Old 12-05-2011, 09:07 PM   #151
BBcj8
BBcj8's Avatar
Re: I think i can!!! - SWB 72 Step-side
Good luck nice build.
67 C20 CST long fleet SB 327
69 Chevy swb stepside BB 396
82 Jeep Scrambler Crawler BB 427
2008 CCLB Duramax Toy Hauler
To many big dreams.
BBcj8 is offline   Reply With Quote
Old 12-05-2011, 09:34 PM   #152
CheyenneShop
CheyenneShop's Avatar
Nice work on this one!
72 Cheyenne shorty "CheyLow"
72 3/4 long 4X4
69 SWB "Prospector"
68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled"
Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
CheyenneShop is offline   Reply With Quote
Old 12-05-2011, 10:35 PM   #153
Hduramax
Hduramax's Avatar
Build is looking sweet, keep up the good work, I like the trailing arms, was thinking of doing the same to my truck
2008 HD
2010 Camaro 2ss (The Wife's Ride)
2005 Suzuki GSX-R 1300 "Busa"
1969 C-10 (under Construction)
2013 Sonic LT
"LIVE LIFE,TASTE DEATH"
Hduramax is offline   Reply With Quote
Old 12-06-2011, 07:40 PM   #154
bmfpeterson
bmfpeterson's Avatar
Dude this truck is so ****in cool!
bmfpeterson is offline   Reply With Quote
Old 12-06-2011, 08:07 PM   #155
dnd1978
dnd1978's Avatar
Thanks guys. I need all the motivation I can get. I’m hoping to have it done by Cruising the Coast 2012. By done i mean drivable because i think there never done.
________________________________
1972 SWB stepside pro tour build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=452840
dnd1978 is offline   Reply With Quote
Old 12-11-2011, 02:33 PM   #156
502ms
502ms's Avatar
Wow! I love it!I've watched your YouTube vids so much...did not know you were on here!
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 12-11-2011, 09:45 PM   #157
dnd1978
dnd1978's Avatar
502ms,
Thanks, Its been so long since i driven it or even heard the motor i watch them somtimes too. HAHA
Old 12-11-2011, 10:05 PM   #158
dnd1978
dnd1978's Avatar
Guys just a quick update and some picture of my help this weekend. Thanks Dad!! We got the cab completely stripped except for the ignition switch. How do you remove it?
Old 12-12-2011, 04:02 AM   #159
ZUBZ
ZUBZ's Avatar
Lovely truck, damn I love the sound of it......gives me chills....
ZUBZ is offline   Reply With Quote
Old 12-12-2011, 07:18 AM   #160
lolife99
67-72 parts collector,…
lolife99's Avatar
http://67-72chevytrucks.com/vboard/s...light=ignition
Keith
Convert to disc brakes.
Old 12-12-2011, 11:15 AM   #161
dnd1978
dnd1978's Avatar
A couple old videos
When i first install the air ride
This video is after I redid the dog house, new wheels and new 383 stroker
Old 12-12-2011, 11:36 AM   #162
dnd1978
dnd1978's Avatar
Thanks lolife.
Old 12-18-2011, 08:09 PM   #163
dnd1978
dnd1978's Avatar
Switching gears a little, back to the cab. I’m sending it off to the paint shop, so I had to finish a couple projects before it leaves. I shaved the back wall of the cab and the dash, plus cleaned the fire wall a little.
Old 12-18-2011, 08:14 PM   #164
dnd1978
dnd1978's Avatar
pics
Old 12-18-2011, 08:50 PM   #165
dnd1978
dnd1978's Avatar
one more time!
Old 12-19-2011, 01:29 AM   #166
VA72C10
VA72C10
VA72C10's Avatar
smooooooth
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 12-19-2011, 10:31 AM   #167
67cheby
67cheby
67cheby's Avatar
great progress !! back of cab looks killer !
67cheby is offline   Reply With Quote
Old 12-19-2011, 12:16 PM   #168
orngsikL
orngsikL's Avatar
nice!!
build thread - 1972 C/10 "Ethyl"
1974 C/10 " Paw Paw"
C/10 Club Louisiana
instagram -
@esso_c10
@projectpawpaw
orngsikL is offline   Reply With Quote
Old 12-20-2011, 11:19 PM   #169
giles70chevy
giles70chevy's Avatar
I made some progress this weekend but it does not feel like much. I hope this holiday weekend will be way more productive.
I figured out my rear shock mount plan. I bought the upper mounts plates from No Limit Eng. The lower mount on the trailing arm is home made.
I got the rack kit mounted but ran into a lot of problems with Step 13, the bearing mounting. I will get it next weekend.
How do you like the way the rack and pinion unit fit in there? I see you didn't have to notch the frame. Just got my X-member tached together this weekend. I was wanting to keep the stock steering (haven't moved mine forward like yours.....yet), but..........I like the look of the R&P unit, and I'm thinking it's going to handle a lot better than the stock stuff......
giles70chevy is offline   Reply With Quote
Old 12-21-2011, 02:56 PM   #170
chevyrestoguy
chevyrestoguy's Avatar
You might want to check,... But I'm sure the CPP upper a-arms are on the wrong sides.
(the straight tube goes in the front)
The upper balljoint should be closer to the front of the truck.
Here's a picture from a Classic trucks Tech article.
http://www.classictrucks.com/tech/10...s/viewall.html
They also install the balljoint on the bottom side for some reason.
When I first saw the picture showing the view from the top down, I thought the same thing about the arms being swapped. What caught me was the noticeable offset between the upper balljoint and the lower balljoint. But then my brain started thinking................
We are always trying to gain caster to make the trucks go down the road better and to also help in the handling department. That picture sure looked like the swap moved the balljoint to the rear, thus gaining caster. Now, I'm just commenting from my computer, but COULD the arms be safely swapped from side to side to gain caster, or is this idea not physically possible because of other elements like balljoint angle, possible ackerman issues, or A-arm forward-to-aft angle? Just food for thought, and I would love to hear any comments on this idea.
Also, the picture from Classic Trucks showing the balljoint bolted on from the bottom seems wrong to me. Unless there's no physical way to bolt them in from the top, it seems to me that every factory balljoint I have ever seen was installed from the top side, not from the bottom. Maybe CCP designed their arms with the balljoint to be installed from the bottom side only? Just seems weird to me.
You are doing a GREAT job on this build! I really like your "no fear" attitude and the ability to tackle anything head-on!!!! I'll be watching this one, for sure.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 12-21-2011, 05:04 PM   #171
tubbedII
needs more $$$
tubbedII's Avatar
I need to start frequenting the build forum more often...I can't believe this thread has been here all year and I'm just seeing it the 1st time today! I ready through all 7 pages and it's coming out great! Keep it up!
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 12-21-2011, 10:52 PM   #172
dnd1978
dnd1978's Avatar
Originally Posted by VA72C10 View Post
smooooooth
Originally Posted by orngsikL View Post
nice!!
Thanks guys for the motivation! I’m getting excited about the progress. Im starting to see the light!! Merry Christmas
Old 12-22-2011, 10:51 AM   #173
dnd1978
dnd1978's Avatar
Giles70chevy,
With the x-member sectioned I had to add some tabs onto the top of the x-member to bolt the rack unit bracket on. Also where the steering rod goes though the frame was a little tricky due to the sectioning and forward movement of the x-member. All and all I’m happy with the kit. Good luck on your project.
Old 12-22-2011, 11:43 AM   #174
dnd1978
dnd1978's Avatar
chevyrestoguy,
Thanks! This is my first build and I have learned a lot plus I’m hooked. I really enjoy the Fabrication part of building.
With the a-arm flipped around you would gain too much caster (way to much). When the a-arms where switch around (the wrong way)the spindles where laid back so far that the steering stops would hit the a-arms, stopping it from making a complete turn. After I reversed the arms this problem was gone and you could see the amount of caster was way less. I’m shooting for 8-9 deg. of caster when done. The Cpp arms have 4 deg caster build in and I’m hopping for another 4-5 deg. by moving the a-arm mounts on the X-member back .5'.
About the ball joints I’m not sure. I will just mount them like the stock arms. I will drop Jeff at cpp a message about this and see what he says.
Later
Old 12-22-2011, 12:50 PM   #175
chevyrestoguy
........ I’m shooting for 8-9 deg. of caster when done. The Cpp arms have 4 deg caster build in and I’m hopping for another 4-5 deg. by moving the a-arm mounts on the X-member back .5'.
I like where you're going with this. I am planning on the same thing on the upper mounts. I am also doing a mod on my stock lower arm that will gain some additional caster. I am dropping the parts off to the machinist today. I'll update my '64 build thread as I progress on that mod.
My build threads:
