01-23-2013, 08:06 AM | #151 |
Re: Papa's 67 step side (aka ANOTHER porterbuilt prison)
Yes and yes.. Ordered them from summit.
01-23-2013, 10:37 AM | #152 |
67cheby
great looking headers ! i am checking on a set for Square Peg now !
01-23-2013, 12:37 PM | #153 |
17's too small
I am going to be doing the same set up as you (drop and motor) can you provide a link or information on your fuel cell/pump, and your trans cooler? I just placed the order from PorterBuilt yesterday...the countdown begins.
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows |
01-24-2013, 10:34 AM | #154 |
Im not sure how they will hold up but they sure are pretty when new
01-24-2013, 10:40 AM | #155 | |
In tank fuel pump (make sure to get the 250 pump)- http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm Trans cooler- http://www.summitracing.com/parts/der-13267 hope this helps |
01-25-2013, 10:46 AM | #156 |
Got the two piece drive shaft installed
[IMG][/IMG] [IMG][/IMG] |
01-25-2013, 10:57 AM | #157 |
67cheby
looks great !
01-25-2013, 11:23 AM | #158 |
Looking good friend!
-Rus |
01-25-2013, 03:31 PM | #159 |
nice build! subd
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692 70 C-30 Tow truck AKA Highlighter 02 Silverado 2500 HD CUCVII Tow Rig/DD 1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800 1980 Buick Regal Dirt Stock car |
01-25-2013, 03:34 PM | #160 |
C/10 junkie
I like it!!
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
01-26-2013, 07:59 AM | #161 |
Thanks guys...just slowly plugging away at it
01-26-2013, 08:17 AM | #162 |
Would anyone know if there anything wrong with mounting my bearing carrier upside down?? I will be a lot easier in doing so..
01-26-2013, 06:39 PM | #163 |
I don't think it would matter. But I am not a expert need to asked bomp or keen
01-27-2013, 11:13 AM | #164 |
will do..thanks
01-27-2013, 01:29 PM | #165 |
You can mount it upside down.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
01-27-2013, 01:49 PM | #166 | |
Posted via Mobile Device |
01-27-2013, 02:32 PM | #167 |
Curious who made your driveshaft and if you don't mind the cost?
01-27-2013, 02:35 PM | #168 |
Driveline Inc around thw corner from me...just shy of a grand
01-30-2013, 04:10 PM | #169 | |
17's too small
Yes, that helps, thanks for the links.
On the RCI tank...I take it you had to cut out the area for the fuel pump module, no biggie I assume. Was the tank material thick enough to drill and tap, or did you have to use the pump supplied backing plate? Also, on the RCI tank I can see all of the in and out lines, and the sender (in the middle) but is the large black circular thing just the fill location? On another note, can you confirm the measurement for the steering rack notch. PB directions say 4.5 on one line and then the next says for the C4 to do 3.5. What is confusing me is my dropmember is a Version 4 and the letters C and V are right next to eachother on the keyboard and it might be a typo. Someone else mentioned the C might be for the C4 vette dropmember/components, but that is not mentioned anywhere else in the directions I got from Dave from PB. Thanks, John Quote:
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows Last edited by ChevyCruizer; 01-30-2013 at 04:39 PM. |
03-14-2013, 10:09 AM | #170 |
Im glad work is busy but sure doesn't help me with time to get this on the road. hell of a tight fit to get the LS in there. now need to cut front fenders so wheels don't hit when air is out. sure they need to be cut for turn radius as well..
03-14-2013, 10:12 AM | #171 | |
Im not sure what your asking on the second question to be exact..Definitely call porterbuild in regards, they have awesome customer service! |
03-14-2013, 11:02 AM | #172 |
Looks good man!
03-14-2013, 11:26 AM | #173 |
Starting to look like a truck again! Looks good
03-14-2013, 12:20 PM | #174 |
C/10 junkie
I'm loving those shots.
03-15-2013, 08:38 AM | #175 |
thanks guys.. not sure when i will tear her down and maker her look pretty. gonna run it (unfinished paint and body work) like this (obviously still a little more sheet metal to install) until i have everything worked out.
