02-22-2016, 11:20 PM | #151 |
Re: 1963 GMC C30 panel truck
Started the blending. Will need to spend some more time on getting it nice and smooth.
02-23-2016, 12:00 AM | #152 |
Nice, what are you using to take your welds down? I find sandpaper flap disc's such as these work the best.
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
02-23-2016, 11:22 AM | #153 |
02-23-2016, 11:26 AM | #154 | |
I have used them, they are awesome. I found that I was able to get to aggressive with them and would end up taking to much off. So I have been using a regular grinding disk, a file and in this case was trying out some sand paper. Makes me be a bit more cautious I guess |
03-04-2016, 12:20 AM | #155 |
Down island for the weekend, tackling the bumpers. The front is mounted now. The back is all ready to go, just letting the paint dry. Pictures to come
03-04-2016, 01:46 AM | #156 |
It's lookin good
03-06-2016, 11:16 PM | #157 |
Thank you, I like you rocker progress as well!
More on the panel. Rear bumper is all bolted up. Decided to start drilling out all the body mount carriage bolt and well... Ended up drilling out all the bolts for the strapping as well. The strapping was crusty, soo, I got them all fire wheeled and painted with enamel. Will be looking into getting some new plywood to lay down, might be tough to find some in 10 1/2' lengths hahaha Last edited by AJCK87; 03-06-2016 at 11:24 PM. |
03-10-2016, 11:34 PM | #158 |
Parts come in!!!!
O yeah, had to put on the lenses and they are looking sharp. Also got , the front windshield seal, cowl to hood seal, front bumper brackets, front floor pan supports, front fender seals and some more barn door hinge seals. |
03-11-2016, 03:00 AM | #159 |
Wow those lights look great!
03-20-2016, 01:40 PM | #160 |
Thanks! Cool work on your fenders!
I had some shop time this weekend and a bit of progress. First I started putting together my front signal lights. I mounted some amber LED panels in the signal housings. Also got a set of new signal lenses. Nice and crisp! Also got a few more hours into smoothing and blending the seam from my passengers side front fender. It's coming along but I still want to do a bit more before I fasten in the support. It sure is tricky to get that seam nice on a big piece of sheet like that. Good practice a guess for when I tackle to rear quarter panels |
03-20-2016, 01:41 PM | #161 |
Here's the fender so far
03-20-2016, 09:43 PM | #162 |
Nice work, good to see you making progress
03-25-2016, 11:27 PM | #163 |
Always hoping to see more though hahaha.
Down island until the 4th. Looking to get some more done on the floor pan, rockers and floor support. Started on the floor here is where I'm at. All the bulbs in the shop were out when I got down, will have to pick up some tubes tomorrow. |
03-28-2016, 06:01 AM | #164 |
Anthony...Great progress on the truck, did you determine if it is a 62, wider frame in the back? I found that a 93 caprice wagon poly fuel tank fits close to the frame rails of my 62, made some new cross braces and hung with 93 OEM straps. May not be what you need for diesel...Ed
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 Last edited by notsolo; 03-28-2016 at 06:11 AM. |
03-30-2016, 12:52 AM | #165 | |
Passengers side floor, rocker and floor support are checked off the list |
03-30-2016, 12:54 AM | #166 |
Got the motor pulled last night
03-30-2016, 12:59 AM | #167 |
Moving on to the drivers side. It is in much better shape, have to repair the hinge adjuster plate and the bracket that holds it in place. Soo many rats nests in the A pillar and rocker!!!
03-30-2016, 01:41 AM | #168 |
It's surprising how much driver and passenger sides can differ, mine was like that as well. The passenger was twice as worse as the drivers. When you are done all the rust repair you'll be glad you got it over with. Keep up the good work
03-31-2016, 01:31 AM | #169 | |
More progress on the drivers side rocker. This side had more material to work with and is turning out better then the passengers side. |
03-31-2016, 01:34 AM | #170 |
Got the hunger adjuster plate fabricated as well
03-31-2016, 02:12 AM | #171 |
Nice work on the inner rocker. Well the burb might actually still be alive. He dropped it off at a yard (don't know what yard) and it might not be crushed for a while. I messaged him to ask if it's still around, if it is I'll be sure to let you know.
03-31-2016, 09:54 AM | #172 |
Thanks that would be awesome! If it's in the Comox Valley I can stop there on my way back to McNeill.
03-31-2016, 10:37 AM | #173 |
Sorry I just heard back from him and it's gone.well the pictures made it look a hundred times better than it was anyways so no big loss.
04-01-2016, 01:01 AM | #174 | |
Went hard today and I got the floor in and fabed up the inner portion of the A pillar. More to come |
04-01-2016, 10:42 AM | #175 |
Nice job! I don't know where you find the time to do all this in one day
