#151 |
![]() Join Date: Jun 2012
Re: Wires,Wires, and MORE WIRES..
I'll take them both. I will send payment this weekend I'm guessing your PP address is the (remimartin257 etc etc )
thanks no worries |
#152 |
Just a Member
yes sir. That is it. I guess the pics just made it look like an alternator harness. It's def the engine harness.
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
#153 |
![]() Join Date: May 2012
Do you have any tail harness left w/side markers? SWB
Thanks |
#154 |
Just a Member
None without splices..I don't think Sorry.
#155 | |
![]() Join Date: Feb 2011
#156 |
Just a Member
Well that is no good because I boxed it and took to post.. I will give them a ring.. ERRRRGH
#157 |
Hey Duane!! you out there...today is Friday I got my harnesses yesterday, I finally got the time to compare both harnesses together......and as expected from the posted pics of the engine harness it is the DRIVERS SIDE that has the voltage regulator and the alternator along with the headlights and turn signals, SEE post #147 this harness goes along the front of the truck across the core support. it is not the starting circuit harness which is the side that I really needed(I could tell by the pics you posted) That being said I will keep the harness and use it, as my original harness is jacked up also. Alright! on to new business, Do you have theharness that will feed the starter/distributer and the blower motor, that is the one that runs along the FIREWALL.
let me know please. no worries!! |
#158 | |
Just a Member
#159 |
trust me I compared my original harness to the one I got from you and it is the charging circuit side with the Alternator and the voltage regulator. In your posted pics you show a closeup of a flat 4 pronged connector THAT is the voltage regulator hookup. I believe that ALL of these trucks had the voltage regulator mounted on the drivers side of the truck on the core support another tell is the pic of the heavy rwed wire with the bonnet on it with a brown and blue wire. THAT is the ALTERNATOR feed.
#160 |
I'll PM you my cell # call me.
#161 |
Just a Member
yeah i feel ya' just confused..
#162 |
the relay block you are referring to is, I believe the main power feed to the whole system it is a fuseable link to protect the system.
#163 |
#164 |
Just a Member
Going out tomorrow. Did not insure so now I am out another assembly and money order until it doesn't clear. Will have ANOTHER tack number shortly.. No more wires for me.
#165 |
#166 |
![]() With tracking numbers never supplied I am assuming I am not getting parts or refund anytime soon. Here a timeline to re-fresh your memory. 5/22 - paid for parts ( $72 ) 7/9 - recieved parts - Taillight harness was junk, dome light wire only supposed to be full assembly. 7/10 - Told you would be sending out new parts next day?? 7/12 - Ask for update and sent refund amount I requested. 7/20 - No parts or refund 7/23 - Ask again for update 7/23 - Told post office lost shipment ??, but would get new tracking number 7/25 - Ask for tracking number 7/30 - Nothing yet............. This needs to be wrapped up by Wednesday ( 8/1), no more promises, excuses, or PMs about how great your service and reputation is with other members. After 8/1 I will be contacting the Administrators, bad deal section, Paypal, Oprah, Dr.Phil and the National Enquirer to get this deal far behind me.......... |
#167 |
![]() Join Date: Mar 2012
well said
#168 | |
Just a Member
Duane
#169 |
PM sent, please post when payment sent
#170 |
#171 |
Just a Member
payment sent. sorry for all the hassle and predicaments. Will send out dome light assembly when found.
DUane
#172 |
Refund received.................
