Old 11-29-2010, 02:55 PM   #151
67C10BUB
67C10BUB's Avatar
Re: Silver Dollar
Those cables are a great idea that I never even considered. I may do the same thing once I get her running.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 11-30-2010, 10:06 AM   #152
mrhino
Re: Silver Dollar
front end
pick up a dual horn, at a local swap meet. $5 came with wire harness and 2 highs and two lows, one for each side but i only used one.
mrhino is offline   Reply With Quote
Old 11-30-2010, 09:12 PM   #153
mrhino
Re: Silver Dollar
the factory location for the battery on the newer Silverados is on the left side, and since I had the factory harness from a Silverado, I decided to move the battery location to the left side. So being the cheap ass that I am, couldn't see dropping 50 bucks for one out of the catalog. so I made my own.
went to the salvage yard and grab a tray from a 94 chevy or something like that for $5. I then cut the mounting tab off of the side and moved it to the rear of the tray
then cut a pie section out, so it would form around the inner fender, and I could bolt it from the underside for support. then welded in a piece of metal.
told you my welds are ugly, but no one will see it where this is going
ran it through the blast cabinet and then shot some paint on it.
drilled the holes in the fender well and the core support, as you can see i drilled one to many
bolted it up and then hook the cables up,
wish I had a side post battery, only but you work with what you got.
Old 11-30-2010, 09:37 PM   #154
67cheby
67cheby
67cheby's Avatar
Re: Silver Dollar
nice job on the battery
67cheby is offline   Reply With Quote
Old 11-30-2010, 11:15 PM   #155
mcbassin
Still Learning
mcbassin's Avatar
Re: Silver Dollar
Love the tray idea! I hope to use the same plan on mine since I'm going to keep as much as the original harness as possible. BTW, I am a cheap a$$ too.
mcbassin is offline   Reply With Quote
Old 12-01-2010, 10:43 AM   #156
eagleuh1
eagleuh1's Avatar
Re: Silver Dollar
Nice work on the battery tray. That was a good idea. It works a whole lot better with the battery over there.
eagleuh1 is offline   Reply With Quote
Old 12-01-2010, 12:36 PM   #157
VA72C10
VA72C10
VA72C10's Avatar
Re: Silver Dollar
nice job!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 12-01-2010, 03:00 PM   #158
mrhino
Re: Silver Dollar
Thanks guy's
Here are some shots of the engine.
Old 12-01-2010, 03:13 PM   #159
smokinstang70
smokinstang70's Avatar
Re: Silver Dollar
AWESOME BUILD!!! Great inspiration for my LS build... in works
Question... are you running a MAF meter?
smokinstang70 is offline   Reply With Quote
Old 12-01-2010, 03:39 PM   #160
mrhino
Re: Silver Dollar
No, I'm not. according to my programmer I dont need one if my engine is fairly stock.
Old 12-01-2010, 06:49 PM   #161
mrhino
Re: Silver Dollar
Called the wife and kids out to the garage, for this glorious moment. when I tried to start the engine for the first time, it wouldn't start or run. after a few minutes of me cranking, and some cussing. They must of got the feeling that the show was over. cause they all just slowly went back inside. (iv seen this before.) So now Im thinking to myself and resiting the 3 basics all engines need. First I checked ignition, with my timming light. every cylinder was firing. Next, shot some starting fluid down the throttle body, and it would start and run till the starting fluid burnt up. I Then put my fuel pressure gauge to it. it had pressure to the rail. Ok! What the hell is going on here. I posted the question on the forum got so good suggestions, and asked my PCM programmer, Brenden at LT1swap, He suggested I check the injectors, they might be cloged or "stuck" from sitting.
So I took out the injectors and put one in the vice Poured cleaner into the top of the injector. Made a simple wire harness, one side went to the power on the battery charger. The other I dragged across the negitive clamp on my charger. this resulted in the injector pulsing open and closed very fast instead of just staying opening.
At first I dint hear the injector pulsing at all but after a few minutes i started to get some nasty stuff out of it.
I went ahead and did this to all the injectors, then soaked them over night in cleaner. The next day, i had to run to the parts store for new injector orings. The cleaner had swelled them. should have taken them off but was sidetracked. After the orings were in I put the injectors back in the rail. i have a OTC injector cleaner, that will pressureize the rail to bypass the fuel pump for cleaning purposes.
So I hooked that up and used the same trick as I did on the bench and fired one injector at a time, this time with 55 psi behide them.
Sprayed cleaner through the injector into a little catch can a.k.a. wifes storage container (she let me keep that one). did that to all injectors till it looked like i had a good spray pattern.
Put all the injectors back in and fired the engine. she started and ran. it was a little loud with no exhaust but it was great just to her in run.
Old 12-01-2010, 06:53 PM   #162
mrhino
Re: Silver Dollar
And thanks for everyone's kind comments and praises, there are appreciated.
Old 12-01-2010, 07:05 PM   #163
VA72C10
VA72C10
VA72C10's Avatar
Re: Silver Dollar
Nice job on chasing down the issues! And Congrats!!!
Old 12-01-2010, 07:09 PM   #164
67cheby
67cheby
67cheby's Avatar
Re: Silver Dollar
sweet congratulations !!!
Old 12-01-2010, 09:10 PM   #165
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Silver Dollar
Very cool build! Congrats on a job well done! Your paint and body work looks very professional. You should be very proud!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-01-2010, 10:39 PM   #166
robzilla
robzilla's Avatar
Re: Silver Dollar
Originally Posted by mrhino View Post
Called the wife and kids out to the garage, for this glorious moment. They must of got the feeling that the show was over. cause they all just slowly went back inside. (iv seen this before.) .
it's amazing how the family know when the show is over
robzilla is offline   Reply With Quote
Old 12-01-2010, 10:50 PM   #167
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Re: Silver Dollar
I bet you are such a happy camper...congrats on the truck, you are getting close now, keep up the great work!
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 12-01-2010, 10:53 PM   #168
eagleuh1
eagleuh1's Avatar
Re: Silver Dollar
Good job on cleaning the gunk out of the injectors. What are you using for a power stearing pressure hose? I need to replace mine. Nobody local makes hoses any more. Thanks.
Old 12-02-2010, 12:06 AM   #169
tonypaul
tonypaul's Avatar
Re: Silver Dollar
Congrats on your startup! Brenden is the man! He did my programing on my 454 Vortec.
I got lucky and mine fire right up the first time. But a couple days later when I went to start it again it wouldnt start.... Luckly I found the problem (shorted power wire) and fixed it and it started right up again.
tonypaul is offline   Reply With Quote
Old 12-02-2010, 12:11 AM   #170
brossow
Amateur Rust Fighter
brossow's Avatar
Re: Silver Dollar
I had a similar question that he answered here.
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline   Reply With Quote
Old 12-02-2010, 12:21 AM   #171
spike38
spike38's Avatar
Re: Silver Dollar
Congratulation man, I know that had to feel great!!!!!
Spike
spike38 is offline   Reply With Quote
Old 12-02-2010, 10:06 AM   #172
mrhino
Re: Silver Dollar
I am extreamly proud, Ill show it off to anybody who will look at it. even tied up the fedex guy for 15min or so the other day, and you know how busy those guys are. I cant help but think of how the next one will look, now that I have at least a clue as to what im doing.
lol
happy and relieved.
Yes he is the man. Im glad there is people out there like him that share their knowledge.
Thank You and yes 73-up
Old 12-02-2010, 10:07 AM   #173
mrhino
Re: Silver Dollar
Spike
Awesome!
Old 12-02-2010, 10:49 AM   #174
menace121978
menace121978's Avatar
Re: Silver Dollar
hey Mike, i'm a little late to the party but i git a question... what is that relay for behind the battery on the core support? i just recently chopped off that huge hot wire that comes off the battery terminal thats going to your relay. (hope i didn't get carried away)
congrats on getting her up and running
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 12-02-2010, 02:06 PM   #175
mrhino
Re: Silver Dollar
Spike
thats my main battery feed for my wire harness. instead of running it of the alt or starter, I ran it thru a circuit breaker from the battery. Dont know if its any better or safer.
5.3, boss 338, house of kolor, lsx, tank
