04-03-2015, 08:10 PM | #151 |
Re: Parting 1972 C20
Thomas,
I need the whole assembly left and right. Thanks Dave |
04-04-2015, 09:00 AM | #152 |
Vintage 4x4s
Thanks you for checking.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
04-05-2015, 05:48 PM | #153 |
I need a set of pigtails for the front deluxe side marker
Ralph L. Jasper 69 4x4 Suburban PTO winch(NAVY) 13 GMC Ext cab 12 Ford Fusion SE(wife) MAI Interior shop |
04-06-2015, 12:02 PM | #154 |
04-06-2015, 12:09 PM | #155 |
Hi Dave,
I have left and right housings and lenses all in good driver condition for $27.50 each / $55.00 for the pair plus 13.00 for shipping $68.00 total and they will come with the correct screws for the lenses. No gaskets. Let me know. I am going to be away from the shop after tomorrow for the rest of the week. Thank you, Thomas |
04-06-2015, 12:45 PM | #156 |
Sounds good to me, how do I pay you?
04-06-2015, 01:02 PM | #157 |
Thomas: Are the two Vent Windows available? If so, coulkd you snap photos of each and post them and what your price would be to ship them to Mauldin, Sc 29662? Thanks, Doug Massey
04-06-2015, 02:07 PM | #158 |
04-06-2015, 05:29 PM | #159 |
Would you have decent set of drivers amber deluxe marker lense? Wills end funds for pigtails at the same time
04-06-2015, 06:17 PM | #160 | |
$15.00 for the pair onto your order. Let me know Thank you, Thomas |
04-06-2015, 06:19 PM | #161 | |
Hi Doug, This truck had mix matched doors and vent windows. Are you looking for clear or tinted glass and how nice? I do have others I can look at for you. Let me know on the glass. Thank you for the interest, Thomas |
04-06-2015, 06:34 PM | #162 |
I'll take them with new gaskets. give me a total and I'll pp you
04-06-2015, 07:21 PM | #163 |
04-06-2015, 07:22 PM | #164 |
To our valued customers and friends, we will be off line for from the end of day Tuesday 4/7/2015 - 4/13/2015 to attend the Portland swap meet. I may be on line for a very limited time but will be sure to answer all request as soon as possible.
Thank you in advance for your business and patients, Thomas |
04-06-2015, 08:06 PM | #165 |
I am interested in the steering wheel. If still available.
04-06-2015, 08:26 PM | #166 |
Do you still have the gauge cluster? Ill take it if you have it
04-07-2015, 07:44 AM | #167 |
Do you have a p/s bracket for a long water pump 350?
'71 LWB c10-"WORK" in progress 385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall 2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better) 2013 best 7.39 2014 best-7.38 New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage |
04-07-2015, 12:15 PM | #168 | |
Nice for a driver. Has a few cracks and a little grain wear. $100.00 with the horn cap plus shipping. Let me know, Thomas |
04-07-2015, 12:18 PM | #169 | |
I have this gauge cluster from a 72 C30 with a 350. It is a overall decent cluster with a good circuit board. Temp gauge is the worst of all the gauges for condition of face. If you are interested, $50.00 plus shipping. Let me know and thank you for the interest, Thomas |
04-07-2015, 12:32 PM | #170 |
I will need to know what water pump you are using. 73-76 will have a boss with a through hole. 77 up will have the same boss with the hole threaded.
It makes a difference on the P/S brackets. I should have what you need but need to know what water pump you are using. Thank you, Thomas |
04-07-2015, 01:30 PM | #171 |
Thomas,
Any chance you have a driver's side brake caliper? I'm looking for an OEM Delco Moraine piece in good shape that I can rebuild. I have a 72 Blazer 4WD. Thanks, Lee
72 Ochre Blazer 69 Camaro Z28 Garnet Red 48 Willys (rolled) |
04-07-2015, 04:33 PM | #172 | |
I would have to get a casting number from you for what you need. I should have it but need to make sure we get you the correct one. Let me know, Thank you, Thomas |
04-07-2015, 04:46 PM | #173 | |
What I currently have on there has casting # 5473499 (On both sides), not sure if they are original but they seemed to work OK. There is one on EBAY now with that casting # http://www.ebay.com/itm/290651099833...%3AMEBIDX%3AIT The EBAY vender lists it for a 1978 -1980 3/4 ton Metric? Do you have a 72 with that casting #? If not, maybe I should purchase both the left and right from you just to make sure. Hopefully, I'm not making this too confusing....I tend to do that! Thanks, Lee
04-07-2015, 06:03 PM | #174 | |
I am sure I can help you. If you can wait until next week, I will follow up on this and see what we can do. We are In the mean time, if you can confirm the casting number you need, then I can see what we have. I should be able to get you a pair of Delco castings for a 71/72 K5 and/or K10 that will work. If you are not worried about the exact casting number. Not confusing at all. We are loading to go to the annual Portland swap meet and will be back at the shop on Monday April 13th. Thank you for your patients, Thomas |
04-08-2015, 12:17 AM | #175 | |
Next week will be fine. I'll try and dig up some info on the numbers. Good luck at the swamp meet! Lee
