12-04-2010, 03:33 AM | #151 |
Truck and auto performance nut
Re: Project -underfunded - '68 shortstep/carb'd LSx/200-4r build
Installed all the new steering parts (Inner/outer tie rods, adjusters - others where almost new) today. I also drilled holes for the brackets and installed the Trick Flow pre-filter and A/C (Carter) fuel pump, and the regulator to carb -8AN S.S. line with Russell inline filter. Now I have a better idea of what I need in the way of AN fittings to complete the fuel system. My -8AN S.S. hose and 1/2" hard line came with with red/blue fittings and I had black on the truck...so I'll be ordering some more black AN fittings and a little more -8AN S.S. hose...as well as a few more odds and ends. Getting ready to start on the electrical...which means at some point...putting the radiator support back on.
Pics to follow tomorrow............too tired.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
12-04-2010, 11:52 AM | #152 |
I am also thinking of installin my fuel system this week end. I Think i have gotten too small of hose. I got -6 that says good to 375 hp on a site i read. Also think my pump is too small at 105 gph. Cant wait to see pics.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
12-04-2010, 03:03 PM | #153 |
I also think my pump is too small. I was buying a bunch of genuine GM A/C Delco parts and thru in A/C Delco's street pump. Sitting next to the nice Trick Flow canister filter...it looks homely.
I think I may use it to get it going then replace it. I know yall like lots of pics so here yo go! New 3.5" .083 wall DOM steel Driveshaft is in. Still need to center up the rear. The shaft fits thru the CPP crossmember well, at roughly 80% weight/assembled? -8AN Russell "post" filter, fittings, and -8 AN S.S. hose: Steering is finally in with new Moog components. The outer tie rods have a bend in them that the originals didn't? And tho I'm running a carb'd LSx......my technolgy upgrades (1 of 2)... Ordering more plumbing and diggin in to the wiring....might start to install the 3" exhaust. I've missed SO many deadlines...but this thing WILL be running before Christmas...maybe even next weekend!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 04-16-2012 at 03:24 PM. |
12-04-2010, 03:26 PM | #154 |
VA72C10
nice progress and parts! Looks great!
Looking for a 67-72 swb or blazer project in or around VA. |
12-04-2010, 04:05 PM | #155 |
Lookin nice man
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
12-04-2010, 04:31 PM | #156 |
That pump is pretty small. How many gph is it? All looks great tho. I would like to have mine in by xmas to we will see i guess. Cant wait to here it running.
12-04-2010, 10:32 PM | #157 |
got some more done...need to take pics tho. Yes...I thought that pump was the 100gph model...but I think I wound up with the 72gph model. I'm planning on having to take it a bit easy in the beginning to limit parts breakage until I can afford to install a bulletproof trans, rear end, and driveshaft.
12-04-2010, 10:40 PM | #158 | |
12-04-2010, 10:53 PM | #159 |
Oh it is....and it should be fine....but its not a "race built 900hp rated TCI" or "2000hp API Big Brute" or something along that lines.
But really....if the rear is not replaced with a built Moser or Strange...it will get upgraded with bigger axles, c-clip eliminators, etc. and both slip yoke and pinion yoke upgrade to forged pieces and 1350 u-joints...along with possibly an even bigger drive shaft. Then the weak link is just the trans...and it will also be upgraded at some point. Heck.....I still want to pull out my front suspension and steering I just put in and put in a $2500-$3500 (or more) coilover/rack and pinion steer IFS!
12-05-2010, 12:20 AM | #160 |
My save power train ideas consist of......one tire fire...
12-05-2010, 12:34 AM | #161 |
What was I thinking?
Looking great!
Justin '68 C/10 Custom Long wide bed '78 GMC Sierra short wide Project: Second time around...'68 short wide http://67-72chevytrucks.com/vboard/s...d.php?t=423949 |
12-05-2010, 01:25 AM | #162 |
69' Chevy Stepside
Looking great! Your build is so clean! That AEM Air/Fuel Ratio gauge is the same one I'm bout to install in my truck except mine has the digital readout unfortunately.
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
12-05-2010, 12:23 PM | #163 |
Kvn1011
Front ifs? Nate has the new stage II setups.......
Posted via Mobile Device |
12-05-2010, 03:52 PM | #164 | ||||
Thank you sir! Quote:
12-05-2010, 06:52 PM | #165 |
If there is a posi of some kind it sure does not work. I will add a posi when i upgrade to a 14 bolt full floater down the line.....my end up being a very short line...
12-05-2010, 06:57 PM | #166 |
our TBSS has a 14 bolt with 4.10 posi. Its a semi floater though I think...the 9.5" version.
12-05-2010, 07:09 PM | #167 |
That is what i have now in it. Have not opened it up too inspect it but does not make noise so it will do for now.
12-07-2010, 02:03 AM | #168 |
going to have to cut down the front sway bar links...not enough cornering clearance. you can see how short they are already in the 2nd pic. I'll be taking 1/2" to 3/4" off...
swapped out the rubber for a S.S. hose from filter to pump. still thinking I'll change the pump. also added one for the booster...doesn't fit too well tho.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 04-16-2012 at 03:25 PM. |
12-07-2010, 03:07 PM | #169 |
nice. sus scribed
1971 LWB C10 - 5.3/350 1970 SWB C10 - 5.3/4l60 or 6.2/4l80 not sure yet 1964 malibu ss - ls1/4l60 http://67-72chevytrucks.com/vboard/s...d.php?t=382403 |
12-07-2010, 03:22 PM | #170 |
Under Construction
nice progress.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
12-08-2010, 01:16 AM | #171 |
thanks guys. made some more online purchases....everything (hose, fittings, etc) to finish the fuel system, Lokar throttle cable and bracket, Autometer Designer Black series oil, temp, and volt gauges and senders/adapters; plus hardware for trans lines. Doesn't sound like well over $400 does it?
Thats everything but brake lines, and a floor shifter or other solution (column shift).
12-08-2010, 04:16 AM | #172 |
69' Chevy Stepside
Great progress!
12-08-2010, 02:10 PM | #173 |
Thanks. I got a new trans crossmember yesterday that I'm getting ready to try out....so I can run the 3" exhaust inside the frame.
12-08-2010, 02:32 PM | #174 |
Excited to see the exhaust getting done
12-08-2010, 06:47 PM | #175 |
its funny.....until you really get under there and plan a system "within" the frame rails with long tube headers that hang slightly lower....
I had planned on the mufflers being before the trailing arm crossmember, along with an x-pipe ahead of it. Now it will be an h-pipe with the mufflers after the TA crossmember.
