#151 |
Old Guy
Re: 48 5 Window air ride driver
I got the truck running, everything seems to work fine only a couple bugs to work out. I won't be making it to Kalamazoo due to family commitments, but will be at the Rt.66 Festival in Springfield, IL at the end of the month.
#152 |
awesome can't wait to see it rolling. congrats.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#153 |
Old Guy
I finally got to attend an event with the truck last weekend, the Morris IL. monthly cruise night. The truck ran great and I was very happy that the heat worked on the ride home, as I wore a T shirt and the temps got to the mid 50's. I know in January that will feel like summer, but after the 90's we've been having around here it felt cold! Here's a couple pictures aired down in the grass.
#154 |
Oldnslow, looks great and glad it ran great for you. I am dreading the fall all ready, not ready for summer to be over.
Shannon Posted via Mobile Device
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
#155 |
truck looks great, congrats on the christening and everything went smooth. Yeah I love having heat in my truck, glad I went with an aftermarket non leaking unit, small and simple and reliable. Yeah totally not felling summer being just about over.
#156 |
Truck looks great. I can only say ... inspiring.
#157 |
Old Guy
Spring engine upgrade......ZZ383 Deluxe 450 HP /450 TQ going in this weekend, ordered drag radials!
#158 |
nice man, keeping it carbed I like that. what was wrong with the engine you had? just not enough ooommmph for ya?
#159 |
Nice Crate Stroker. Putting one in my 57 TF as well. Love the new Deluxe, bumping it to 450 - with manifold to boot! Are you going with the Holley 770 also? Jim
#160 |
Old Guy
The Vortec 350 that's in the truck runs like a *****, great oil pressure, cools good, but it smokes a little at idle when warm. It is a low mile engine removed from a wrecked Suburban, everything looked great when I pulled it apart, leaks down less that 5% on every hole, compression is 160 -165 across. I thought the intake gasket was allowing oil to be sucked in from the valley, so removed the Chinese manifold and added a new Edelbrock RPM air gap and tried again with the same results. I'm guessing that either the valve guides should have been replaced when the valve job was done or the oil rings are stuck / cashed. Guess I will know when I blow it apart, after the new one is installed. I'm using the same Holley 770 cfm Street Avenger carb on the 383.
#161 |
That should spin the boots no problem!
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() |
#162 |
![]() Join Date: Mar 2007
You might need to change your name to oldnfast..
Good luck with the install. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#163 |
Old Guy
Got the 383 in over the week end, now on to changing the standard Ford light 4.11 "chunk" to a Strange with 3.89 gears and adding Moser axles.
#164 |
AWesome build! Like what you did with the bed!
More horse power is always good!
1950 chevy PU work in progress. |
#165 |
Old Guy
The new engine looks a lot better with some shiny accessories.
#166 |
A320 Pilot/USAF Retired
Nice!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#167 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Looks killer!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#168 |
Old Guy
Running and driving with the 383, added inner fenders, almost ready for power tour!
#169 |
truck looks so awesome! is that gray primer or a flat gray paint?
#170 |
Old Guy
The truck is in DuPont DP50LF primer, thanks for the compliment!
#171 |
Old Guy
After all the talk for the last couple of years about doing Hot Rod Power Tour I finally did it this year. We went to the Goodguys show in Indy Fri, Sat and Sunday, took a tour of the Auburn/Cord /Dusenburg Museum on Monday and picked up Power Tour on Tuesday in Norwalk, Ohio. Wednesday on to Crown Point, Indiana, Thursday Bettendorf, Iowa and Friday, Wisconsin Dells. The truck ran great, I installed a new speedometer when the crate engine was installed, changed out the break in oil with 175 miles on the odometer and headed out. We returned with 1700+ miles on the odometer, these things are WAY more fun to drive than to use as garage art, as I had for several years! I took a lot of pictures, not many of the truck but here are a couple.
#172 |
![]() Join Date: Mar 2011
Glad you had a good time, I've always been the type to drive em. Continue to enjoy your great looking truck...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#173 |
sweet congrats.
#174 |
![]() Join Date: Jul 2012
Awesome trip you took. Truck looks good!
#175 |
Glad you had fun. It was nice meeting you in Norwalk.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
