Old 08-29-2012, 04:54 PM   #151
Russell Ashley
Russell Ashley's Avatar
Re: Dutch 1955 build
"finished the corners and fit the bed wood and strips
i am pleased with the fit and look "
I would be pleased too if mine looked that good. That is beautiful. You are doing some very nice work on this truck.
Russell Ashley is offline   Reply With Quote
Old 08-29-2012, 04:54 PM   #152
sopsum
super werk! petje af!
sopsum is offline   Reply With Quote
Old 08-29-2012, 04:57 PM   #153
63split
63split's Avatar
dank u
63split is offline   Reply With Quote
Old 08-29-2012, 10:50 PM   #154
oldman3
oldman3's Avatar
That is looking real sweet....Jim
oldman3 is offline   Reply With Quote
Old 08-31-2012, 02:11 PM   #155
63split
63split's Avatar
put on the rear bumber to see how it would hide the fuel tank
it doesnt stick out underneath so thats good
but there still is a large gap between bed and bumper
so i started on building an apron
made a template
and cut some sheet metal
then a few hours later i got this
then put in some bowtie's
Old 08-31-2012, 04:38 PM   #156
youngrodder
youngrodder's Avatar
Very nice work. It looks good. I wish I would have ran a rear bumper but with my frame set up there was no good way to attach one. Keep it up.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 08-31-2012, 04:48 PM   #157
Kim57
Kim57's Avatar
Filler panel looks real nice. I love the bow ties.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 08-31-2012, 06:09 PM   #158
_Ogre
_Ogre's Avatar
nice work on the panel, but...
now when you go to the gravel pit and the loader operator over fills the bed it will fall on there
shop air compressor timer
Old 08-31-2012, 06:48 PM   #159
oldman3
oldman3's Avatar
Very nice panel you made, nice work...Jim
Old 08-31-2012, 09:09 PM   #160
candyx
candyx's Avatar
The only thing about this build that sucks is that one day it will be done and then there we be no more cool pictures of the neat metal work to look at.Very nice fab work it's nice to be able to see your skills with metal,keep the photos coming.
candyx is offline   Reply With Quote
Old 09-01-2012, 11:08 AM   #161
YahamaR1
YahamaR1's Avatar
YahamaR1 is offline   Reply With Quote
Old 09-01-2012, 03:54 PM   #162
63split
63split's Avatar
there are a lot more with better fab skill on this forum so dont worry
Old 09-01-2012, 03:58 PM   #163
63split
63split's Avatar
oh crap now i am screwed
Old 09-02-2012, 04:24 PM   #164
63split
63split's Avatar
well took everything apart agian
need to do some more on the dash an attachment of the seats
put the chassis back on the rotisserie
for some adjustments and prep for paint.
C notch for the rear axle
Old 09-02-2012, 05:21 PM   #165
oldman3
oldman3's Avatar
Aw man you messed up a dimple, should look great once it's welded in place, nice job...Jim
Old 09-03-2012, 05:24 PM   #166
63split
63split's Avatar
tonight i have been working on the tailgate
straightened it out and removed some dents and rust spots
we had bought a repro tailgate (luckily at a vendor over here and not in the usa)
but it had the chevy script pressed in diagonal
went back to to get a correct replacement
cecked out 3 other he had but all where croocked
so ended up leaving without one
also did some upgrade on the tailgate hinges because i didnt liked the stock hinges with to much play in them
I have put in 2 ball bearings (6202) and put one hollow shaft through over the full lenght
and threaded both side of the hollow shaft for two 1/2 ich bolts
with 3/8 inch thread in them for attachment to the bed
now it moves freely and has zerro play
Old 09-03-2012, 07:05 PM   #167
Kim57
Kim57's Avatar
Nice upgrade on the bed.
Kim
My build thread
Old 09-03-2012, 07:19 PM   #168
oldman3
oldman3's Avatar
Super nice work on the tailgate...Jim
Old 09-03-2012, 07:51 PM   #169
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Great work!
ChuckDriver is offline   Reply With Quote
Old 09-05-2012, 05:04 PM   #170
63split
63split's Avatar
got some more done to the tailgate
made some stainless steel check link straps
i think i will add hole's in the straps for a better look
and polish them
Old 09-05-2012, 05:23 PM   #171
hotrod1
56 - autocross
hotrod1's Avatar
You are spoiling us. Pictures ever day and loving it. The problem will arise when you do not post every day. What to look forward to then?
hotrod1 is offline   Reply With Quote
Old 09-05-2012, 05:52 PM   #172
Kim57
Kim57's Avatar
You're doing some real nice work.
Kim
My build thread
Old 09-05-2012, 06:04 PM   #173
oldman3
oldman3's Avatar
Nice clean set-up....Jim
Old 09-05-2012, 10:13 PM   #174
apache200
apache200's Avatar
How did you make your straps? That looks great.
1958 Chevy Apache Stepside
1955 BBW Fleetside
apache200 is offline   Reply With Quote
Old 09-06-2012, 05:11 PM   #175
63split
63split's Avatar
i have made them from aprox. 1'' wide and abouth 9 gauge stainless steel
and drilled a few holes
