11-05-2017, 12:28 PM | #151 |
Re: Mr Green Jeans - the 69 (or not) chevy, er gmc, project
Thanks for the support. It helps keep me motivated. Sometimes that’s harder than the actual work!
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
11-05-2017, 12:31 PM | #152 |
Since knomadd got HIS Dapper lighting headlights in I decided to dust mine off for a trial fit. Plus I’m thinking the bulbs may affect my air box construction since they stick through the core support.
11-05-2017, 12:33 PM | #153 |
White or amber halo rings.
11-05-2017, 04:49 PM | #154 |
tailgate is killer
keep up the good work |
11-06-2017, 09:53 AM | #155 |
Damn, those lights look good! I like the white halos myself, but either would look good. Do they work as turn signals too?
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
11-06-2017, 10:24 AM | #156 |
I bet they could. I didnt buy the optional controller. As they are, there are only three wires. A common ground wire, red line in for white, and yellow line to amber. Haven’t decided if I want to use the amber or not. When I ordered mine they were out of white only and Jonathan at Dapper offered me an upgrade so they could be built faster.
11-07-2017, 05:17 PM | #157 | |
11-07-2017, 09:14 PM | #158 |
A box of random goodies showed up today.
11-07-2017, 09:17 PM | #159 |
...and the next painstakingly slow project starts.
11-08-2017, 04:47 PM | #160 |
Is your MAF sensor a clamp on style that will fit between tubes, or do you have the card style? If it's the card style, how are you adding that?
11-09-2017, 04:29 AM | #161 |
Clamp on. It will push through the back of the enclosure I'm trying to build, and it has three little holes on the flange that I can put bolts through to attach it. I just can't figure out how to make it look good AND be functional.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 Last edited by OKGMC4; 11-09-2017 at 06:25 AM. |
11-10-2017, 05:50 PM | #162 |
Well darn. I was hoping you had the card style like I do so I could steal your idea. It'll look good when you're done.
11-10-2017, 06:34 PM | #163 |
I "think" Spectre makes an aluminum adapter for those style MAF sensors.
11-10-2017, 06:58 PM | #164 |
They do, but it's aluminum. I don't have the welding equipment or knowledge to weld aluminum. I can do stainless just fine. If I could find a stainless weld-in adapter, I'd be set.
11-11-2017, 10:22 AM | #165 |
That’s why I’m doing my intake in steel. I know it’s heavier but it’s what I know I can work with. My father in law is a machinist. I bet if he had a MAF pattern he could make an adapter plate to be welded onto the pipe. I wonder if there’s an eBay market for that?
11-12-2017, 10:28 PM | #166 |
I is dumb. Was about half done with the pipe when I realized the MAF would be pulling in air 90 degrees to itself. With a little reworking I moved it downstream into a straighter section of pipe. Should help it read airflow better. Now I can work on finishing the filter box.
11-26-2017, 05:36 PM | #167 |
I wanted the air box to kinda sorta match the engine covers so I built it with the same perforated stainless steel theme. I’ll paint the metal underneath black and the air box will probably be body color.
11-26-2017, 05:43 PM | #168 |
That looks great.
11-27-2017, 09:11 AM | #169 |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
11-28-2017, 11:50 PM | #170 |
Cool build. Wish I'd have found it sooner. I've never seen a uni-body GM truck before.
01-21-2018, 08:08 PM | #171 |
I have spent a ton of time pondering mirrors. I could go on about the ones I don’t like, or are too big, or just won’t fit the door, or cost too damn much, etc. instead I will just say I have settled on the reproduction raydot mirrors found on ac cobra kit cars and vintage 60’s race cars such as Shelby mustangs and all of the old school British roadsters. I think they are a good balance of fit vs cost vs good looks. Hope you guys like them..
01-21-2018, 10:50 PM | #172 |
I like them, they fit and look nice..
02-18-2018, 11:08 AM | #173 |
Looking good,keep on truckin'
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15. Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e, |
06-01-2018, 08:36 PM | #174 |
OK , its time for an update ... What's UP ?
This is a great project and we want to see more ! As for the mirrors they look good on there . I like the fab work.
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
06-01-2018, 09:05 PM | #175 |
What he said ^ x2
