#151 |
Re: 56 step/C5/C6 Z06 BBC
56 Chevy PU http://67-72chevytrucks.com/vboard/s...d.php?t=531955 Question: Know how to sell your truck for $50,000? Answer: Spend $100,000 building it. |
#152 |
![]() Join Date: Jul 2011
Chevette,
Thinking of my next project dad's 38. Could I get the measurement from arm bolt to arm bolt on th rear cradle? Then the measurement from out side to out side of tire? Then the offset of the rims you have? 19x12's right?
Build for my 1959 Fleetside... http://67-72chevytrucks.com/vboard/s...d.php?t=518308 |
#153 |
nice things going on here
#154 | |
Hope this helps. If the track is too wide for you, have a look at the Cadillac. It's very similar to the Corvette (in fact it's built in the Corvette plant). I don't know the spec's on the Caddy, but it might be narrower. Anyway, good luck.
#155 |
Thanks,
Mike
#156 |
Nice work. I'll be waiting to see where this build goes. Real "out of the box thinking" here
#157 |
#158 |
Sorry for being a pain But DAD and I have another measurement question.
What is the height difference between the cradle mounts(front to rear)? Thanks in advance, Mike
#159 |
With the cross member sitting level, front to back (at the base) there is a 2" difference at the mounting surface(front being 2" lower than the back). I have mine set up so the intake manifold will sit level when the engine is attached to the bell housing/torque tube, as I'm not using an LS. I assume you can change the angle of the torque tube to level when using an LS with a level manifold.
#160 |
It should be noted that I have changed the angle of the cross member since that pic was taken.
#161 |
Playin' around with my new pipe bender. Works well.
#162 |
Finding the time and enthusiasm has been a struggle lately. I did manage to get the radiator mounted and the fit is good. It's almost time to disassemble the chassis and get it coated.
#163 |
Looking good.
Keep the pics coming. Kim |
#164 |
That is one Funky looking radiator. Looking good.
Doug 48 chev LWB pickup 350 turbo400 tri power 48 GMC S10 350 700R4 48 che 5 window 2012 Camero suspension & power train |
#165 |
It's from one of Jimmy Johnson's race cars, but it was never used. It is very high capacity. How's the hot rod coming along?
#166 |
Thanks Kim. I'll be trying to get some time in about two weeks to work on it some more. How are things with you?
#167 |
Glad to see you at it again. More pics of that funky radiator.
#168 |
Chevette, good to see you back at it. Keep the pictures flowing while you are working on it. You know how we all like pictures.
Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
#169 |
Thanks Shadow. I'll post a couple more "rad" pics in the next few days.
#170 |
I am always amazed at the quality and quantity of this build, very interesting, keep it coming, like your way of thinking, no in the box here.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
#171 |
WOW ! what a great build. just read the whole thread. i'll be glued the rest of the way.
USN RETIRED there are two things you don't need in the navy. that's a wife and a pick up truck. cause when your out to sea someone else is using them |
#172 | |
Much appreciated.
#173 | |
#174 |
Here's another pic of the radiator and one of the crown removal.
#175 |
Thats taking shape very nice
