Old 10-20-2010, 04:52 PM   #151
superflysteiny
superflysteiny's Avatar
Re: 66 DiBella (means of the beautiful)
Glad you guys like it. I am not really a sheet metal guy but I am learning as I go here are some more pics of what I finished last night. Thanks for the support
superflysteiny is offline   Reply With Quote
Old 10-20-2010, 05:02 PM   #152
superflysteiny
I got the inside of the core support shaved and half the fire wall
Old 10-20-2010, 06:34 PM   #153
VA72C10
VA72C10
VA72C10's Avatar
very nice!!! Are you shaving the wiper cowl also?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-20-2010, 06:37 PM   #154
superflysteiny
Yes I am going to shave it next week.
Old 10-20-2010, 10:32 PM   #155
VA72C10
VA72C10
VA72C10's Avatar
cool!
Old 10-21-2010, 11:39 AM   #156
superflysteiny
I did not get anything done last night. I was in bed by 8. I will be in the garage tonight. I will get you guys more pictures in the am. Thanks Eric
Old 10-25-2010, 07:39 PM   #157
superflysteiny
More pics in a few hrs, higes are mounted and the firewall and inner fenders are done. Thank god.
Old 10-26-2010, 09:37 AM   #158
67cheby
67cheby
67cheby's Avatar
hmm....... its been a few hours !!! wheres the pics ??
67cheby is offline   Reply With Quote
Old 10-26-2010, 11:34 AM   #159
superflysteiny
Sorry I forgot my lab top is getting fixed so I had to wait till this morning to down load the pics at work. I got the hood started last night. Had to wait till the kids went to bed before I started. So I did not get that much done. I am hoping to have this mod done by the end of the weekend. First pic is what the fire wall used to look like which is poop.
Old 10-26-2010, 11:36 AM   #160
superflysteiny
I plan on trimming the panel back on the front of the hood because the way it is set up right now the sheet metal will hit the top of the core support
Old 10-26-2010, 11:37 AM   #161
67cheby
67cheby
67cheby's Avatar
WOW ...looks killer , love the bottom of the hood
Old 10-26-2010, 11:44 AM   #162
VA72C10
VA72C10
VA72C10's Avatar
Looks good. Are you going to skin the rest of the underside?
Old 10-26-2010, 11:50 AM   #163
superflysteiny
Thanks, Like I said I need to remove some of the she metal under the hood because it will hit the core support. I am hoping to have the sides of the hood cut and on tonight but I will have to wait and see how much time I have.
Old 10-26-2010, 11:54 AM   #164
superflysteiny
I will have around 3 inches of sheet metal running down each side of the hood. Then I will box it in. Should be cool. I have decided to run 8 stack injection on this truck so I need some room under the hood
Old 10-26-2010, 12:09 PM   #165
superflysteiny
injection I am going with
Old 10-26-2010, 01:08 PM   #166
ajgriffin
ajgriffin's Avatar
Who's that made by?
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 10-26-2010, 01:11 PM   #167
superflysteiny
inglese
Old 10-26-2010, 01:24 PM   #168
ajgriffin
ajgriffin's Avatar
Gotta admit, I'm really diggin the look! Can you tell us (read as: me) how this works though. I'm not familiar with this type of system, but it looks like its electronically fuel injected, but uses these stacks as an extension of the intake?
If so that's pretty cool.
Anything you're willing to share about it would be nice, I'm considering something a little different like this on top of my big block, but am just starting the search.
Old 10-26-2010, 01:39 PM   #169
67cheby
67cheby
67cheby's Avatar
WOW....that inj system is AWESOME !!!!! AWESOME !!!!!
Old 10-26-2010, 01:46 PM   #170
superflysteiny
Correct the system has 8 individual injectors and the black tube down the middle of the system is the fuel rail. It used o2 sensors in the exhaust and a computer system called the fast ez to tune the engine. All you do is answer some quesions the computer asks you for your set up and it will self tune its self. You can also go into the computer and hook the lab top up and tune the engine yourself. Its a very cool system. Hilborn also makes a system very similar to this one but I like the way this system looks so I am going with this one.
Old 10-26-2010, 01:48 PM   #171
superflysteiny
The Inglese™ EZ-EFI® Induction Systems may look like classic Weber induction, but these technically advanced systems deliver increased performance, cold starts and drivability for your street rod, muscle car or restored classic. Additionally, they are capable of supporting engines up to 1000 hp and allow a much broader camshaft selection than a carbureted setup.
The new systems employ advanced FAST™ EZ-EFI® fuel injection and Precision-Flow™ Fuel Injectors (GM LS7-type) that are integrated into our exclusive cast aluminum 50mm IDA-style throttle bodies. The EZ-EFI® is a self learning fuel injection system that tunes itself as you drive and does not require the use of a laptop. Simply answer a few easy questions on the system’s hand-held unit. The EZ-EFI® controller will then use that information to establish the base tuning file, and then “learn” as you drive, while honing in on the optimum tune. It really is that easy. The EZ-EFI® can even be used with your existing distributor.
Old 10-26-2010, 01:50 PM   #172
67cheby
67cheby
67cheby's Avatar
So ....are you still trying to convince us that this is your wifes truck?? we havent seen her working on it once...... i think you are using her to cover up your " PROJECT ADDICTION"
Old 10-26-2010, 01:56 PM   #173
superflysteiny
You could say that again. She came out in the shop the other night to hold a few nuts while I removed the bolts from the firewall. I looked at her and said now you can tell everyone you built the truck. We had a good laugh. Anyways you are right I am addicted to this hobby. It really is like a drug. I think I need to check myself in.
Old 10-26-2010, 02:07 PM   #174
67cheby
67cheby
67cheby's Avatar
if you get checked in ....dont tell them about this website.....they will come take us all away, reminds me of a song " there coming to take me away ,ha,ha there coming to take me away "
Old 10-26-2010, 02:18 PM   #175
ajgriffin
ajgriffin's Avatar
So its a modification of the ECU from this unit?
