#151 |
A320 Pilot/USAF Retired
Re: 55 Chevy C-4
Looking good Hank! Did you get a side shot?
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#152 |
Re: 55 Chevy C-4
Looking good!
#153 |
Post Whore
![]() ![]() Join Date: May 2015
Re: 55 Chevy C-4
Looking good hank..
#155 |
Re: 55 Chevy C-4
Thanks everyone. I went back out after dinner and moved the motor back 1 1/2". I've got plenty of room all around now. Going to measure it for a drive shaft then blow it apart and weld it solid.
My 55 Build 55 C-4 |
#156 |
Re: 55 Chevy C-4
Shaping up nicely! dug
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
#157 |
Re: 55 Chevy C-4
Perfect stance!
#158 |
Re: 55 Chevy C-4
Nice. I'm jealous, I should have done bags....
#159 |
Re: 55 Chevy C-4
Your build is looking good.
#160 |
Re: 55 Chevy C-4
WOW!!! I'm impressed. Love the stance. I know it turned into more work than you planned on but it was worth it. Can't wait to see what's next. Keep the pics coming.
I'm not tail-gating, I'm drafting. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=432758 |
#162 |
Re: 55 Chevy C-4
I've been home for a few days and I finished up the rear end. Mounted the gas tank. Then spun it around and put the motor back in and checked the driveshaft. Remade the trans. mount, I wasn't happy with the other one but I forgot to get a picture of it.
#163 |
Re: 55 Chevy C-4
Ooops, forgot my other passion R/C Helicopters.
This one is a Gasser, it has a weed wacker motor on it that's been "Hot Rodded". I have'nt flown it yet and it don't have the main blades on it here.
#164 |
![]() Join Date: Jul 2012
Re: 55 Chevy C-4
Good to see you able to get back on the truck. Good progress! And a cool looking helicopter too!
#165 |
Re: 55 Chevy C-4
Nice work!
#166 |
Re: 55 Chevy C-4
Very nice.
Cool R/C copter. Kim |
#167 |
Re: 55 Chevy C-4
AZ
Coming along nicely, one of the first pictures is a side view showing longer adjustable rods on the 4-link. How long are they? Did you fab them yourself? What size of joints, dom tube did you use? do you think it will change any of the geometry? I've read that using those joints improves the ride. I'd love to get the details on this, what you have done is the route that I'm taking, so any help would be appreciated. Thanks Keep on keepin on NC ![]() ![]()
Been there, wrecked that ![]() |
#168 |
Re: 55 Chevy C-4
Thanks for the kind words everyone.
Nut case, I don't know how much it will change things. I guess I will find out when it gets aligned. I made the Heim joints out of 1" D.O.M. tubing with 5/8ths Heim joints. I don't remember the length. I mounted the Flat Out bracket with enough room for the front bed cross member that holds the step then cut them in and made the other side match.
#169 |
Re: 55 Chevy C-4
Little "detour" in the road. I wanted to get the frame finished so I can now blow it apart and weld it up. Now I started building a Rotisserie. I want to put the frame on it to finish it and paint it then put the cab on it and start on it. I also have a 29 Model A that I have finished building and now need to paint that I've put it off for some time.
#171 |
Re: 55 Chevy C-4
AZ
Thanks for the info. Must be planning on many more restomods to come, building a rotiss. Can't wait to see that come together. That Ferd TK is assume, I know your on your own path for the Ferd, but my first thought when I saw the 1st photo is how cool that would look on a jacked up 4-wheeler set up. I know I may be twisted, but anyway look forward to more posts on both. Keep on keepin on NC ![]()
#172 |
Re: 55 Chevy C-4
The rotisserie is coming along well and will sure be handy. Nice looking Ford. Was it just sitting out in the field like that when you bought it?
#174 |
Re: 55 Chevy C-4
Looks good so far
#175 |
![]() Join Date: Feb 2006
Re: 55 Chevy C-4
You got it going for sure! You being a trucker you must see a lot of old stuff on the road! I just subscribed to this thread.
1955 Chevy truck ( SOLD ) 1955 3/4 ton parts truck. 1957 Chevy truck 1995 S10 Chevy truck 1999 ext cab Chevy truck, w/1998 body style. (for parts) ![]() 1964 Honda 90 2003 Ultra Classic Harley ![]() ![]() |
