08-11-2012, 12:12 PM | #151 |
Re: 1978 GMC Sierra C35 "Project Second Life"
Agreed... Do the spindles & cut 1 coil max. Adjust the rear from there if necessary. Anything taller than a 28" front tire & you'll be removing the inner fender wells or building newer/taller ones (or buying aftermarket units).
08-11-2012, 12:23 PM | #152 |
Just to educate me, Can I simply remove the fenders and not have to worry about the strength of the structure of the truck?
Project Second Life----1978 c35 http://67-72chevytrucks.com/vboard/s...d.php?t=503961 |
08-11-2012, 12:27 PM | #153 | |
Yes, there will be less structural support but not to the point of other things failing. If anything, the fenders have the opportunity to vibrate more w/nothing securing them @ certain points. The bigger deal is it can/will/does create an ugly engine compartment anytime you track through water that's been sitting on the roadway collecting dirt.
08-11-2012, 01:21 PM | #154 |
I wonder if cutting 1.5 coils out would give more drop on the 1ton than a half ton.
This thing is turning out beautiful, and just remember the credo, thou shalt not drive stock. Posted via Mobile Device
74 C10 LWB 350/T5 Dropped on 20's Soon to be Bagged and Injected 84 C35 Crew Cab Dually. 454/400 Dropped a lot. Instagram: mmmdropp |
08-11-2012, 05:02 PM | #155 |
Agreed, you only want to cut one coil from your coils. 7" in the front should get you level. To get where you are wanting to be in the front with a slight rake in the stance, you can pick up some 3" drop coils and possibly cut a coil off those or see if a place like eaton detroit springs could make you a 4" coil but that'll probably be more costly and will only get you level. The other options I can think of are either more costly or more involved, one is aftermarket crossmember (plus bags) or section the factory crossmember and/or Z the frame.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030 97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver 220,000 miles, all stock for now |
08-11-2012, 08:34 PM | #156 |
It followed me home?
Yeah nothing really wrong with removing the inners other than the battery tray is no longer supported and having to worry about driving through mud, water, etc...
Shh dont tell anyone but when my truck was static I cut two complete coils off and it drove great, didnt bottom out, and I didnt see any negative effects. All of that being said, since you dont want to cut it up just buy some bags and an aol kit and be done with it.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
08-11-2012, 09:24 PM | #157 |
I have a ?? On the rear disc brake. Did you have any trouble bleeding the brakes with the calipers on the top? I've done the conversion in the past and have always put them at the 3 o'clock position. Just curious.
87 Suburban R20 (6bt Cummins) 79 Cherokee Chief (454 from Suburban) - both in progress http://lobie4x4.com |
08-31-2012, 10:59 AM | #158 |
I just got an offer on the truck for 5700 dollars he will take it he will take it half finished give me guidance brothers.
08-31-2012, 12:30 PM | #159 |
Cool build, I just saw this. Obviously it's up to you on where you go with it. I think it's pretty cool that you and your wife work on it together, and you're not far from having something to drive. I would keep it, drop the front and drive it. If you need to raise the back up an inch or two to make it work so be it. I like your idea of keeping the steel wheels too. I love driving my old truck, which is why I bought it. It was also pretty original, but my thought is that if modernizing / customizing it a bit gets it on the road, then it is a plus. Not a huge fan of survivors that sit in garages and get polished and not driven, but that is my taste. I hope to see it get finished! Oh and if you do keep it, throw a 4L80E in it and go to town.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
08-31-2012, 01:13 PM | #160 |
I wouldnt sell it...Just think about all the hard work you have put in it and when you get it how you want it how you feel.... Plus you cant find many good body's like that easy
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
08-31-2012, 10:16 PM | #161 |
I would sell it and put it towards another truck that is more done. You get more bang for your buck buying people's projects.
09-04-2012, 10:47 AM | #162 | |
09-16-2012, 03:25 AM | #163 |
09-16-2012, 12:37 PM | #164 |
so did you end up selling it or keeping it?
1979 GMC 3/4 ton camper special 454 (7/8in drop) UPDATE: CADDILAC 500 SWAP AND 4X4 SWAP http://67-72chevytrucks.com/vboard/s...d.php?t=518625 1965 gmc 4x4 build : http://67-72chevytrucks.com/vboard/s...d.php?t=724972 |
09-22-2012, 05:41 PM | #165 | |
01-12-2013, 10:39 PM | #166 |
Hey guys,
I'm back. So I still have the truck for now. Its winter again and I have time now to work on it again. The tree service business was crazy busy this year so I had no time to work on it all summer. I drove her a couple times from garage to garage. So anyways, I'm going with one of two options: 1) Undo the work to the rear end and lift it back up and drive it daily in summers. OR 2)Lower the front buy getting spindles and lowering springs. I don't want to have to remove the front inner wheel wells. But the issue is the rear end. The rear will be to low for what the front will end up, so what are my options for raising the rear a couple inches?
01-13-2013, 01:17 PM | #167 |
Any thoughts on how I would go about lifting the rear end back up an inch or two.
01-13-2013, 01:21 PM | #168 |
Add leafs back?
01-13-2013, 01:34 PM | #169 |
The leafs are under the axle so i dont think that would do anything.
01-13-2013, 01:40 PM | #170 |
belltech sells shorter shackles
85 swb c10 6/6 drop 83 c10 bagged and sfbd project |
01-13-2013, 02:38 PM | #171 |
Welcome back. The add a leaf might put a little more arch in the springs but would likely be negated by the axle being on top of the springs. You could add some overload airbags and keep a little air in them.
01-13-2013, 04:03 PM | #172 |
Air shocks that you can add air too?
01-14-2013, 08:23 PM | #173 | |
http://www.offroaddesign.com/catalog/shacklekit.htm or http://diy4x.com/cart/index.php?rout...product_id=125 Another possibilty is an air-over-leaf bag set-up. Simply add air to adjust the height you need. The down side to this is there will prob be additional spring rate that will accompany the height increase.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-14-2013 at 08:36 PM. |
01-14-2013, 08:37 PM | #174 |
my truck has the same problem, its an inch lower in the back than the front, so i was just going to put airshocks and leave it. i think the "moving front leaf mounts down" is a good idea!
01-14-2013, 08:44 PM | #175 |
The prob is you might run out of real estate before reaching the amount of lift desired since the height increase is half of what you move it on the frame.
