Old 11-26-2010, 09:55 AM   #151
Panelman55
Panelman55's Avatar
Re: SGTUSMC '59 build
Thank You for what you gave and what you were willing to do for this country!!!
I'm glad you made it, and hope you can keep up the good work. God Bless you and your family.
Panelman55
In God We trust!!!
Panelman55 is offline   Reply With Quote
Old 11-26-2010, 10:16 PM   #152
71'tahoe
71'tahoe's Avatar
SGT,
Is a 7" wide wheel the widest you can run up front? I got a spare 95' frame at the farm and Im curious as to how much clearance you have. Id like to run an 8" wheel. You think that would be possible?
Great build you have going on! It has me thinking about an 88-98 swap for my 58'
Thanks for any help you can give me!
Greg "GT" Tholen
71'tahoe is offline   Reply With Quote
Old 11-26-2010, 11:57 PM   #153
sgtusmc
sgtusmc's Avatar
Thanks guy's for the positive words.
Fat Mike- Sorry I missed your post about the wheelbase. I'll get that for you in the morning if you don't mind.
71'tahoe- Since the truck will be for my wife I was afraid to run a 7" wide wheel with bags so I went with a 15x5 rims from wheel vintiques. Now if she airs out with the wheels turned she won't kill the fenders. If your not going to lay running boards a 7" will work. I don't have an 8" wheel with a tire so I can't really say it would work or not. If it's low you might hit the fender at full lock (depending on tire size). You'll limit your tire choices with a 8". I'm happy I went with the swap. It's going a lot smoother than I initially thought.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 11-28-2010, 07:12 PM   #154
71'tahoe
71'tahoe's Avatar
Thanks for the info! Id like to try a 17x8/18x8 . Like I say,I've got and extra 95' frame Im going to try. I would have never thought of the swap if it wasnt for you. Thanks for the project thread!
Old 12-04-2010, 09:47 PM   #155
slick65
slick65's Avatar
great looking project! i have a 59 Apache that im building, only problem is its a long bed fleetside. i want it to be a short bed but cant find a bed around here at all. is there anyway that you can send me measurements of your bed so i can cut mine to length? id appreciate that a bunch! thanks again
slick65 is offline   Reply With Quote
Old 12-05-2010, 04:18 PM   #156
sgtusmc
sgtusmc's Avatar
Here's some measurements of the bed and track width.
This is measuring from the rear stack pocket to the front of the bed. I get 77 1/8".
From the rear of the bed, right at the round tail light pocket (without the tail light assembly installed) to the front of the bed following the body crease is 82"
My track width running a 155/80/15 on a wheel vintiques 15x5 rim (outer most part of the tire to the other) is 68 7/8"
There is 3" tuck from the tire to the wheel well.
Here's the 1988 seat sitting on the 59 seat tracks. It sits right under the rear window. With the 88 seat tracks the top of the seat (about 3") can be seen.
Old 12-05-2010, 08:01 PM   #157
slick65
slick65's Avatar
thanks a bunch, your a life saver. now mine goes under the knife next week
Old 12-05-2010, 09:14 PM   #158
entourageguy
Yellow truck club
entourageguy's Avatar
With the 88-98 seat on it's own track it come up to the bottom of the window on a small back window.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 12-05-2010, 10:12 PM   #159
sgtusmc
sgtusmc's Avatar
slick65- Your welcome. Let me know if you need anymore measurements.
entourageguy- I love the way your seat was upholstered, It looks great in your truck. I thought about cutting the 88 seat track riser down to lower the seat so it wouldn't be visible out the back window. It wouldn't take much to get the seat to mount to the 59 tracks.
Old 12-05-2010, 10:27 PM   #160
slick65
slick65's Avatar
its been like pulling teeth for those measurements or trying to find a bed. i have a nearly perfect long bed. it sucks that i have to cut it but im running out of options, and these long beds are HUGE! it seems way bigger than a normal long bed
Old 12-06-2010, 01:34 PM   #161
71'tahoe
71'tahoe's Avatar
SGTUSMC,
Thanks for the track width measurements! It will help me a ton! with those measurements Im sure I could fit an 8" wheel under the front! Thanks again.
Greg "GT" Tholen
Old 12-06-2010, 01:34 PM   #162
entourageguy
Yellow truck club
thanks for the comment about the seat.
I'm really enjoying watching your builds. I chuckled to myself about the welded tailgate on your latesed build.
Couple of friends have modified their seats as well by cutting wedges out to change the seat angle. I'm very happy with how the seat turned out. A guy that looked at the truck the other day made the comment " you can tell a boat guy did that seat".
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 12-06-2010, 02:25 PM   #163
Kabwe
Certified Car Nut
Kabwe's Avatar
entourageguy- I thought about cutting the 88 seat track riser down to lower the seat so it wouldn't be visible out the back window. It wouldn't take much to get the seat to mount to the 59 tracks.
Most people I know cut the 88 seat riser down to lower it for a big back window, but then again most every I know did not have the 55-59 original track or think of using it. Cool idea and cool truck keep up the good work man.
Kabwe is offline   Reply With Quote
Old 12-06-2010, 07:25 PM   #164
99 to Life
99 to Life's Avatar
that is awesome that seat fits in there perfectly. I used a 73-87 full size chevy bench seat in my 51' I mean it fits by the hair of someones chiny chin chin. I give chevy credit for keeping the same bolt pattern for all these years and also for these damn seats fitting so nicely. You gonna get a serape for it, or get it upholstered?
good work
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-06-2010, 08:21 PM   #165
Fat Mike
Fat Mike's Avatar
Thank you for the measurements!
Fat Mike is offline   Reply With Quote
Old 12-09-2010, 06:18 PM   #166
mr48chev
mr48chev's Avatar
Mike, remember that some of the extra length of the longbed is behind the wheel wells. It will have to be trimmed front and back to be right.
I hadn't paid much attention to this thread Sarge but this looks to be one of the better swap ideas around for this model of truck.
Old 12-09-2010, 08:56 PM   #167
OrrieG
OrrieG's Avatar
I thought I had replied on the bed shortening dims too. Here is a photo I attached to someone elses request that show the dim from the front to the wheel well. It shows 23" by my measurement. Like mr48 said, both ends need trimmed to center the wheel and wheel well.
OrrieG is offline   Reply With Quote
Old 12-24-2010, 12:11 PM   #168
subscribed.
Old 02-01-2011, 05:46 PM   #169
sgtusmc
sgtusmc's Avatar
Can I get your opinions on this? It's the stock '88 column with the '59 wheel. It's mounted higher up on the firewall to hide the wires and such. At this point it's just zip tied there. The column is at half tilt right now. At this angle I won't need to worry to much about u-joints. It's a straight shot.
Old 02-01-2011, 06:05 PM   #170
Fat Mike
Fat Mike's Avatar
Can you show a picture of where it would come out on the firewall.
Old 02-01-2011, 06:29 PM   #171
sgtusmc
sgtusmc's Avatar
Here you go. If I keep it, I'll shorten the column tube and leave the shaft at it's length. Here's a poor paint pic of what I'm talking about. The blue is the shaft, the red is the trans shifter moved up.
Old 02-01-2011, 08:20 PM   #172
Kim57
Kim57's Avatar
To me it looks fine. I think you're going to have to sit behind it and see how it feels in the different tilt positions.
Kim
Kim57 is offline   Reply With Quote
Old 02-01-2011, 08:48 PM   #173
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Kim
I'm thinking the same thing. Looking good buddy!!!
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 02-01-2011, 08:53 PM   #174
Kabwe
Certified Car Nut
Kabwe's Avatar
Thats about where mine is located and the only reason I was nervous is because I don't have my master cylinder on my firewall. I think yours looks fine.
Old 02-01-2011, 08:54 PM   #175
JML55
JML55's Avatar
I have mine come right below the bend in the fire wall and i still have to use one u joint. What ever works for you i think will be fine.
JML55 is offline   Reply With Quote
