Old 07-05-2013, 09:05 PM   #151
f.monroe
f.monroe's Avatar
Re: Project "Shifted"
If you install lower motor mounts won't that raise the rear of the tails haft and make that angle worse? Or are you going to lower the entire assembly, motor and trans together to keep the same angle?
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 07-05-2013, 09:23 PM   #152
jmedero
jmedero's Avatar
How come when I come over there is no beer on that cowl.......? Lol. Ill bring them next time.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 07-05-2013, 09:39 PM   #153
RRC
RRC's Avatar
That's what I was wondering , the angle being 5 degrees is right . So did Nate think you might have just got the wrong motor mounts? Because mine set up at 5 degrees the trans x member is lower than yours. Mine looks like floppydoodle's
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712
Instagram: http://instagram.com/rockylakekustoms
Rocky Lake Kustoms
Russ
RRC is offline   Reply With Quote
Old 07-05-2013, 09:48 PM   #154
floppydoodle
floppydoodle's Avatar
Bennett--G4L mine is a little less than halfway. Actually you can see where I had to shim the tail shaft up so my headers wouldn't hit my control arms. I am machining a 5/8 aluminum spacer to slide in there.
floppydoodle is offline   Reply With Quote
Old 07-05-2013, 10:18 PM   #155
Hart_Rod
Hart_Rod's Avatar
What is the measurement of your motor mounts from the center of the lower mounting point to the tallest part of the motor mount?
Hart_Rod is offline   Reply With Quote
Old 07-05-2013, 10:48 PM   #156
Hart_Rod
Hart_Rod's Avatar
Floppy what angle is yours set at? How high did you have to shim your carrier bearing?
Old 07-05-2013, 11:22 PM   #157
floppydoodle
Rob mine is at 5* like RRC and the carrier bearing is 2-1/2" shimmed up. From the tail shaft to the carrier bearing it runs parallel to the the frame.
Old 07-05-2013, 11:47 PM   #158
Hart_Rod
Hart_Rod's Avatar
What is the measurement of your motor mounts from the center of the lower mounting point to the tallest part of the motor mount? Also, what is the measurement from the bottom of your carrier bearing to the centerline of your driveshaft? Do you have a picture of the front of your engine?
Old 07-06-2013, 12:15 AM   #159
floppydoodle
I'll get pics and measurements tomorrow.
Old 07-06-2013, 12:19 AM   #160
RRC
RRC's Avatar
I'm out camping .....but I will be home tomorrow and can measure that. Unless floppydoodle get it before I get home
Rocky Lake Kustoms
Russ
Old 07-06-2013, 09:51 AM   #161
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Im tuned in on the driveline action... I agree there needs to be a good write up soon..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-06-2013, 07:25 PM   #162
RRC
RRC's Avatar
Rob my motor mount measures 8" from center of the lower hole to the top edge of mounting plate......
Rocky Lake Kustoms
Russ
Old 07-06-2013, 07:31 PM   #163
RRC
RRC's Avatar
Posted via Mobile Device Here is a pic from the front ....the motor is not set at 5 degrees in this pic.....
Rocky Lake Kustoms
Russ
Old 07-06-2013, 08:23 PM   #164
Hart_Rod
Hart_Rod's Avatar
Thanks Russ, mine measures the same. Where are you placing your angle finder to get your measurement?
Old 07-06-2013, 08:50 PM   #165
RRC
RRC's Avatar
The surface of the tail shaft
Rocky Lake Kustoms
Russ
Old 07-07-2013, 09:28 AM   #166
Hart_Rod
Hart_Rod's Avatar
Thanks Russ. Can you get one more measurement from the centerline of the lower engine mounting hole to the centerline of holes that the lower A frame bolt to? TIA
Old 07-07-2013, 09:32 AM   #167
lolife99
67-72 parts collector,…
lolife99's Avatar
I assume everyone is getting their "5 degrees down" measurement with the frame rails level and not setting on the wheels?
Keith
Convert to disc brakes.
Old 07-07-2013, 09:41 AM   #168
RRC
RRC's Avatar
That measurement is 4.5" .....I measured from the top of the lower control arm tube to the center or of the lower motor mount hole....
Rocky Lake Kustoms
Russ
Old 07-07-2013, 09:56 AM   #169
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Good point Keith!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 07-07-2013, 10:01 AM   #170
lolife99
lolife99's Avatar
Originally Posted by BucksSS View Post
Good point Keith!
That's the only way to compare "apples-to-apples", here.
Keith
Old 07-07-2013, 10:16 AM   #171
Hart_Rod
Hart_Rod's Avatar
Thanks. I think we found part of the difference, mine measures 5.0"...
Good point Keith!
Yep
Thanks Keith, that's what I'm using as the reference. I should have mentioned it before.
Old 07-07-2013, 11:45 AM   #172
RRC
RRC's Avatar
Yes my frame is level as well.....I wonder why there would be 1/2" difference ?
Rocky Lake Kustoms
Russ
Old 07-07-2013, 12:06 PM   #173
RRC
RRC's Avatar
Posted via Mobile Device Sorry Rob.....when you said yours was 5 I double checked and it is 5
The frame is still level the other question should be is the 5 degrees measured with the frame level or ride height ?
Rocky Lake Kustoms
Russ
Old 07-07-2013, 01:25 PM   #174
Hart_Rod
Hart_Rod's Avatar
Mine is with frame level.
Old 07-07-2013, 02:23 PM   #175
RRC
RRC's Avatar
I have also heard that it should be measured at ride height ...not sure which is correct though. I could not lower my engine or the rack would hit.
Rocky Lake Kustoms
Russ
