Old 02-03-2016, 09:42 AM   #151
rtinniste
Re: Project U S Army Sargent Slam
Originally Posted by fredscarryall View Post
Rtinniste. It was real easy to mount the running board brackets.put a jack under the running board and bolt the back of the running board to the front of the rear fender making sure your splash shield is mounted so you get correct gaps.
Now I think about it I think you've mentioned how you did it in another thread. Looks good and thanks for the tips I was thinking about that route but my stock mounts were kinda beat looking so I didn't even want to hassle cutting rivets I had enough on the s10 frame when I put my 4 link in. Plus I want to sell the stock frame soon, its taking up my side yard/summer fab shop.
But I got one side built last night ended up building a 1x3 frame that bolts to the frame rail also doubles as a slider and keeps my sheet metal from getting thrashed.
rtinniste is offline   Reply With Quote
Old 02-04-2016, 11:58 PM   #152
fredscarryall
fredscarryall's Avatar
Got my cross drilled slotted rotors today with ceramic brakes for my zr2 rear axle.
fredscarryall is offline   Reply With Quote
Old 02-05-2016, 12:00 AM   #153
fredscarryall
Painted the calipers red. Swapping out the rear axle tomorrow.
Old 02-05-2016, 12:06 AM   #154
fredscarryall
Going to start with putting a 2" c notch in the back first because the rear axle in resting on the frame
Old 02-05-2016, 10:45 AM   #155
Coach529
Coach529's Avatar
Those rotors look awesome
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 02-06-2016, 12:59 AM   #156
fredscarryall
The only part i don't like when doing a c notch on an s10 frame. Cutting off the bump stop bracket
Old 02-06-2016, 01:05 AM   #157
fredscarryall
I love my harbor freight plasma cutter. I have used it about 10 times so far without a single problem.$650 was a heavy hit, but worth it
Old 02-06-2016, 01:11 AM   #158
fredscarryall
45 minutes later with a cut off wheel. Since the bump stop bracket was welded to the frame I couldn't use the plasma
Old 02-06-2016, 01:14 AM   #159
fredscarryall
10 minutes with the plasma. The longest part was marking the frame with a sharpie for the cut.
Old 02-06-2016, 01:17 AM   #160
fredscarryall
Mocked up the c notch. I am going to both weld and bolt it to the frame.
Old 02-06-2016, 01:24 AM   #161
fredscarryall
Saw this bumper yesterday on eBay. Looks pretty cool in matte black. Thinking about doing this on my truck
Old 02-06-2016, 09:54 PM   #162
yawdie1
yawdie1's Avatar
Nice truck. wish I am motivated to work on mine.
1950 chevy PU work in progress.
yawdie1 is offline   Reply With Quote
Old 02-08-2016, 11:56 AM   #163
deejaaa1
I've used a 230v gas Harbor Freight mig about 13 years now. have had to rework the handle/nozzle/gas feed several times but it won't die. have it rigged to use a 20 pound spool also. might have to check out that plasma cutter.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 02-09-2016, 12:09 AM   #164
fredscarryall
Got one frame notch welded and bolted in. Believe it or not. I am mentoring a 15 year old neighborhood kid on building this truck and I had him do all the prep and welding for the c notch. The welds had perfect penetration. He has lots of skill and talent beyond his age.
Old 02-13-2016, 12:21 AM   #165
fredscarryall
Got the dropped spindles,new upper control arms ,lower control arms and slotted drilled rotors on. Had to order new front calipers because mine were froze up.so I can't finish till next week.
Old 02-13-2016, 12:28 AM   #166
fredscarryall
Finished installing the zr2 rear axle. Has to oval out the spring perch holes to fit the axle on the air bar.Rear calipers were frozen to. Just have to figure out emergency brake.
Old 02-13-2016, 06:05 PM   #167
FarmerSid
FarmerSid's Avatar
Nice work. I like my plasma alot too. Anymore info on that bumper from ebay?
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 02-13-2016, 11:42 PM   #168
84blaze
Nice project man. I'm running the same ride tech 4 link as you on my 49'
84blaze is offline   Reply With Quote
Old 02-15-2016, 02:17 AM   #169
deejaaa1
OMG, that is wonderful!
i can remembering watching my 'neighbor' Helegard mentoring me with his 'slant six' and imprinting the memories of his life. i still look upon that time and his words of wisdom.
if i could only reverse time.........
Old 02-18-2016, 11:55 PM   #170
fredscarryall
Got the brakes all set up today
Old 02-18-2016, 11:56 PM   #171
fredscarryall
Rear
Old 02-19-2016, 12:01 AM   #172
fredscarryall
Layed out. Running boards sit an inch off the ground
Old 02-19-2016, 12:02 AM   #173
fredscarryall
Front
Old 02-19-2016, 12:03 AM   #174
fredscarryall
Drivers side
Old 02-19-2016, 12:05 AM   #175
fredscarryall
Back view
