06-06-2014, 07:36 AM | #151 |
Re: Captain America 68 short/fleetside
Anything new with the Captain?
06-06-2014, 01:03 PM | #152 |
My friend and i are building a tonneau cover for the bed. I'll post pics as it happens. Right now, it's a pile of scrap aluminum. Not very photogenic.
-Josh
1967 Buick Special wagon 1968 Jeep Wagoneer 1958 Chevy Panel Truck 2017 Suzuki M109R |
06-06-2014, 01:15 PM | #153 |
So I am getting closer to my swap. You used entire wiring harness from donor right? If so, you attached it to the headlights, tail lights and all right? How hard was that? Did you just use butt connectors?
06-06-2014, 01:19 PM | #154 |
I'm interested in the aluminum bed cover, I'm thinking about doing the same thing. What thickness are you going to use?
My 68 Stepper build |
06-06-2014, 03:07 PM | #155 | |
I used all the wiring from the donor truck. -Josh
06-06-2014, 03:19 PM | #156 | |
It would be nice if the headlight bulb sockets and all from the 01 would just go right in my 87 lights! You didn't have to fool with power windows or locks or anything like that did you? What did you do for heat or ac? |
06-06-2014, 03:41 PM | #157 |
I have manual doors and windows, so no fooling with that. No AC in my truck, and i use the factory controls to run the heater fan.
-Josh
06-06-2014, 04:19 PM | #158 | |
Keep in mind, we're using scraps groom reroofing trailers. -Josh
07-04-2014, 01:37 AM | #159 |
Update time. Been busy with the rear section of the Captain. I wet sanded the tail lights with 1200 grit, masked off the centers and blacked out the edges of the taillights to match the bed. Then I used the nightshades to black out the taillight lenses, then wet sanded it so it was safe to drive with. Plus sanding them too the shine off, so the taillights are flat black like everything else.
-Josh
07-04-2014, 01:41 AM | #160 |
Then I mounted the taillights and swapped beds.
-Josh
07-04-2014, 01:44 AM | #161 |
And here's how they light up. I have to make a spacer for the hitch receiver to clear the new roll pan. Also have to make the fuel fill just a tad longer. I frickin love the lights on this truck!!!!!!
-Josh
08-01-2014, 11:17 PM | #162 |
Just an update with the Captain. I've been on two road trips, one to West Virginia, and one to Chicago with the truck without any issues.
On the West Virginia trip, I had my motorcycle in the bed, used the Tow/haul button and was getting 16-18 mpg. On the Chicago trip, we held her steady at 80 mph and never got less than 16 mph. -Josh
08-02-2014, 12:10 AM | #163 |
Well you can't complain about that!
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
08-10-2014, 11:07 PM | #164 |
I picked up some new wheels for the Captain today. 20x8.5 Factory GMC Sierra wheels. I need 2 in spacers for the rear, and 245/35r20 tired for the front and 245/40r20 tires for the rear to make them fit, but I picked them up for $250.00!!
-Josh
08-11-2014, 07:26 AM | #165 |
The spacing up front works for those wheels? I was thinking you would need spacers all around.
08-11-2014, 09:51 AM | #166 |
I have some spacers that I didn't use for my 67 you can try'um and if they fit Ill make you a deal you can't refuse.
08-11-2014, 02:18 PM | #167 | |
-Josh
08-11-2014, 02:40 PM | #168 | |
-Josh
08-11-2014, 04:33 PM | #169 |
If the fronts work without spacers I would be tempted to get some nice late model wheels and run to pick n pull and get a 99+ disc brake rear end. I think they are under $200 out the door. That would put the back spacing right and get disc brakes on the cheap.
08-11-2014, 10:16 PM | #170 |
Home most of the time just give me a call or txt, Ill PM you a number.
08-12-2014, 01:43 PM | #171 |
I got the super singles for the rear with 445/50's, now I just need standard alcoa fronts.
08-20-2014, 11:27 PM | #172 |
I just saw this 99 Z28 dash in the stock housing and thought of you.
Did you find some spacers and get the rims on? Pretty cool
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour Last edited by colgad; 08-20-2014 at 11:29 PM. Reason: added txt |
08-21-2014, 06:50 PM | #173 |
Yes, I ordered my 2 inch spacers last night, and they were waiting for me when I got home from work. Pics to follow.
-Josh
08-21-2014, 07:50 PM | #174 |
As pretty as the spacers are, they are wrong. I double-checked to make sure I didn't order the wrong ones, since I had a few options in my Ebay cart. Sure enough, I ordered the 2 inch spacers 6x5.5 to 6x5.5 with 7/16-20 studs and the large center bore. The ones I received are 14mm 1.5 studs with small center bore.
You can see about 1/4 inch gap at the back of the spacer, because it doesn't clear the center bore. My dad suggested a fitment test regardless, to see how close the 2 inch spacers were to being correct. On wheel pic is with the suspension aired up, and the other is suspension dumped. Mind you, there are 305/50R20 tires on the rims, and they bottom out in the fender well before the suspension settles. I"ll be running 245/40R20's in the rear. -Josh
08-21-2014, 07:54 PM | #175 |
And here are pics of the inner and outer sidewalls off the tire with the suspension up (first two pics), and suspension down. There's quite a bit of travel side to side when the suspension drops. I'm thinking I might have to get the adjustable panhard bar that goes from the frame to the passenger trailing arm. I have the adjustable bar for the stock location, but it's allowing too much lateral movement I guess.
-Josh
