Old 03-19-2012, 12:31 AM   #151
jimig1
jimig1's Avatar
Re: 55 2nd series
Got a little work done this weekend but of course UPS did not deliver what I really wanted but it will be here tomorrow. Got the electric choke for my carb and installed my shifter.
55 2nd series Chevy Pickup
2019 Chevy Equinox(Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
Old 03-19-2012, 12:36 AM   #152
jimig1
jimig1's Avatar
Re: 55 2nd series
Also here is the color I think I'm going to paint my motor (burnt copper). My wife hates the color but I told her she'll never look at the motor anyways. That is the color that I wanted to paint the whole truck but she nixed that.
MSRA Member
-George Carlin
Old 03-19-2012, 01:03 AM   #153
Kim57
Kim57's Avatar
Re: 55 2nd series
Looks good. I like the color.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-19-2012, 04:24 PM   #154
_Ogre
_Ogre's Avatar
Re: 55 2nd series
copper looks good.
pick a color you know she will hate and give her a choice
shop air compressor timer
Old 03-19-2012, 04:44 PM   #155
jimig1
jimig1's Avatar
Re: 55 2nd series
Thanks Kim and Ogre. I love that color the first time I seen it.
MSRA Member
-George Carlin
Old 03-20-2012, 12:27 AM   #156
jimig1
jimig1's Avatar
Re: 55 2nd series
Got the steering setup. Forgot to snap a pic of the final setup with the DD rod in place.
MSRA Member
-George Carlin
Old 03-20-2012, 01:03 AM   #157
drivea55
drivea55's Avatar
Re: 55 2nd series
man, that's some tight stearing linkage!
Copper color will be great! I likey
current project;
1950 GMC "Junk Yard Dawg"
http://67-72chevytrucks.com/vboard/s...d.php?t=635960
___________________________________________
SOLD to "ONEBADFIVEFIVE"
http://67-72chevytrucks.com/vboard/s...d.php?t=436406
drivea55 is offline   Reply With Quote
Old 03-20-2012, 08:57 AM   #158
jimig1
jimig1's Avatar
Re: 55 2nd series
Yeah it is tight but it is not binding up I'm still debating on getting different headers.
MSRA Member
-George Carlin
Old 03-20-2012, 09:09 AM   #159
Kim57
Kim57's Avatar
Re: 55 2nd series
Looks tight but if it doesn't bind it shouldn't be a problem.
Kim
My build thread
Old 03-20-2012, 11:10 PM   #160
jimig1
jimig1's Avatar
Re: 55 2nd series
I need some help. I pulled the motor out and started cleaning it up but I need to know if there is an easier way. I used a can and a half of brake cleaner just for the clean side. Any suggestions? Also how to get the rust off?
MSRA Member
-George Carlin
Old 03-20-2012, 11:57 PM   #161
Kim57
Kim57's Avatar
Re: 55 2nd series
I used simple green and a stiff brush to clean up mine. Use it full strength and let it soak for a while. It works pretty good.
A wire wheel should take care of the rust.
Kim
My build thread
Old 03-21-2012, 12:59 AM   #162
oldcouple
oldcouple's Avatar
Re: 55 2nd series
Use CLR, that's calcium lime rust remover, and wad up some aluminum foil or a wire brush. Hit with baking soda to neutralize it before you paint.
http://youtu.be/-UPO8aJh_6A
http://youtu.be/dqvDD_L7Y_M
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 03-21-2012, 10:21 AM   #163
_Ogre
_Ogre's Avatar
Re: 55 2nd series
my only parts washer is a gallon jug of mineral spirits from home depot and my oil drain pan
i have a stiff parts cleaner brush from parts store
i drill an 1/8'' hole in the lid so i can spray right out of the jug
mineral spirits is cheap, i maybe used 4 gallons over the years.
just recycle it with your used motor oil
Old 03-21-2012, 10:19 PM   #164
jimig1
jimig1's Avatar
Re: 55 2nd series
Thanks for the suggestions I'll be back at it tomorrow. Had my 3yr wedding anniversary tonight (I really wanted to work on the motor).
MSRA Member
-George Carlin
Old 03-21-2012, 10:30 PM   #165
Chevette
Chevette's Avatar
Re: 55 2nd series
Remember that your motor will torque over a bit when you stand on the throttle. You want to take that into account when thinking it's not going to bind up. Pictures can be deceiving, but it sure looks tight to me. I hope it works for you.
Chevette is offline   Reply With Quote
Old 03-21-2012, 10:32 PM   #166
jimig1
jimig1's Avatar
Re: 55 2nd series
That is why I was thinking about different headers.
MSRA Member
-George Carlin
Old 03-22-2012, 11:22 PM   #167
jimig1
jimig1's Avatar
Re: 55 2nd series
Well I got the motor cleaned up it is almost ready for paint a little more clean up tommrow and hope to be painting Saturday AM
MSRA Member
-George Carlin
Old 03-23-2012, 12:03 AM   #168
Kim57
Kim57's Avatar
Re: 55 2nd series
It came out nice.
What did you finally use?
Kim
My build thread
Old 03-23-2012, 08:55 AM   #169
jimig1
jimig1's Avatar
Re: 55 2nd series
I used Simple Green Pro HD Heavy-Duty Cleaner it worked good then I used a wire wheel on a drill to remove the rust and loose paint
MSRA Member
-George Carlin
Old 03-23-2012, 01:00 PM   #170
OrrieG
OrrieG's Avatar
Re: 55 2nd series
Simple Green rocks, we use it for everything, can't kill the cats and dog and easy on the environment, and my lungs. Soak, powerwash, move on...
OrrieG is offline   Reply With Quote
Old 03-23-2012, 01:05 PM   #171
jimig1
jimig1's Avatar
Re: 55 2nd series
Yeah it does. I bought a gallon of it and maybe used a quart an a half.
MSRA Member
-George Carlin
Old 03-24-2012, 11:57 PM   #172
jimig1
jimig1's Avatar
Re: 55 2nd series
Blocked Prepped and painted the color looks a little different in person
MSRA Member
-George Carlin
Old 03-24-2012, 11:59 PM   #173
jimig1
jimig1's Avatar
Re: 55 2nd series
More of it painted and new valve covers on
MSRA Member
-George Carlin
Old 03-25-2012, 12:01 AM   #174
jimig1
jimig1's Avatar
Re: 55 2nd series
More motor pics and intake installed.
MSRA Member
-George Carlin
Old 03-25-2012, 02:51 AM   #175
drivea55
drivea55's Avatar
Re: 55 2nd series
Lookin good!
Gotta luv simple green!
current project;
