Old 07-20-2011, 06:31 PM   #151
parkwood
parkwood's Avatar
Re: slamburban
Originally Posted by fredscarryall View Post
welded up some holes in the dash, so i can get it ready to paint
Fred you came by and said some nice things about the suburban i did and i got time to read through your build today..
You've have done some nice work, and we did do some of the samethings but i might have went a little over board on some..
Not sure you can see or not but i mounted the air tanks on the outside of the frame rails on ours and put a pump in front of each one.. saved a little on running lines every where and gave a little more room in the middle..
You did a nice job with the rear end set up even though you had to raise the floor. you'll have to let us know how it rides..
What are you going to do for interior??
Parkwood
parkwood is offline   Reply With Quote
Old 07-20-2011, 11:49 PM   #152
fredscarryall
fredscarryall's Avatar
Re: slamburban
ya,thats a really good way to run the air tanks. i used airbagit.com and i wish i would have done air ride tech.it looks like a better set up. as far as the interior. it didnt come with any seats. i am using 4 1972 chevy blazer buckets and two mid 2000s f150 center consoles. as far as the inside panels.it used to be a shrinners bus years ago and had two side mounted fold down benches which damaged both sides really bad. so the plan is to paint the upper half above the factory interior panels blue and vinyle the lower half.and put in a foam backed headliner like new cars have,but thats still up in the air.
fredscarryall is offline   Reply With Quote
Old 07-21-2011, 12:00 AM   #153
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Re: slamburban
hey fred your burbs lookin killer.you and charlie are kickin a**.i have my third row seat that we are not going to use if your interested.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 07-21-2011, 12:59 AM   #154
fredscarryall
Re: slamburban
chizzler, how yours coming along. i should have mine hopefully on the road by the end of the month.
Old 07-21-2011, 01:10 AM   #155
fredscarryall
Re: slamburban
here are some pics of the seats and rear center consol/buddy seat. they are really dirty from sitting in my garage but i had them redone last year.
Old 07-21-2011, 01:20 AM   #156
parkwood
parkwood's Avatar
Re: slamburban
fred this suburban was a school bus but didn't have any damage on the side panels... but if you see how the guy who did the interior covered the side panels i think is what you're talking about.. he put wood up on the roof and then glued foam to that and shaped it when covered it.. came out nice..
Old 07-21-2011, 10:54 PM   #157
fredscarryall
Re: slamburban
charlie got the drivers back inner wheel well almost all welded in.he just needs to do some finish welding. then copy it on the passanger side.after some grinding and painting, it will bolt to the floor like it was factory. he cut and sectioned it so i could get my seats to go back about 8 inches for more foot room.
Old 07-21-2011, 11:46 PM   #158
oldman3
oldman3's Avatar
Re: slamburban
Looks real good....Jim
oldman3 is offline   Reply With Quote
Old 07-28-2011, 01:33 AM   #159
fredscarryall
Re: slamburban
got the inside,dash,jams and the doors painted
Old 07-28-2011, 01:45 AM   #160
fredscarryall
Re: slamburban
more pics
Old 07-28-2011, 01:49 AM   #161
parkwood
parkwood's Avatar
Re: slamburban
Fred, that's looking good.. what car is that blue off of or is it a special mix..??
Old 07-28-2011, 01:57 AM   #162
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
Re: slamburban
looking great as always, are you planning on running the classic visor on the windshield?
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 07-28-2011, 10:53 PM   #163
fredscarryall
Re: slamburban
steve the glass worker got the glass in today. now i can put in the visor,but i bought it from somewhere back east and it got caught in a hail storm. so i got some body work to do on it first.the blue color is something i picked out of a catalog.
Old 08-02-2011, 10:48 PM   #164
fredscarryall
Re: slamburban
got the front seats mocked up. i used a center consol seat out of a 2000 dodge dakota and to let passangers in the rear i got a fold forward seat out of the second row of a 1994 chevy lumina van.all i have to do now is drill holes and run u bolt in the floor for the van seat.then redo the seats and consol to match the rest.
Old 08-02-2011, 11:14 PM   #165
fredscarryall
Re: slamburban
got the steering column and steering shaft in. i used a chrome exhaust tip to cover up the ugle column end that stick out throught the firewall.
Old 08-03-2011, 12:15 AM   #166
fredscarryall
Re: slamburban
it goes to get rewired on the 15th.i got to start getting real busy. i have a ton of small things to do.
Old 08-03-2011, 12:34 AM   #167
VA72C10
VA72C10
VA72C10's Avatar
Re: slamburban
nice progress!!! I really like the exhaust tip idea!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 08-03-2011, 01:34 AM   #168
oldman3
oldman3's Avatar
Re: slamburban
Moving right along and looking good....Jim
Old 08-12-2011, 12:18 AM   #169
fredscarryall
Re: slamburban
installed the grant telescopic tilt wheel adapter. descided to use the center lower part of the dash for two cigerette lighter ports and three push pull switches for my fog lights, halo lights and city lights. installed the fuse panel in the glove box.also had jute glued on the floor. tomorrow the carpet and seats go in and we set it on the ground.i ran the motor for about 5 minutes yeasterday, it sound real good.
Old 08-12-2011, 12:29 AM   #170
tantrumpipeline
Re: slamburban
Looks great, you work super fast!! the muffler tip idea is a great compliment to that engine bay, where's the video of the running motor
20 Duramax tow pig
52 short project
Old 08-16-2011, 12:18 AM   #171
fredscarryall
Re: slamburban
carpet and seats
Old 08-16-2011, 12:21 AM   #172
fredscarryall
Re: slamburban
on the ground
Old 08-16-2011, 12:22 AM   #173
bjcaldwe
bjcaldwe's Avatar
Re: slamburban
nice
My AD Truck Build Thread
52 GMC one day laying on the running boards
2004 Chevy Crewcab. 3/5 and notched
bjcaldwe is offline   Reply With Quote
Old 08-16-2011, 12:22 AM   #174
fredscarryall
Re: slamburban
more pics
Old 08-16-2011, 12:25 AM   #175
fredscarryall
Re: slamburban
off to get rewired
