#151 |
![]() Join Date: Oct 2011
Re: 1968 redo
Trying to get it started. Not getting fire from new coil. We are trying to run it down, spent the entire day yesterday doing that. I was hoping to get it going, so we could move on to painting doors and exterior of cab today, then all that would be left is the bed. I have a bed lift and stand for it. Planning a spraying bedliner inside bed. The tailgate needs some work before it is painted, but it is doable. It’s not in bad shape, it’s just that heavy gauge steel that will take a little extra coaxing.
I tore up my shoulder and am having a shoulder replacement in 3 weeks. This has significantly slowed the project down as I am down an arm. I posted a thread on the main forum about my coil problems for suggestions and criticism. Any help is appreciated.
Joey |
#152 |
![]() Join Date: Jan 2007
Re: 1968 redo
Nice job on the steering wheel
Project "C10 Fever" (68 factory black 396 swb) Project “Faded Glory” (71 c10 med bronze original paint refresh) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#153 |
Re: 1968 redo
Little by little. We adjusted timing today and the distributor would not turn enough to get it in time. The distributor was hitting those ribbed pushrod covers. Had to remove distributor and grind some of those ribs down to allow for clearance. Got it fixed.
Paid for my monojet rebuild at a carb shop, after warming up to operating temp , gas is pouring out of the bottom of carb after it runs for a bit. I assume it is the float sticking because I can tap it with a screwdriver handle and it stops. Installed a new alternator and the belt is loose. I’m using the original belt. Wondering if the pulley on my old alternator was bigger. It turns and charges, but needs to be tighter. Probably will modify the bracket to add length.
Joey Last edited by Dude68; 04-23-2025 at 07:02 PM. |
#154 |
Re: 1968 redo
Carb woes, leaks at gasket first then starts dripping out of hole below and to left of mono jet stamp
Joey |
#155 |
Re: 1968 redo
I adjusted float down to 1/4 inch in the bowl, also noticed a little t of debris getting through the filter in the carb. Cleaned the bowl, needle and needle housing out, also disconnected the pump to carb fuel line and gave it a good cleaning. Hooked everything back up and it started missing, but no leak. It even missed at high idle. Today it fired up without the miss, no leak, timing going, water temp good, oil pressure good. I guess the air in the fuel line may have caused the miss until it bled out.
Ready to make ve on to next step.
Joey |
#156 |
Re: 1968 redo
You ruined a nice, ribbed lifter cover by grinding on it?? All you had to do was remove the distributor and re-clock it a tooth or two.. As for the dripping, leaking carburetor, you probably have trash in the tank, fuel pump, and fuel lines.. Clean out everything, re-set the float level, and install a quality (not one of those clear glass or plastic) filter between the tank and fuel pump.
#157 |
Re: 1968 redo
Yes, it looks terrible. Did not know re-clocking it was an option.Here is a pic.
Joey Last edited by Dude68; 05-01-2025 at 03:49 PM. |
#158 |
Re: 1968 redo
You need to plug that vacuum port on the intake also. Huge vacuum leak
Eric 68 Anniversary Gold C-20 LWB to C-10 SWB build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=637492 It's hard to explain puns to kleptomaniacs because they always take things literally. |
#159 |
Re: 1968 redo
I have PCV valve on that now.
I have the vacuum advance hose connected to the vac port on the carb just above that. Vacuum advance is not working. I have vacuum from that port. I pulled vacuum advance of and it moves, but is very stiff, so I ordered a new one. Had to extend alternator bracket this far. I’ll be looking for a longer bracket.
Joey Last edited by Dude68; 05-01-2025 at 03:04 PM. |
#160 |
Re: 1968 redo
Went back with original in cab setup for fuel tank.
Joey |
#161 |
Re: 1968 redo
We replace vacuum advance today and that is the end of the timing not advancing as it should problem..
Started sanding cab looking for hail damage and began the tedious task of removing all of the caulk out of drip rail. I had stated that it was very rusted in a previous post, come to find out the caulk was seriously buckled in the drip rail an I thought I could see rust under it. Turned out to be primer not rust. Got it removed and applied a rust inhibitor to the shiny rail followed by a seam sealer. Don’t see any hail damage, but we gonna mist it black and block it down to check for dings. I fell the other day and tore up my shoulder, shoulder replacement today. Stay tuned, gonna be a bit before I can work some more.
Joey Last edited by Dude68; 05-06-2025 at 08:39 AM. |
#162 |
![]() Join Date: Jun 2002
Re: 1968 redo
Nice work, I think I'm going to do something similar to my cab.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
#163 |
Re: 1968 redo
My seats are done. Headed to Ricks Custom Upholstery next weekend to get them. Stay tuned....
Joey |
#164 |
Re: 1968 redo
Looking forward to seeing how it turned out
#165 |
Re: 1968 redo
Hey dude, how are things going? Still working at it?
| Bookmarks |
