Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 07-23-2015, 04:18 PM   #151
East Tex
Re: Project 6 Point Oh
New brake hardware, new shoes, new wheel cylinder, and new drums. I always like to put a little brake lube where the shoes rub the backing plate.
My 1972 K5 6.0 LTR 4L60 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=622068
East Tex is offline   Reply With Quote
Old 08-02-2015, 05:00 PM   #152
East Tex
This little cardboard trick didn't work so well in the sandblast cabinet LMAO.
It was worth a try
Old 08-02-2015, 08:03 PM   #153
hemi43
hemi43's Avatar
I use a thin piece of 1/8 thick rubber to blast bolts.
hemi43 is offline   Reply With Quote
Old 08-02-2015, 09:27 PM   #154
East Tex
That's an awesome tip, I will have to try that on my next sandblasting session.
Thanks hemi43
Old 08-06-2015, 05:40 AM   #155
East Tex
More parts cleaning, sandblasting, and painting.
Old 08-06-2015, 05:49 AM   #156
East Tex
Front differential back from the powder coater.
Old 08-06-2015, 05:57 AM   #157
East Tex
Everything on these brake calipers was bad, stripped out bleeder screws, pistons stuck, ect. So, it was cost effective to buy "Loaded" calipers. They come with new caliper bolts, bleeders, brake pads and everything ready to go. Also I got some more Moog front end parts in.
Old 08-06-2015, 06:04 AM   #158
East Tex
Installing rear diff ,springs, and new stainless brake lines. This shop looks so bad, I need to clean it up soon.
Old 08-06-2015, 06:10 AM   #159
East Tex
more...
Old 08-06-2015, 06:32 AM   #160
East Tex
I ran into a couple of problems with wrong parts. First problem was, I went to Rough County's web sight and ordered front and rear stainless brake hoses for a 1972 Blazer with a 4" lift. Well, after trying to install the rear hose I discovered that the brake lines (that go to each rear wheel cylinder) wouldn't screw into the block on the new brake hose. So I called Rough Country and described the problem. They said that maybe their website had the wrong part listed and that they would overnight the correct rear hose. The package arrived and it was the exact same part that I already had and it wouldn't fit. So, I called Rough Country again and explained that they sent the exact same part and it was wrong. They gave up and said to return the hoses for a refund. (I'm in the process of doing that now) Then I called In Line Tube hoping they could sell me some 4" extended braided hoses. They had to build them, but it was no problem and the rear hose fits like a champ!
Old 08-06-2015, 06:39 AM   #161
East Tex
This is the rear brake hose from Rough Country that wouldn't fit. They have some issue with they're parts or part numbers for this application and they can't figure it out. Also I noticed that it was made in China. The new custom built hoses from In Line Tube are made in the USA. Hopefully someone else needing hoses will read this, and it will save them the drama of wrong parts that I went through.
Old 08-06-2015, 06:42 AM   #162
East Tex
New rear hose from Inline Tube. And it fits!!!!!!!!!!!!!!
Old 08-06-2015, 06:43 AM   #163
East Tex
Front brake hoses
Old 08-06-2015, 06:51 AM   #164
East Tex
Here is a picture of Rough Country's brake hose and Inline Tube's hose, side by side. You can see that the female threads in the brass block (on the Inline tube hose) has a larger ID than the threads on the other block. This is where the hard brake lines, coming from both rear wheels, attach. Hope this helps someone.
Old 08-06-2015, 07:14 AM   #165
East Tex
Now for the second issue that I had with wrong parts. This time it was my fault. I had ordered all new stainless parking brake cables from Inline tube and it never crossed my mind that my 4" lift kit would cause issues with my parking brake cables. When I installed the stock length cables, they would fit but were stretched tight and would probably work but I didn't like the idea of them being in a bind. I did tons of reading and researching on other Blazer builds where they had a 4" lift. What I found was the only answer is to call Inline Tube and have them make custom cables that are 3" longer than stock. So again I called Inline Tube and they built me two longer cables and saved the day. I can't say enough good about Inline Tube, they fixed my brake hose issue and brake cable issue, and have quality stuff. Here is a picture of the stock vs the longer cable.
Old 08-06-2015, 07:15 AM   #166
East Tex
Old 08-06-2015, 09:06 AM   #167
aggie91
I'm just glad to be here!
aggie91's Avatar
Man your an earlier riser! Progress is looking good, hope to see this one in person some day. I wonder if you know any of my car buddies over in Tyler, Mike Harty, David Hale, Charlie Molloy, Barry Clark, Stuart Suggs, Keith Harper, Curt Priddy, Don Davenport, and others that I just can't think of right now...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 08-06-2015, 11:58 AM   #168
East Tex
I knew David and Curt but I haven't seen them in years.
Old 08-06-2015, 02:12 PM   #169
notsolo
notsolo's Avatar
This is going to be a great truck! Your New 72 K5 is way better than what was thrown together at the factory. Your attention to detail shows. Carry On.
notsolo is offline   Reply With Quote
Old 08-06-2015, 06:47 PM   #170
East Tex
Thank you notsolo
Old 08-08-2015, 11:22 AM   #171
East Tex
Here is a pic of how the stock length brake cable fit. It rubs the leaf spring.
Old 08-08-2015, 11:25 AM   #172
East Tex
And here is what it looks like after I put the 3" longer on. Much better fit!
Old 08-08-2015, 11:40 AM   #173
East Tex
The other side
Old 08-08-2015, 11:44 AM   #174
East Tex
Rear brake hose installed. I need to hand bend the hard lines some, to improve the looks but it's ok for now.
Old 08-10-2015, 10:55 AM   #175
aggie91
aggie91's Avatar
Looking good, nice progress.
Karl
The LST Challenge:
