Old 05-07-2018, 09:14 AM   #151
kidd79
kidd79's Avatar
Re: 86 C10 LS 6.0 6L90E Swap
Originally Posted by Jake Wade View Post
Didn't you just have the transmission reworked? Warranty?
The trans was converted from 4wd to 2wd, and the guy that did it told me to bring it to him. But it was toast. The warranty he gave was for the conversion stuff. By not having the trans computer tuned and whomever was driving the truck before tuning the trans toasted the clutches. It's been repaired now after some months down the road and my dad staying on me about getting the truck to where I could at least drive it.
kidd79 is offline   Reply With Quote
Old 05-07-2018, 09:16 AM   #152
kidd79
kidd79's Avatar
Originally Posted by Puzzled View Post
Hello all, i have a 86 gmc truck, developed a ac problem blower won't blow except on low low if switched to high position will blow high if you thump the relay, and will blow if you come off high to medium will not blow high again till relay is thump and it dont take big thump just barely touch it and it will blow, have replaced blower motor, relay, resistor, cleaned and relocate ground, in the spring put new ac panel assembly on with switch don't know what else or where to start next anyone any ideas. Thanks
Sounds like you probably have a bad connection in the plug to your relay for the blower.
Old 05-07-2018, 09:23 AM   #153
kidd79
kidd79's Avatar
Originally Posted by st1 View Post
Stay with it!!! supercharged LS power. sounds good. i totally get what you saying about the build process. I live in NC and my truck is in Nevada, so believe me when I say I get it. Stay with it.
Sorry for not answering you guys sooner. I took a huge step back and put the truck aside for a while. My best friend in the world (good ol Pops) finally talked me into keeping the truck and going ahead and getting it running and driving. Man I cussed that truck, got aggravated with it, wanted to light it on fire, I even kicked it a few times. But in the end I stuck with it. Had to have the trans rebuilt. That was a $2300 repair. It's up, running and driving now. Funny thing is now I'm running into a whole new set of issues that are horse power related.... LOL. We made a little bit of power after it got tuned by Matt Sanford over at Derailed Motorsports north of nashville on 93octane (Fuel contains up to 15% Ethanol.. That's what the pump said when I filled it up... LOL!!)
Old 09-26-2018, 12:44 AM   #154
destructiondylan
I've been through the whole thread and I couldn't find if you said what mount you used between the trans and the hooker crossmember? Doing this same swap and need to know what isolator you used. Did it come with the crossmember? Thanks
destructiondylan is offline   Reply With Quote
Old 09-26-2018, 11:16 AM   #155
kidd79
kidd79's Avatar
No sir. It didn't come with the hooker cross member. It's a standard energy suspension trans mount for any th400, 4l60e, 6l80e. I don't have the part# off the top of my head. Two bolts that mount to the trans, one stud that mounts to the cross member. Hope that helps you bro. "A" lol. ;-)
Old 09-26-2018, 05:58 PM   #156
destructiondylan
Helps a lot. That's exactly the insulator I was looking at and was hoping it's the one you used. I'll get it ordered!
Old 09-26-2018, 06:01 PM   #157
kidd79
kidd79's Avatar
Awesome! Happy to help out buddy!!
Old 10-22-2018, 08:44 AM   #158
kidd79
kidd79's Avatar
Been cleaning up things under the hood a bit. Watched a couple youtube videos on how to bend tubing. I think it turned out ok for my first time.
Old 10-22-2018, 08:52 AM   #159
kidd79
kidd79's Avatar
Called the guys over at Little Shop MFG and got a set of their stock size wilwood front disc dual piston caliper brakes. considering they are "stock" replacements installation was quick and easy. Had to get a conversion hose to adapt the trucks hard line to the wilwood caliper, but that was straight forward too. They have them in stock. And yes, I have the dust shields installed. Was mocking things up to see how they fit while waiting for new dust shields to show up in the mail.
Also went on and ordered the caltracs. Man.. Those things definitely helped out a ton!!!
Old 10-22-2018, 09:07 AM   #160
kidd79
kidd79's Avatar
Got tired of not having any reverse lights since the cadillac tail lights don't have them installed, so I got creative. They don't put out a ton of light, but at least people can see them when I'm backing up.
Old 10-23-2018, 02:11 AM   #161
MTCK
MTCK's Avatar
Looks great. Does it hook up better now?
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 10-23-2018, 07:02 AM   #162
kidd79
kidd79's Avatar
Yessir. It's way better now, and it's not as noticeable at higher speeds when it down shifts and spins the tires under full throttle. If I were to run some softer tires the tire spinning at hwy speed would probably go away.
Old 10-26-2018, 12:34 PM   #163
aggie91
I'm just glad to be here!
aggie91's Avatar
Nice work on the hydroboost hard lines. One of the best installs of that system I have seen.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 10-26-2018, 12:43 PM   #164
kidd79
kidd79's Avatar
Thanks bro!
Old 02-10-2021, 09:58 AM   #165
kidd79
kidd79's Avatar
Well. After this whole COVID BS. The economy shutting down, life acting a fool and a ton of other reasons that shall not be gone into on a forum, Beastie has been sold to her new owner. It was definitely a long project, lots of money, time, blood sweat and aggravation. Even with all the ups and downs I think the experience was worth it. Made a few friends along the way, even lost a couple. But still worth it. Thanks to everyone that helped out along the way. You all kick ass!!
The party ain't over though. Once things settle back down and return to somewhat normal I'm sure the 71 that I got to replace the 86 will be getting some LS attention.
Old 02-10-2021, 02:42 PM   #166
aggie91
aggie91's Avatar
Sorry to hear you got rid of the red truck, but the '71 looks like a great starting point!
Karl
The LST Challenge:
Old 02-10-2021, 04:30 PM   #167
kidd79
kidd79's Avatar
Thanks Karl.
Yes sir. The 71 "Earl" as I call it, has pretty decent bones as far as I have seen so far. It's a stock 350 block,882 heads, mild roller cam (specs unknown), lifters and rockers with a TH350. Nothing wild just yet.
