Old 07-07-2014, 11:24 AM   #1
COS399
COS399's Avatar
Re: 89 GMC Cummins conversion
Yesterday I drove it on a 220 mile trip and after about 70 miles noticed that the transmission temperature was creeping up above 200 and finally settled in at 215. So I bypassed the thermostat switch on the trans cooler, added nearly two quarts of ATF and I am pretty sure that the ATF is leaking into the transfer case because there are no oil leaks. On the way home it stayed at about 185 degrees.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 07-07-2014, 08:13 PM   #2
Hankster
Hankster's Avatar
Uh oh.. I'm not real good with tansmission or transfercases.. but that can't be good?
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 07-07-2014, 08:19 PM   #3
MTCK
MTCK's Avatar
That's a bummer. I didn't know the transmission had a thermostat... Guess I had better get educated.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 07-07-2014, 08:59 PM   #4
COS399
COS399's Avatar
I think it will be more labor than parts.
The aftermarket transmission cooler mounted up front has a thermostat that turns the cooling fan on and off, not the transmission.
Old 07-07-2014, 09:22 PM   #5
COS399
COS399's Avatar
I found the installation instructions for the B&M trans cooler and the instructions show that the fan is suppose to come on at 176 degrees F (+ or - 5.4 F) and turn off at 140 degrees F (+ or - 5.4 F). I don't think that this is accurate but the next time I take it out I will take my infrared thermometer and check.
Old 07-08-2014, 01:31 AM   #6
MTCK
MTCK's Avatar
Oh that makes sense. I was thinking a thermostat like restricting flow...
-Marcus
Project Plow Truck
Old 07-08-2014, 07:21 AM   #7
ryanroo
ryanroo's Avatar
That sucks. at least the input shaft seals on the t-case are pretty easy to do. the de-bug process can be a patience tester for sure.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 07-08-2014, 08:13 PM   #8
COS399
COS399's Avatar
hopefully you will be doing some shake down runs soon. That oil pan is killer!
Old 09-13-2014, 10:24 PM   #9
COS399
COS399's Avatar
Not much to report. I have just been occasionally driving the truck around town and to work, which is just one mile away, to keep the batteries charged . I will probably be dropping the transfer case and resealing it after the kid is done with football, basketball jamboree, and the hunting season is over. I sold his 1978 CCLB K35 the other day so I will definitely be giving him this truck. He will barely be 14 this December so I am not planning on doing too much more to it until he is closer to getting his permit. Thanks for following along.
Old 09-16-2014, 03:54 PM   #10
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I have to say that is a bad azz first truck. I hope I can do the same for my kids when the time comes. It's good to hear it's starting alright now too.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 09-18-2014, 08:12 PM   #11
COS399
COS399's Avatar
Thanks Ryan. I'm sure you will have something nice for them. I only have one kid so getting him a vehicle is easier on the wallet. Yes, the truck has been starting right up and I sure am glad I found the problem. We need some updates on your project vehicles.
Old 10-25-2014, 01:51 AM   #12
COS399
COS399's Avatar
Hoping to get a chance to work on transfer case seal this weekend to keep the transmission fluid from going into the transfer case.
Old 11-30-2014, 01:57 AM   #13
COS399
COS399's Avatar
I still haven't changed my leaking seal and now the heater core has sprung a leak. I have been driving it a lot and I have to say that it does really well in the snow and on the icy roads. However, the mileage hasn't been that impressive.
Old 11-30-2014, 02:20 AM   #14
MTCK
MTCK's Avatar
How good (bad) is the mileage? Glad you are getting some miles on her.
-Marcus
Project Plow Truck
Old 11-30-2014, 02:21 PM   #15
MTCK
MTCK's Avatar
That could be a lot worse! Winter just kills mileage. My tacoma gets down to just over 10 mpg sometimes if I'm abusing the auto start and it's really cold out. You're driving twice as much truck.
-Marcus
Project Plow Truck
Old 12-01-2014, 12:25 AM   #16
COS399
COS399's Avatar
i picked up a heater core yesterday and found some time to get it installed today. Now if I could only find the time to fix the seal. Maybe when Ryan is doing his northern tour he could swing by and fix it.
Old 12-01-2014, 04:41 PM   #17
Dieselwrencher
Don't get too excited. I doubt that trip will be happening anytime soon.
Ryan
Old 01-17-2015, 08:12 PM   #18
72MARIO
72MARIO's Avatar
Any updates i am curious how everything is holding up ? How about the mpg any better ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-18-2015, 02:04 PM   #19
COS399
COS399's Avatar
72MARIO - Thanks for asking but I haven't had any time to work on it. It will more than likely be a few months before I will get around to it.
I just got done watching the first episode of POWERNATION: Truck Tech involving the installation of a LBZ Duramax and Allison combo in a 1987 C10 short bed.
Old 01-26-2015, 02:06 AM   #20
COS399
COS399's Avatar
I know it's not a Chevy and it's not like I have a lot of spare time, but the price was right! That is probably how most of our projects get started. I may one day put it in the "Alternate Tinkering" section.
Old 04-21-2016, 06:08 PM   #21
COS399
COS399's Avatar
So today I took the red truck for a little drive and put about 140 miles on her. I checked the mileage and it was 12.5 mpg, but that includes a lot of idling and short trips while tweaking the transmission tune. On my trip today most of the driving was at 75-80 mph. I'm sure the mileage will go up some after I fix the problem with the 3rd to 4th gear shift. I have to say that I got a lot of thumbs up from drivers in the two little towns that I went through.
Old 01-26-2015, 11:49 AM   #22
Dieselwrencher
That is in really nice shape. What are the plans for it?
Ryan
Old 01-26-2015, 01:41 PM   #23
84chevyguyid
I dont recognize the brand, what is it?
84chevyguyid is offline   Reply With Quote
Old 01-26-2015, 08:37 PM   #24
COS399
COS399's Avatar
Don't really have any plans at the time. I like it the way it is right now.
It is an International.
My brother saw the picture and immediately thought of a 6bt conversion.
Old 01-26-2015, 09:43 PM   #25
84chevyguyid
That would have been my guess, what year? Does it still run?
