or just any good ground source?
04-02-2010, 11:10 AM | #168 |
Chassis is good, but make sure you have good chassis to body and body to engine grounds.
04-05-2010, 10:18 PM | #169 |
6.0L power.........
Well I haven't started it yet' but I'm a little closer. Just need to plumb in the steam pipe from the front of the engine, hook the trans lines up to external cooler and install radiator. The harness is in and all hooked up except for the fuse block and relays. So I still have a little before it will start. Weekend was a lot busier than I thought it would be.
04-05-2010, 10:30 PM | #170 |
Right on! where did you end up mounting the ecm?
04-06-2010, 06:23 AM | #171 |
6.0L power.........
Haven't mounted yet. Mocked it up on the inner fender with the TAC on the firewall next to the wiper motor. Really do not like the ECM on the inner fender I would like to put it under the battery, may try that this afternoon. I will post pics as soon as I decided.
04-06-2010, 09:22 PM | #172 |
6.0L power.........
OK Guys I have a 6 bank fuse block and this is how it looks. Do I hook all the W4M wires to the threaded post and the others to the spade terminal? I need your help! (sorry for the blurry pics) My confusion is the 12v all the time If I hook it to the threaded terminal all them will be hot? If that makes sense. Also what size fuse do I need?
04-06-2010, 10:23 PM | #173 | |
The best thing to do is list every wire and every component that will need power, determine or estimate how much current/amps it will draw, and will it require switched power, constant power, or ignition power. Then decide how to supply the power. Since I haven't even started on my swap yet, and haven't gotten to wiring, maybe someone can chime in on the exact fuse ratings to use. (I was just using an example) Hopefully I've gotten you started in the right direction. Travis Last edited by buckshot305; 04-06-2010 at 10:24 PM. |
04-06-2010, 10:28 PM | #174 |
Oh yeah, your truck is turning out great! Maybe I'll just drop my truck off at your house with a bed full of parts for a weekend! And a case of beer?
Travis |
04-07-2010, 06:27 AM | #175 |
6.0L power.........
Yea come on by, I have a case also, maybe two cases will get me thru this wiring. I understand the principle of it, just not sure how to excute. What size fuses was going to be my next question. The W4M harness has 4 12 ga wires 3 that say switched 12v and 1 that says constant 12v power and Bobs wiring diagram for the 4 bank block shows those 4 wires going to it. If I run a constant power to the threaded post it will give constant power to all 4 banks, how do I make three of them switched? I need another beer I'm getting confused
