Re: New project! The "Red Herring"
I had the same problems with my inner to outer cowls. Worst fitting piece ever.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() |
Simple? What's simple?
![]() Join Date: Apr 2007
Cleaned up both cowls, did the seam welds down near the rockers, and trimmed the ends and edges to contour. I also traced out the filler plates for the front, just haven't cut them out yet.
![]() Also did the cab corner braces and set my door gaps for the last time. I was amazed how much better the doors shut just by adding this brace! ![]() ![]() A little hard to tell here, but the rear gap on passenger's side is sitting a little fat, I'll need to weld about an 1/8" to the rear edge of the door to make it even with the others ![]() And driver's side, surprisingly, is 99% perfect as is. I was shocked! ![]() Around the windows at the top of the door... well that' another story ![]() Shifting gears, I picked up the correct air box for my LS motor today - in 2009, they changed from a separate MAF mounted in the air intake to this type, integral to the filter box. Unfortunately they also changed the programming and resistance values, so I'm going to try and use it as-is. I'm thinking I'll build a replica of the lower half of the box directly into the inner fender (running a 4" tube along the inside above the wheel up to the grill area) and then mount the upper section of the box directly to it. Thoughts? ![]() And last, just another little piece of shop junk I picked up at the boneyard the other day - 1981 Buick LeSabre clock. I picked up a 12v power supply to run it off of for cheaps, so it's going to get mounted back in the fake wood dash panel and go up on the wall ![]() ![]()
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
![]() Join Date: Jul 2012
JJ, nice work. I like the idea of the MAF and box placement. And I have seen sensitivity by the PCM to airflow over the MAF. For example, I remember a vehicle with a non GM airfilter setting MAF codes with a light. Install a GM filter and the light, codes went away. Not saying it would do that with this arrangement, just something to be aware of. Will you be using the programming for that MAF?
#4 | |
As far as the placement, this seemed like the best location, but I won't know for sure until I have the stub and motor in the truck, hopefully I have enough width to use it this way; I might have to cant it a bit.
![]() Join Date: Mar 2011
Nice panel work, good ideal with the brace...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
Tonight, I did a lot of sitting in the truck staring at the dash and scratching my head about what to do to fix it
![]() Made the cowl end fillers ![]() ![]() So the problem with the dash was that the steering column - firewall brace was broken, so the dash was cracked all around the gauges and the holes were torn. Since my new column doesn't fit in the recess anyway .. away it went! ![]() You can see here that I also cut out the raised section of the underdash reinforcement and fitted up a new straight piece. Here's where I'm at right now. The dash looks better in the photo than in person, I think ![]() ![]() Also, I discovered that my Pontiac column and the S10 brake bracket don't play nice - the column has the external "bowden cable" turn signal switch, which is mounted in the 10 o'clock position and is exactly where the pedal wants to be. It looks like if I make a new exit hole on the other side of the column for the cable, I can clock the switch around to 2 o'clock and solve the problem, but I've never been inside an early GM tilt column so this could get interesting ![]()
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) Last edited by JJorgensen52; 04-17-2015 at 05:19 PM. |
Like to read your posts, most of your posts tells me how to do mine. We have the same problem area's.
Can't wait to read future posts. The posted pictures and explanation are great, thanks from Holland, best regards Richard |
#8 | |
![]() I told myself I wasn't quitting tonight until I had the pedal assembly mounted in the truck in a way I was happy with. As you can see, that took a bit. Trimmed down S10 bracket ![]() I didn't want to mount the bracket under the dash, so I decided to mount it above instead. To compensate for the lip on the inner edge of the dash, I laid a piece of 1/4"x1-1/4" bar in there (more on this in a minute) ![]() Once that was done, drilled the firewall and cut down the ribs so the booster would sit flat ![]() 16ga reinforcement plate added ![]() And my junk test booster mounted up ![]() Here's the modified S10 bracket. I welded the 1/4" bar stock to the ears, and then plated over the center to make it rigid again. ![]() ![]() And here it is fully mounted in the truck ![]() The two 3/8" bolts under the gauges will also carry my column drop and tie it into that 1/4" bar under the dash; this way, I could have the hardware symmetric ... I'm a little kooky like that ![]() There is an additional 5/16" bolt on the left of the gauges, which ties the end of the bar down. I will probably swap this for a cap head or carriage bolt to make it less conspicuous. I'm still not happy with how far the pedal is off the floor, so I'm probably going to extend the pedal arm down about 2" and likely shift it towards the center of the cab and inch or two as well. I have the pedal assembly out of my parts Olds to use as a donor for more metal that's the right size. I also need to make a new dash - cowl brace, because my original was broken and it probably wouldn't fit with this arrangement anyway. Most likely I'll just use some angle and tie it into the brake bracket somewhere behind the gauges. Stay tuned for more fun modifications - some of you may have noticed I removed the brake lamp switch bracket. Another thing I didn't want hanging out under the dash so I have a plan to make it hidden away ... but not yet ![]()
Nice mod's! You are fast. That would have taken me a week end at least.
#10 | |
I spent a LOT of time today sitting, staring, fitting, fiddling, and so on. I must have had the column and the seats in and out of the truck two dozen times.
The good news is I've decided exactly where I'm hanging the column, I laid out all the pieces to make my dash-firewall brace, how high the seats need to be, where the gas pedal is going, and that I DO NOT need to modify the turn signal switch assembly (thank goodness! ![]() Now a little on the brake light switch. This made for not many photos but a LOT of fitting and fiddling: Original S10 switch bracket (which I cut off and cut down a bunch) welded in the new location ![]() Sitting in the seat or just getting in and out of the truck you can't see it. I may make a dress cover for the underside of the dash anyway, but it's tucked up nicely now. This is the new switch actuator arm. It mounts on the pedal (there is a bolt hole above the booster rod, and the lower part of the arm catches the end of the booster rod pin to keep the arm from spinning) and goes out through the hole you can see in the side of the bracket (directly below the pivot bolt in the previous picture) to hit the switch. The switch is at about the same distance below the pivot here as it was in the G-body setup. ![]() Since I have to be up for church in the AM, I quit in the middle of fitting up the pedal - I've moved the pad (at this point) 1-1/2" down and 2" to the right. I'm happy with the position left to right, but I'm still about 7-3/8" above the floor at the base of the pad. I checked my '71, it's about 5-5/8" ... not sure if I want to move it down more? Figured I would sleep on it. ![]() More pictures tomorrow when I get all these pieces finished up and get the column and the gas pedal mounted in the truck.
Nice update on how you are doing this, will be helpful to a lot of people...Jim
#13 |
Yep, me for one. Thanks JJ! Nice work.
#14 | |
Okay, so this one is a little picture heavy (and I have more, if something isn't clear): Finalized the position of my brake pedal - I measured my HHR this morning and it was 6-3/8", so I settled at 6-1/2" with the truck which felt decent. The second measure is distance from the kick panel. ![]() ![]() Clearance to my turn signal switch - this is with the switch at the bottom of its range and adjusted all the way down, I have about 1/2" at the closest point, and it will never be this far down. ![]() Column drop bracket made ![]() Column drop and base plate tacked in place (I made the base plate to fit the contour of the original firewall so I can seal around the opening). I set the end of the column shroud (so the base of the wheel) at about 5-1/2" from the dash between the gauges, which puts the rim of the wheel relatively close to where the original sat. ![]() These shots show the brake switch arm and bracket all assembled. ![]() ![]() My "Rev.1" accelerator pedal bracket. My brake can't bend 1/8" plate, so I did this using the hammer and vice method - I may clean it up and use it, or I may make another nicer version. Either way, it needs to have a gusset added at the top, it's a little more flexy than I would like this way. ![]() Column all welded up. This took FOREVER to not put too much heat on and damage the seals or anything. ![]() Column bolted in, from outside and inside. I used 5/16" flange head body bolts to mount my base plate. ![]() ![]() Pardon the mess, I haven't cleaned up any of the welds at all yet ![]() Final pedal placement. ![]() And the money shot! Driver's entry perspective. I didn't have my near-NOS GMC horn button in the garage otherwise I would have put it on for the photo ![]() ![]() Note that from this position, you can't see the brake switch or any of the wiring for it (which is installed here). The turn signal switch I am going to loom so it's less conspicuous, but otherwise this is about how it's going to look. And with that big wheel, it still looks like a proper truck! ![]()
#15 |
Awesome! Nice work, great detail. The placement of the pedals looks spot on.
#16 |
Like this set up...Jim
#17 | |
![]() Tonight was more about rework than anything - if I'd been a little more careful when I did the rocker and floor fit-up on this side, I would've been two hours less work tonight. But anyways. Park brake brace (which I finally succeeded in buying after four months of backorder) bolted to the floor and the rocker ![]() If the rocker were about 5/8" further forward I could have made it fit without modification. Here's the after shot, with the pedal and bellcrank mounted. ![]() And the pedal position appears to be pretty much spot on inside the cab. ![]() Now on to new work. I made the dash-firewall brace tonight. ![]() Pardon the ugly welds, I tacked it up inside the dash and I wasn't too worried about making it super pretty The bolts are recessed into the firewall, so thusly they are bumped OUT on the inside. I made this piece from two pieces of 1-1/4"x1/8" plate and welded the studs into it. ![]() And here's a couple shots showing the geometry. The electric wiper conversions don't mount to this brace anyway, so I'm free of that constraint here (though it could be made to work easily enough). ![]() ![]() I tied it directly to the column drop. You may notice that I don't have any threads protruding through the column drop nuts ... I'm not terribly happy with that, so I'm probably going to pick up some longer graded flange bolts for the final assembly. Just for fun, I put it all back together with the original nuts and washers ![]() ![]() Going to pick up my donor truck frame tomorrow, as long as all goes according to plan. Then the real fun begins!
#18 |
Nice work! Why the extra under dash brace? The pedal one not enough? Sucks that it took so long to get that parking brake brace and then had to modify it. Just wondering but what made you think the brace was out and not the sheet metal?
#19 |
Nice work, again. Donor truck frame?
#20 | |
Yessir. Way back on maybe page two we were talking about how I decided to go from the S10 swap to a hybrid frame - the donor is a '68 C10 longbed coil sprung truck. Once I get it in the garage, I'll drop the bed on, situate the cab and then splice in the Olds stub. I was originally going to use a shortbed frame, but one reason and another than didn't happen - I think, though, for getting the rake I want the longbed frame may actually be better for me in the long run. We shall see!
#21 |
Oh Sid, I forgot to answer your other question! If you look at the S10 pedal assembly, back in post #166, you'll notice there's a welded nut on the underside of the bracket right above the pedal pivot bolt. In the S10, the pedal assembly is tied to the windshield frame by a stamped brace with an M8 bolt right there - so I felt it wise to keep a brace for that reason. As well as that, even with the pedal bracket installed, there isn't much separation between the base of the column and the booster on the firewall (meaning the triangle is narrow), so over time if someone pulls on the wheel getting in and out, say, it flexes the firewall and can cause damage to the metal.
I guess it's more peace of mind for me than anything. I want this to be 100% a get in and turn the key truck, my parents aren't the most mechanically inclined so I feel better knowing it's solidly (over?)built.
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) Last edited by JJorgensen52; 04-21-2015 at 05:23 PM. Reason: I have grammatical OCD |
#22 | |
#23 | |
#24 |
Alright, well it took me a bit to get the frame moved with a jack and my engine hoist, but it's where I needed it (which it isn't in this photo
![]() ![]() I spent a little time this afternoon getting the 228 cleaned up and running again, since I'm hoping to yank the frame out and list it as a roller in the next week or so. Anyways, it was making an awful lot of lifter noise and I vaguely recalled something about spare pushrods ... so I dug them out and pulled the valve cover. I think "bent" might be the understatement of the year!! ![]() It's a LOT quieter now. Didn't fuss a bit though, started right up with fresh fuel. Got the rest of the park brake setup installed to make sure everything fits and functions as it should with the new metal alignment. I don't think the pedal is too incongruous ![]() Forward progress, hung driver's sheetmetal: ![]() ![]() I have two questions. First, how in the heck are you supposed to do this once the truck has been painted???? I tried six ways from Sunday and I couldn't get it on there without scraping something. Second, I think I've read a bit about this problem occurring, but is a gap this wide at the cowl normal? It's probably 7/16" or so at the widest. ![]() It looks like the other side will be a little better. I have to fix the rear flange of both fenders anyway, so I'll probably adjust it a bit to compensate. Also thinking I may need to buy new inner fenders - I found a bunch of soft spots along the top of this side, and this is the better of the two. Which is kind of a shame since they're going to get hacked up to fit the stub, anyway. ![]() Last thing, preliminary rendering came back for my gauges today - thought you guys would like a peek. We're making a few tweaks here and there and adding one more warning light (for brakes) but otherwise, this is pretty close.
#25 |
Understood... Keep on keep'in on.
